Old 01-13-2012, 07:20 PM   #1
jrisch
jrisch's Avatar
HELP!!!! Torsion bar Removal
I have been working on my truck now for about 3 month now and making great progress but ran into a stand still on the torsion bars, I would like to remove them from the control arms but have not had any luck getting them to move at all, I assume they have never been off the truck due to the amout of grease and dirt that was welded on them.
I would like to know if anyone has removed them before, and if so do I need to press them out or should they come out just with brute force
Im hoping someone will be able to help on this becouse I will be sending the parts out to be powdercoated next week and I would like to have it apart by then!!!!!
Thanks for all you help guys and gals!!!!
1962 Chevrolet S/B Fleet side
Engine: 283 Transmission: 3 speed manual
2 do list !!!!!!
Frame off-2 1/2" front , 4" rear
Rebuild engine (or find a 327), 700R4 Trans, relocate gas tank, Bed wood
jrisch is offline   Reply With Quote
Old 01-13-2012, 07:28 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: HELP!!!! Torsion bar Removal
Mine never did come out. After I pulled the suspension I gave them several good solid whacks with a sledge hammer just to see if I could remove them at all, and to make it easier to transport to the dumps. They never budged so eventually I gave up. Soaking with WD40 didn't help either. Maybe something like PB Blaster would have made a difference. A press may be the only solution.
Old 01-13-2012, 07:33 PM   #3
jrisch
jrisch's Avatar
I have been soaking them in liquid wrench for about the last 2 days and going to try again tonight, I hope I dont have to go to that extreme though, what did you do for the front end?
2 do list !!!!!!
Old 01-13-2012, 07:57 PM   #4
Imperial Kustom
100% gearhead
Imperial Kustom's Avatar
I unbolted the rear of mine and then used heat, A LOT of penetrating lube, a length of pipe as a drift, and a gigantic hammer. It took a while and made me tired too.
Imperial Kustom LLC
Meridian Idaho.
I never stopped playing with cars, they just got bigger.
Imperial Kustom is offline   Reply With Quote
Old 01-13-2012, 08:16 PM   #5
markeb01
Senior Enthusiast
markeb01's Avatar
I installed a 1975 disc brake front suspension:
Here's a link showing what it took to do the conversion:
http://67-72chevytrucks.com/vboard/s...d.php?t=366828
Old 01-14-2012, 12:39 PM   #6
andyspinstriping
Heat up the lower a arms where the torsion bars go into them with a torch...get them red hot and then hit them with an air hammer. They will slide right out.
andyspinstriping is offline   Reply With Quote
