Old 01-14-2012, 01:33 AM   #1
stepside-mitch
stepside-mitch's Avatar
Fixing a cracked dash pad
Anyone ever used bondo to patch the cracks on their dash pad? I would imagine it turning out halfway decent if it is done right
stepside-mitch is offline   Reply With Quote
Old 01-14-2012, 01:36 AM   #2
black_sheep454
Re: Fixing a cracked dash pad
The hardest part would be matching the texture. It may look good for a while but they 2 different materials will expand and contract and 2 way different rates so it will probably crack back fast being hit with the sun right next to the windshield.
1968 chevy lwb, getting ready to join forces with the 70 gmc
1970 gmc swb, getting ready to be a 68 chevy swb
1971 gmc lwb 2500 2wd Sierra Grande
1988 chevy 1-ton crew cab 2wd waiting for a 12v cummins
black_sheep454 is offline   Reply With Quote
Old 01-14-2012, 02:17 AM   #3
JRANGER
JRANGER's Avatar
I bought an overlay online for about $115 on ebay....I test fitted it and it looks great!
JRANGER is offline   Reply With Quote
Old 01-14-2012, 07:59 AM   #4
It won't work for the reason given by Black Sheep 454. Bondo is meant to go onto rigid material and the dash pad is soft vinyl over foam (flexible). They crack because they lose their flexibility
Old 01-14-2012, 01:14 PM   #5
travis401
theres a bunch of people over on my car forum (common problem to have a dash pad crack on 3rd gen f bodies too) that full the cracks with a sandable flexible epoxy then wrap the dash in vinyl. they usually turn out looking good. there was even one guy who fiberglassed and airbrushed his.
travis401 is offline   Reply With Quote
Old 01-14-2012, 01:38 PM   #6
ont_guy_38
ont_guy_38's Avatar
Lots of threads on the subject if you do a search
ont_guy_38 is offline   Reply With Quote
Old 01-14-2012, 05:46 PM   #7
broey
Square
broey's Avatar
if you fiberglass the cracks first you can use bondo as a filler to smooth everything out.
Squarebody Syndicate
broey is offline   Reply With Quote
Old 01-14-2012, 05:57 PM   #8
mongoose
mongoose's Avatar
theres a guy on here who patched his then put bed liner on and painted it..
looked good from the pictures, i was going to do that with mine, cover the speaker holes as well.
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 01-14-2012, 08:05 PM   #9
JRANGER
JRANGER's Avatar
check this link out....Basically you have to sand down your raised spots, use alcohol wipes, and then spread adhesive on your dash..This will lay over it and look great!
http://www.ebay.com/itm/DASH-PAD-REP...item1c227a1a00
Old 01-14-2012, 10:04 PM   #10
OleBlue79
OleBlue79's Avatar
Trim down the turned up edges around the crack. Fill in the cracks with Great Stuff foam. Spray the entire thing with spray can bedliner and paint to desired color.
79 C-20 Scottsdale 350/400 3:73 gears 9 leafs and a headache rack (I speak English, thank you)
OleBlue79 is offline   Reply With Quote
Old 01-15-2012, 10:26 PM   #11
Pop's C-10
Pop's C-10's Avatar
that is a good idea..
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 01-15-2012, 11:23 PM   #12
Texasupton1
Does anyone have any photos of this? What could you use for speaker grid?
Texasupton1 is offline   Reply With Quote
Old 01-16-2012, 01:35 AM   #13
oldschool18
oldschool18's Avatar
here are some pics of a dash I did, I took out all the bad bondo the fiber glass resin over the whole thing then wraped it in vinal Name:  dash%20bare.jpg
_________________________________
62 Impala
70 C-10 LWB
71 K-10 SWB
85 C-10 LWB==SOLD
01 2500 HD
Members Met......2003Silverado (Dave)
oldschool18 is offline   Reply With Quote
Old 01-16-2012, 01:36 AM   #14
oldschool18
and theres a 7.5 tv in the middle in case anyone didnt know what it was....haha
62 Impala
70 C-10 LWB
71 K-10 SWB
85 C-10 LWB==SOLD
01 2500 HD
Old 01-16-2012, 02:13 AM   #15
broey
Square
broey's Avatar
fiber glass and bondo for mine too.
