Drive Shaft Diameter?
The sub originally had a driveshaft whose diameter was about as big as a soft ball, however picking up a junkyard driveshaft off a 3/4 ton truck to get a pinion that one had a diameter of about a base ball. Sub was a one piece, truck was a 2 piece.
Is there a difference in strength or an advantage of one over the other? |
#2 | |
![]() Join Date: Dec 2010
Re: Drive Shaft Diameter?
Newbee
For long shafts they use larger diameter for the rigidity over the span. The smaller diameter shafts are usually thicker wall for strength. Both will work, as long as the span isnt too long.
Thanks.. Guess I will wait til i get the trans in and measure... leave it up to the drive shaft place..
