01-16-2012, 10:34 PM | #76 |
Re: 67-72 Chev Crewcab Build
Been another long day, spent most of the day getting the skin on and re-assembling the door, installing the door handle, so on and so forth. Now I've just have little touch ups here and there. The inside of the door is painted, seam sealed and rubber coated.
Well I had to try, after I failed I decide to call my friends down at the glass shop, $50.00 a piece...sold.
Randall Cowboy the 70' Crew Cab The DUKE K50 Crew Cab 2nd gen build thread Drill Sergeant The Ponderosa |
01-16-2012, 11:14 PM | #77 |
GEARHEAD
You made this look way too easy. I know it wasn't. Good luck with the sale of these things.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
01-17-2012, 01:08 AM | #78 |
Junk Yartist
looks awesome! Jealous!
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
01-17-2012, 01:31 AM | #79 |
Nice Skills!!
1972 K5 Auto 4x4 factory air 2007 Silverado extended cab Z71 |
01-17-2012, 01:38 AM | #80 |
VA72C10
Very nice work!
Looking for a 67-72 swb or blazer project in or around VA. |
01-17-2012, 01:26 PM | #81 |
67cheby
Looks killer !
01-17-2012, 05:17 PM | #82 |
6>8 Plugless........
Awesome job, stinks about the window breaking!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
01-17-2012, 05:55 PM | #83 |
Love crew cab builds!! Can't wait to see more!!
01-19-2012, 11:44 PM | #84 | |
Still plays with trucks
After seeing your Craig's List ad for Suburban parts it got me thinking about building one myself. I would definitely like to drop buy and check out what you are doing. Feel free to put me to work. Both me and a fellow 67-72 nut from work live in the same part of town you do and would like to drop by some time.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
01-29-2012, 12:07 PM | #85 |
Well been busy building a jig for production. I have started another cab, this cab will be built differently than the last. I have had an outside source make solid 6' long rockers, double the thickness and also had some other pieces vital to building crewcabs made double the thickness, will be showing pictures of those after I pick them up. I will say that having these rockers made intially was very expensive but something I consider to be crucial to producing a high quality crewcab.
I will probably be showing more pics than on the last build more specifically how the rocker will be integrated into the body. The B pillar will mount to the top of the rocker instead of going through it, in all cases this cab will be structurally stronger. As for today I will be dismantling a 69' deluxe for the donor cab and selling the rest of the parts on craigslist. Will have pictures later today until then have a great day.
01-29-2012, 12:29 PM | #86 |
A320 Pilot/USAF Retired
Awesome build, thanks for sharing all the details!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
01-29-2012, 01:36 PM | #87 | |
Junk Yartist
02-01-2012, 12:26 PM | #88 |
Have started new crewcab project that is already shaping up to be a really good build. There will be some new improvements on this cab such as the new 6' rocker panels that will have vertical reinforcement panels inside and the B pillars will mount on top of rocker panels instead of dividing them. All rocker panels and B pillars will be coated on the inside to prevent rust. The 6' long rocker built with thicker metal and combined with vertical panels within should make for a much stronger rocker panel and cab structure.
I have also had the upper rails made in 6' lengths so that there will be no splicing of roof channels. Rockers will be for sale - checkout the website later this week.
02-01-2012, 12:30 PM | #89 |
67cheby
Nice work on the rockers !
02-01-2012, 09:09 PM | #90 |
Great Progress, from the last time I checked in. I can't wait to see more.
02-01-2012, 09:21 PM | #91 |
Awesome developments. I'll be checking out your rockers for sure!
02-01-2012, 09:39 PM | #92 |
Project collector
Nice fab work. Subscribed!
Steve
69 CST-10 SWB (disguised as a 67) 383/700r4 Jezebel Jezebel 3.0 NEW!!! 2020 GMC 3500 Denali Duramax 2016 Harley Street Glide CVO Roll Tide! |
02-02-2012, 12:00 AM | #93 |
Great work! You should have been around 40 years ago doing these conversions.
Name: Les ---------------------- Couple 80s Couple 70s One 68 |
02-02-2012, 12:29 AM | #94 |
Junk Yartist
Sweet deal about the rockers! you better believe that I will check that out! Can you tell me a little more about the center of the roof on your first cab on the roticerie in the back? Is it a hand fabbed piece?
02-02-2012, 04:09 PM | #95 |
Way Cool!
02-02-2012, 07:58 PM | #96 |
"Well I had to try, after I failed I decide to call my friends down at the glass shop, $50.00 a piece...sold."
How are you going to retain the small section of glass in the door that you had cut? Thanks |
02-02-2012, 08:02 PM | #97 |
The same way it was befor, just a different shape
02-02-2012, 08:19 PM | #98 |
thanks Les 40 years ago I was learning thet wat goes up will come down hard and brak wat ever bone reaches the ground first.
02-02-2012, 08:19 PM | #99 |
Ok, I'm needing the same glass for a pair of doors I have that were custom made before I got them and was wondering what holds the glass in there, if they just ride in the felt or if there is clips on the inside of the door itself?
02-02-2012, 08:27 PM | #100 |
OK, I am useing the same rubber thet held the glass in befor. I am speaking of the rubber that came out of the suburban fixed glass.
