Old 01-16-2012, 07:19 PM   #26
LakeAnna
LakeAnna's Avatar
Re: 72 Not sure what to call it yet resto!
Been working pretty hard here the last week on the truck. I got the frame done today. I pressure washed, wire brushed, grinder, da sander etc... pressure washed, degreased again and final washed. Put it in the booth on jack stands and you know the rest. I used SEM rust shield and it seems to be a nice finish. My only issue was not having a larger tip for the gun. We usually use a 1.8 for all the primers or even a 1.5. This stuff is just so thick I had a heck of time getting it to flow with the 1.8
If I use it again I will have a 2.2 for it for sure.
My cab supports as you can tell need attention and all four arrived this evening on the brown truck.... Not looking forward to tomorrow with that.
Just got off the phone with Mark at ECE 4/6 drop is shipping out tomorrow.
Chris-
What do you guys think I should spray on the bottom of the cab? Use the SEM?
Chris
72 RESTO
http://67-72chevytrucks.com/vboard/s...d.php?t=501870
LakeAnna is offline   Reply With Quote
Old 01-16-2012, 07:25 PM   #27
dmwphoto
dmwphoto's Avatar
Mark with ECE is a great guy to deal with and the products are top notch
dmwphoto is offline   Reply With Quote
Old 01-16-2012, 07:52 PM   #28
67c10rustbuket
67c10rustbuket's Avatar
nice work, Thats definately a good way to pick up and move the frame !
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 01-16-2012, 08:35 PM   #29
LakeAnna
LakeAnna's Avatar
Heres is one shot. I been trying to upload some pics but it keeps saying the securtity token is missing???? WTF
Chris
72 RESTO
Old 01-16-2012, 08:52 PM   #30
VA72C10
VA72C10
VA72C10's Avatar
Looks great! Security token missing means the pictures are too large. Try re-sizing them or you can upload them here to the gallery and link them here to the thread.
Old 01-16-2012, 08:58 PM   #31
LakeAnna
LakeAnna's Avatar
Thumbs up Re: 72 Not sure what to call it yet resto!
One more of the frame... And the the rear drivers cab support which is average for what they all look like. I guess it's not to bad though because they are solid further in toward the brace that runs long ways under the floor.
I got the oem type replacements that I plan to start on in the morning.
Chris
72 RESTO
Old 01-16-2012, 10:47 PM   #32
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Great looking project Chris!
What did you paint the frame with?
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 01-17-2012, 01:32 AM   #33
VA72C10
VA72C10
VA72C10's Avatar
Originally Posted by LakeAnna View Post
I got the frame done today.I used SEM rust shield and it seems to be a nice finish.
Frame looks good out in the sun
That support's pretty common....the inners look pretty good overall though from what I can see in that picture....
Old 01-17-2012, 07:42 PM   #34
LakeAnna
LakeAnna's Avatar
The lift is great to have around needless to say... I used it today to take the cab around back for some sandblasting. Just as I was about to start my father showed up and decided I needed to help him on the 36 he is restoring.
The weather is supposed to be decent tomorrow I hope to get the bottom of the cab blasted and along the drip edge/rain gutter or whatever on the roof.
Anyone, what type of sealant is used in that seam after I get it cleaned up?
Chris
72 RESTO
Old 01-17-2012, 07:51 PM   #35
VA72C10
VA72C10
VA72C10's Avatar
Can't search for it now but I believe it's a 3m two part. I know BMERDOC tried some on his and wasn't thrilled with the results...try searching seam sealer on the board or FAQ's...
Old 01-20-2012, 08:57 PM   #36
LakeAnna
LakeAnna's Avatar
After three days and lots of grinding welding and well you know...
Chris
72 RESTO
Old 01-21-2012, 05:40 AM   #37
LakeAnna
LakeAnna's Avatar
Cool Re: 72 Not sure what to call it yet resto!
The picture up above doesn't do the bottom any justice really. It turned out pretty decent I still have 2 coats to spray this morning (total of 3) using SEM 38101. I was able to get an elcheapo hvlp primer gun with a 2.3 tip and the stuff flows great through that. In the pictures you can see I repaired the cab corners by cutting out the rot and welding in the new pieces as needed.
This next pic is from Thursday evening when I blasted the top and around the gutter. Not to bad I guess. I have a few small pieces I hope to weld into that today and get it primed with utech etch primer for now. Do most of you just weld up the small holes like in the pic and use a fiber filler of some sort? I've got some Mar hyde fiberstrand that should do well for most of it after the welding. Sorry the pics just didn't come out to well up top. What do you think? Any suggestions or comments welcome??
