01-15-2012, 12:28 AM | #1 |
Th400 u-joint size ????
Can somebody tell me what size u-joint came stock in a big block truck with a th400 trans ? 1310 or 1350
thanks bob
I BELIEVE IN JOHN 3:16 |
01-15-2012, 12:34 AM | #2 |
Has more rust than truck...
Re: Th400 u-joint size ????
More than likely 1350, but here is a link to the measurements.
http://www.driveshaftspecialist.com/...D%20Guide.html |
01-15-2012, 12:36 AM | #3 |
i dont have a shaft to measure off of.
01-15-2012, 07:53 PM | #4 |
The U joint is going to have to be matched to the yoke and driveshaft you use. If you have the yoke you can figure out what it takes by taking a couple of measurements and comparing them to a u joint size chart.
Note: the chart USMCChevy gave seems a lot easier to use than the one I gave below. This site gives you the dimensions and parts numbers for Spicer U joints. Get the Spicer number and you can cross it at any parts house but the Spicer brand U joints are worth hunting down. http://www.mdsdriveshaft.com/spicer_...sal_joints.htm You also need to know if your yoke and driveshaft have inside or outside snap rings. Preferably both pieces will have matching snap rings or it takes an extra cost U joint most of the time. |
01-16-2012, 02:42 AM | #5 |
guys i need to know what gm installed in "stock" bbc th400 drive lines.......
01-16-2012, 08:20 AM | #6 |
Hollister Road Co.
01-20-2012, 05:54 PM | #7 |
All are 1350 that I have dealt with
'11 Z71 '88 V-30 Crew Cab '87 V-10 '69 Camaro SS '52 M38 '46 Rat Rod Word of the wise should be sufficient! |
01-20-2012, 09:17 PM | #8 |
Thanks, i got me a new 1350 slip yoke for the trans and a good 1350 drive shaft and new precission u-joints. Now its time to decide on what rear axle i,am gonna run. Sstock 12 bolt, 9" ford or dana 60. Leanning towards the 60 as i have a power lok for it.
07-01-2012, 09:13 PM | #9 |
~Rest In Peace~
the dana 60 would be my first choice
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