Old 01-16-2012, 04:37 AM   #16
Stepper86
Stepper86's Avatar
I used flexible epoxy oon mine, and painted it. You can still see the cracks from sertain angles. But it was easy and didnīt require much work so Im happy with the result. Itīs a bad picture. But you can see a small ridge just over the steering wheel. I will take it out at some point and wrap it in tweed, but for now itīs good enough.
Tom.______________________________________
The fleet:
2007 BMW 530xi M (daily driver)
1986 C-10 Stepside (project "my time")
1992 Corvette cab (summer time daily driver)
1969 Cadilac DeVille Cab ("it just need some paint")
Stepper86 is offline   Reply With Quote
Old 01-16-2012, 05:49 AM   #17
bigwheel15
bigwheel15's Avatar
Looks nice, what is flexible epoxy and where did you get it?
bigwheel15 is offline   Reply With Quote
Old 01-16-2012, 10:51 AM   #18
Stepper86
Stepper86's Avatar
Itīs similar to silicone sealer, the stuff u use to seal windows and frames on a house. But this stuff acts like a glue and you can paint it. I used something called Sikaflex, you can all so use windshield glue ( used on cars that donīt have a rubber seal like our trucks)
Just lay a bead in the crack and level it up with piece of plasticard, like when you apply bodyfiller. When it has cured you can trim it down with razorblade or a sharp knife if needed.
If the edges of the crack are sticking up put a piece of plasticfoil over the crack and weight it down with something while curing.
The fleet:
Old 01-16-2012, 11:38 AM   #19
jitteryguy
GoatLube Experss
jitteryguy's Avatar
I'd like to see it after you install it, be sure and post some picture's !
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 01-16-2012, 05:40 PM   #20
OleBlue79
OleBlue79's Avatar
Talking Re: Fixing a cracked dash pad
Look what I found.
http://www.urethanesupply.com/produc...stype=products
You could do like I said, trim the turned up edges on the cracks, apply this stuff to fill in the cracks, sand everything down, spray with truck bed liner and paint. As far as the speaker grill I think I would just fill it in. Nobody uses them anymore anyway.
Old 01-16-2012, 05:59 PM   #21
Rogue_Alphonse
Rogue_Alphonse's Avatar
I used expanding foam and shaved/sanded it down, also wanted to make the dash contoured so I used it as filler. Then I wrapped it in pergo [you know, hardwood floating floors] foor insulation before using two layers of fabric. Honestly it was thrown together but turned out better than I had expected!
1991 Mustang GT Vert, T-5 w/ Pro 5.0, Trick Flow upper & lower, BBK cold air intake, 3:73, BAMA chip, etc.
1988 K5 Blazer, [coming soon] TBI 400, SM465/NP208, 12 bolt rear, 3:08's, looks like a 1980.
1998 Jeep Grand Cherokee 4.0 fully loaded daily driver!
Where there's a will, there's a rig!
Rogue_Alphonse is offline   Reply With Quote
Old 01-16-2012, 06:26 PM   #22
JRANGER
JRANGER's Avatar
Will do...Im going to get my floor pans welded this weekend but I will prob start on that in a week or so....Ill go ahead and put it on as a test fit again and snap a photo this weekend as a teaser for ya
Old 01-17-2012, 11:12 PM   #23
JRANGER
JRANGER's Avatar
OK here is my nasty dash pad and here is it with the ebay cover laying on it..I will just have to cut the high points and then smooth and clean it all...The cover comes with adhesive and that will be that
Old 01-18-2012, 10:27 AM   #24
OleBlue79
OleBlue79's Avatar
That looks good. I bought one like it for my 79 from another vendor on line. The thing to remember with these things is that in 78 I think Chevrolet moved the VIN number to the dash from the door post. If you have one of these you have to either cut a hole in it so the VIN is visible or don't apply the adhesive. Mine looked too good to risk messing it up by cutting a hole in it so I did not use the adhesive. It's been on the dash for close to a year with no problems.
Old 01-18-2012, 10:38 AM   #25
JRANGER
JRANGER's Avatar
hmmm, I will double check but I didnt see a vin on my dashpad