Chris
72 RESTO
Old 01-21-2012, 05:43 AM   #38
LakeAnna
LakeAnna's Avatar
Found some! Although I'm still a ways from needing it yet...
Chris
72 RESTO
Old 01-21-2012, 03:47 PM   #39
scotts72heavyhalf
scotts72heavyhalf's Avatar
Great progress on your build.
Scotts72C10
scotts72heavyhalf is offline   Reply With Quote
Old 01-25-2012, 06:57 PM   #40
LakeAnna
LakeAnna's Avatar
I don't know how great it is Scott but I feel like I am making some progress. Thanks for the parts BTW...no thanks to the USPS of course
Here is what I've been up to for the last few days: I welded up the holes along the gutter on the cab... man was that a job. No matter what I did I always seemed to be chasing the weld it was so thin in spots. Anyway I got it! I cut two patterns and welded up the firewall and the antenna hole. Working on the cab until I can get it primed and moved aside.
UPS came with everything from ECE!!!!
Slow and steady I will get this thing...
Chris
72 RESTO
Old 01-25-2012, 07:05 PM   #41
LakeAnna
LakeAnna's Avatar
Talking Re: 72 Not sure what to call it yet resto!
couple more and parts truck...
Chris
72 RESTO
Old 01-28-2012, 06:52 PM   #42
LakeAnna
LakeAnna's Avatar
My friend James who is an excellent body man came over and gave me a hand today with the cab!!!
I have a few little spots in the door jambs to hit with 320 and then I can shoot the cab and it's ready. Here are a couple shots... of course the camera died before I could get a pic of it finished this afternoon.
Chris
72 RESTO
Old 01-28-2012, 07:10 PM   #43
VA72C10
VA72C10
VA72C10's Avatar
Somehow I missed the last few updates. Went from rusty to done since I last checked in! WOW! Great work!
Old 01-28-2012, 07:29 PM   #44
doubleb's69
doubleb's69's Avatar
Did you spray or brush the frame? It looks great and so does all of the rest of the progress.
Bud
doubleb's69 is offline   Reply With Quote
Old 01-28-2012, 09:46 PM   #45
TXPinstriper
TXPinstriper's Avatar
3M seam sealer or 5200 Marine Sealant will work fine and paint will adhere to it when its dry...
TXPinstriper is offline   Reply With Quote
Old 01-29-2012, 12:45 PM   #46
LakeAnna
LakeAnna's Avatar
VA72C10 thanks for the kind words! I still need to catch up with you sometime...
Double D I sprayed the frame and it was a little tough getting it to flow through the primer gun. We have a Devilbis startingline primer gun with a 1.8 tip. Usually that gun works great but with the SEM rust shield it was a little to thick. With that being said though... It covered very well just not as slick as regular urathane or something. I like the finish it has and it seems like a nice tough coating now that it has cured. If I had to do it again I would use the same thing with a different tip or maybe get the thinner they sell for it.
TX.... Your truck is nice!! Got the sealer deal all figured out. Funny I have used lots of 5200 on boat transoms in the past. Good stuff, tough as *%^^!
Chris
72 RESTO
Old 01-30-2012, 11:32 AM   #47
flatfoot77
flatfoot77's Avatar
If you want to go back to the original colors my 71 is Hawiann blue and white, I bought my truck already done take a look i get a lot of compliments on it.I see your truck has ralley wheels to me they look better than anything else just my personal opinion Good Luck
flatfoot77 is offline   Reply With Quote
Old 02-04-2012, 05:52 PM   #48
LakeAnna
LakeAnna's Avatar
I've been working on the cab and the fenders the last two days. James our body guy came today and got my "rough work" all nice and straight! Actually he said i didn't do to bad... Anyway this is where I am as of today.
Take a look:
Chris
72 RESTO
Old 02-04-2012, 06:03 PM   #49
LakeAnna
LakeAnna's Avatar
As you can see James had to cut all the paint off the hood... It's so thin there is no way I would blast it. I ordered the pads to replace and plan to urethane it to see if we can stiffen it a bit. Any thoughts on that? Anyway here is what I left an hour ago.
Chris
72 RESTO
Old 02-04-2012, 06:13 PM   #50
fencepost
fencepost's Avatar
I like K36 that is some great stuff. Just wondering if they had changed the receipe up any. It use to would stick to everything, over spray, which was good, but it was hard as a rock when it dryed. Very hard to sand. Still loved it for a sealer or trim out primer, good product. DP 90 black epoxy is real good too. truck's looking good.
What acid etch primer are you using?
fencepost is offline   Reply With Quote
1972 c10, 510 medium blue, cheyenne super, fastburn, lake anna
