Does anyone know why or if the disk brakes from a 70-72 will work on a 67 1/2 ton (other than the 5 to 6 lug wheels). I want disks up front but still want the origional look of 6 lug.
jim gallagher |
Who's in CHARGE??????????
both are basicly a bolt on swap...........joe
Send a card to a soldier in Iraq My Music PlayList Large Marge Donate Blood,Plasma,Platelets & sign your DONORS CARD & SAVE a LIFE |
Re: more disk brake conversion questions?!?
i had a list of the chevy parts that are needed to do this conversion but lost it. it was on the message board but where? does anyone know where to find it again?
jim gallagher |
True Addiction
I believe that you need to switch balljoints and tie-rod ends. Other than that, Im not sure.
If you have the complete swap do that, it's easier than figuring out the ball joints and tie rod ends.
All the stuff will work or you can use the later model stuff and buy 6 lug rotors |
the article i had was a list of all the chevy part numbers (from the Hollander interchange manual) needed to make the bolt on conversion. these parts were from a late 70's truck. it also listed a couple parts that were required to be changed over to make the thing fit. i beleave you needed to use 67 3/4 ton outer tie rod ends to fix the newer spindle steering arm. other than that it was a direct fit.
jim gallagher |
![]() ![]() Join Date: Feb 2004
I FOUND THEM AGAIN! Here are the 2 best threads i found about the 6-lug disk swap. I have them saved on my computor but here are their location on the board, hope they're still there for everyone else.
"The 1947 - 1998 Chevrolet & GMC Pickup Message Board Network > FAQ submissions > TECH-FAQ: DiscBrake/Tie-rod End/Interchange" (Author of Thread 68dontneedanewone) "The 1947 - 1998 Chevrolet & GMC Pickup Message Board Network > FAQ submissions > easy disc brake swap" ( Author of Thread dream68)
jim gallagher Last edited by pa_snowman; 04-09-2006 at 10:13 PM. |
