Old 01-14-2012, 07:24 PM   #1
apache200
apache200's Avatar
Hood Bolts??
I need help with the size of the bolts that hold the hood to the hood hinges. Thank you for the help
1958 Chevy Apache Stepside
1955 BBW Fleetside
apache200 is offline   Reply With Quote
Old 01-14-2012, 11:44 PM   #2
Jmageee902004
Re: Hood Bolts??
Just a heads up i posted the same question on the stovebolt page il let you know if anything comes up
Jmageee902004 is offline   Reply With Quote
Old 01-15-2012, 04:58 AM   #3
apache200
apache200's Avatar
Re: Hood Bolts??
ok thank you
1955 BBW Fleetside
Old 01-15-2012, 02:47 PM   #4
youngrodder
youngrodder's Avatar
Re: Hood Bolts??
You both realize that they are special sholdered bolts correct? You can't use just regular bolts. You might just want to pick up a set from Classic truck parts of America.
http://www.classicparts.com/1947-54-...ctinfo/38-525/
Good luck
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 01-15-2012, 03:37 PM   #5
drivea55
drivea55's Avatar
Re: Hood Bolts??
Its an american thread and although they are shoulder bolts, function wise they do not need to be. I used over the counter s.s. bolts with 2 size s.s. washers and it looks and functions just fine.
current project;
1950 GMC "Junk Yard Dawg"
http://67-72chevytrucks.com/vboard/s...d.php?t=635960
___________________________________________
SOLD to "ONEBADFIVEFIVE"
http://67-72chevytrucks.com/vboard/s...d.php?t=436406
drivea55 is offline   Reply With Quote
Old 01-15-2012, 06:51 PM   #6
Jmageee902004
Re: Hood Bolts??
hes the link from the stovebolt page
http://www.stovebolt.com/ubbthreads/...gonew=1#UNREAD
Old 01-15-2012, 08:35 PM   #7
OrrieG
OrrieG's Avatar
Re: Hood Bolts??
Good luck
Marc
Gee guess I got lucky, in 85 mine were pretty crusty so I just used standard grade 5 hex bolts and washers. They worked for 15 years as a dd. I think the original intent of the shoulder bolts with the knurled backs was to eliminate the need for lock washers on the assembly line.
Old 01-15-2012, 11:51 PM   #8
JumboAMONGus
JumboAMONGus's Avatar
Re: Hood Bolts??
yes its just a locking bolt shoulder bolts ,,i use regual 9/16 bolts with lock washers and a washer also never had a problem ,,i went stainless too ,or grab some fender bolts same size from a junk yard ..lol
JumboAMONGus is offline   Reply With Quote
Old 04-16-2012, 05:41 PM   #9
skip99
skip99's Avatar
Re: Hood Bolts??
what about the ones on the hood ? not the hinge to body side...
a regular bolt is too sloppy,right?
talking about a 51 hood..
Tami's 51 build
http://67-72chevytrucks.com/vboard/s...d.php?t=428878
skip99 is offline   Reply With Quote
