Roto Reuter thats the name...
![]() Join Date: Feb 2010
Need your opinion on 8-lug drum to disc conversion
I'm seriously thinking about converting my '69 C20 to front disc brakes. I have been looking at the CPP kits, but I'm not sure if I should keep the 8-lug set up or change it to 5-lug. What do you guys think? If I change to a 5-lug set up would I have to change out the entire rear end, or is a gear/axle swap possible on a corporate 8-lug rear end? Lets hear it!
~ Dan ![]() My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
Re: Need your opinion on 8-lug drum to disc conversion
Anyone have any thoughts? If I convert to front disc brakes should I change over to 5-lugs? If so, what would I have to do to the rear end to convert over to 5-lug?
Converting to a 5 or 6 lug setup is your preference. You'll probably find better wheel selection if you do. I have a '69 longhorn and used the disc brake setup off of a '71 longhorn.
Thanks. I'm trying to find out what I would have to do to the rear end in order to keep the same lug pattern if I wanted to go with 5 or 6-lug set up. I was hoping to find someone that has gone through this with a 3/4 ton 8-lugger.
67-72 parts collector,…
![]() Join Date: Nov 2002
You will have to swap out the entire rearend housing.
Is your truck a coil spring rearend or leaf spring?
I would find an 8 lug square body truck and swap out the complete front suspension/brakes/engine crossmember. I believe there are 14 bolts to remove the crossmember from the frame. You roll out the drum setup and then roll in the disc setup. You now have disc brakes and the higher quality ball joints. I sell these complete setups local in norcal for $100.
Six in a row makes it go...
![]() Join Date: Mar 2009
I have a '67 C20 that I'm thinking about converting in the future. I don't have any experience with the 3/4 ton conversion, but I keep this site bookmarked:
http://blackbirdscustomtrucks.com/index7.html
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
Scrapper 1
there is a lot of talk Now days in the front end swaps I'm hearing you can just take off the old drum brakes and swap a set of upper and lower ball joints tie rods and brake hoses and spindles.No need to touch the A frame
My C20 has coil spring, Corporate HO52 rear end, with 4.10 ratio. So I wonder what rear end would swap if I want to go different lug pattern?
Moderator
![]() Join Date: May 2007
Find a 71 or 72 1/2 ton donor truck for the disk brakes and the matching rear if you want to go 5 lug. If all you want is front disk brakes, get them from a 71-72 3/4 ton truck and you can keep 8 lugs all the way around.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
