Old 01-12-2012, 06:04 PM   #26
tubbedII
needs more $$$
tubbedII's Avatar
Re: Bagged - Key to Low Ride Height
Originally Posted by chevjayfsd View Post
Well that's the thing... In hearing how much $$ it's going to take to ride at Al's aired out height, I'm just going to mimick his height. So to get a ride height like Al's RIDE HEIGHT, the tubulars aren't required? Correct? Sure they are a nice addition, and I will get them one day, but for now, if I can, I will just stick with the stock A arms. That way it'll give me an excuse to work on it later!
With air bags you can ride at any height you want, correct...BUT there's a sweet spot where the bag is at a spring rate for a nice ride which I think is when the bag is between 7-9 inches tall (psi I do not know). The problem with not doing something like the dm/tubulars and trying to ride this low all the time is that your spring rate may be lower than ideal and not provide good ride quality because the bag may not be inflated to the 7-9 inch range.
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 01-12-2012, 06:42 PM   #27
chevjayfsd
Project 7dos
chevjayfsd's Avatar
Nate - You know what would be wonderful?! I think Porterbuilt needs my truck as a sponsor truck!
7DOS - 1972 C-10
350/350
Porterbuilt/Accuair
20x8.5/20x10
Ride Low or Die
PSSST - Yes it's bagged.
7dos build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=610290
chevjayfsd is offline   Reply With Quote
Old 01-12-2012, 06:55 PM   #28
shawno72
C/10 junkie
shawno72's Avatar
Mine too, for the 67-68 look.
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 01-12-2012, 07:20 PM   #29
lolife99
67-72 parts collector,…
lolife99's Avatar
Originally Posted by jimmydean View Post
You can use the dropmember with your stock arms to get lower than Al's. That is a great looking truck, Al.
Stock 67-87 upper arms.
The lowers have to be 73-87 a-arms.
Keith
Convert to disc brakes.
Old 01-12-2012, 07:22 PM   #30
lolife99
lolife99's Avatar
Excellent point.
And,... if you plan to drive it a bunch,... the front end alignment needs to be in proper specs.
This may cause you to drive with the front, higher than you want, (with a stock crossmember).
The Dropmember addresses all of this.
Keith
Old 01-12-2012, 07:26 PM   #31
tubbedII
needs more $$$
tubbedII's Avatar
Shoot...how about a blazer with a 67-68 nose...but just a "mild" so the rear bench is still usuable.
1970 2wd Blazer
Old 01-12-2012, 11:49 PM   #32
jtp67-72
jtp67-72's Avatar
Here's the front--rear is an extreme drop (U could use a mild) Already tried the sponsor route--Nate said I was # 1,204 down on the list!!!!!!!.............lol.......^^^^^I can just hear Keith laughing.............jim
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791
jtp67-72 is offline   Reply With Quote
Old 01-13-2012, 11:57 AM   #33
jimmydean
jimmydean's Avatar
Oops, my bad. Forgot that part. My arms are '75s.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
