Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 01-18-2012, 11:46 AM   #1
Mattman2010
Mattman2010's Avatar
Sound Deadening
I have an 84 crew cab that I need to install some sound deadening into. I'm not sure if this is the right section to post this so it needs moved feel free to move it. What is the best kind of sound deadening to use to kill engine noise? I have a bunch of noise coming through thr firewall and I am not sure what to use to kill the sound. I have been looking at dynamat and dynapad but they both seem to be more high frequency noise killers and vibration noise killers. So what would be my best thing to put under the dash and maybe firewall to help kill the engine noise?
Thanks, Matt
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Mattman2010 is offline   Reply With Quote
Old 01-18-2012, 02:13 PM   #2
jimmydean
jimmydean's Avatar
Re: Sound Deadening
Dynamat helps vibration, too. I did a double layer on my firewall of peel and seal then the same pad I used under the carpet. My engine is pretty loud, but you can't hear a thing now.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 01-18-2012, 09:27 PM   #3
Willie496
Re: Sound Deadening
We just completed our 71 GMC cab with FatMat. We used it under the dash, firewall, floor, behind the gas tank,cab corners, and the doors.
It's still in the rebuilding stage so we have not had a chance to test it for sound deadning. It is real easy to work with.
Willie.
1969 GMC 4x4, 4 speed, 350 Fleet Side in progress.
1969 Camaro SS 427 Cortez Silver. owner since 1974
1964 Chevelle 4 Door, 427 Big block,Turbo 400
1/4 Mile 10.52 @ 125.85 mph. 1.39.1 60'
1982 Crew Cab 3+3, 2WD 3.21 Locker, 468/4 speed
1969 C30 4 speed (IL6) future build.
Willie496 is offline   Reply With Quote
Old 01-19-2012, 06:02 PM   #4
tubbedII
needs more $$$
tubbedII's Avatar
Re: Sound Deadening
I went with this company (http://www.raamaudio.com/) for my sound deadening products.
I don't really have any experience with any deadening products, and haven't even installed any of this yet, but it's supposed to be the best bang for the buck which I'm always looking for.
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 01-22-2012, 04:51 PM   #5
GMR-PERFORMANCE
GMR-PERFORMANCE's Avatar
Re: Sound Deadening
Back a long time ago I did installs for a custom shop. What I found was that unless you are going to enter a sound off, most sound mat will work just fine. I have covered my floor and fire wall on the 62. Inside the doors I used a spray in type, the doors get funny with heat and it can fall off if the surface is not spotless etc. Easier to do some some doors than others.
I am using it to keep the out side noise ... out side ha ha . Single application on floors is fine add a heavy under carpet jute and you will be amazed at how much noise is reduced.
GMR-PERFORMANCE is offline   Reply With Quote
Old 03-19-2012, 09:14 AM   #6
made2drag
made2drag's Avatar
Re: Sound Deadening
im with jimmydean...Peel And Seal from lowes in the roofing section it comes in rolls about 8 inches wide and 20 foot long if i can remember right. its like dynamat and has a aluminum piece on top. it works
made2drag is offline   Reply With Quote
Old 03-19-2012, 10:04 AM   #7
pockets
pockets's Avatar
Re: Sound Deadening
There are different levels of sound deadening. Do you just want to prevent vibration and rattling? then the sticky stuff (dynamat, etc) covers that. If you want road noise, etc. then you need more than that, i.e mass loaded vinyl, foam, etc.. I'm personally going with SDS.
I priced out doing my entire cab and doors in my 87 for about 300, and that is including going up into the dash area.
Project Bad Karma
pockets is offline   Reply With Quote
Old 03-19-2012, 01:05 PM   #8
vegas80step
vegas80step's Avatar
Re: Sound Deadening
I ran Stinger Road Kill over every inch of my cab.. new carpet with full pad.. new rubber seals..
It REALLY made a difference...
I drive a lowered Chevy, a lifted Ford and I have a 62 VW bug stripped down in the garage.
Which "Piss on" sticker do I buy?
vegas80step is offline   Reply With Quote
Old 04-04-2012, 02:19 AM   #9
oldspowered67C10
Re: Sound Deadening
Theres 3 steps to sound insulation, damper(dynamat, fatmat etc.), isolator(foam, jute etc) and barrier(mass loaded vinyl). I used dynamat directly on the panesl and bought some insulation from McMasterCarr that was mass laoded vinyl glued to 1/2" foam. Its not cheap but its easy to install and works well.
oldspowered67C10 is offline   Reply With Quote
Old 04-29-2012, 11:55 PM   #10
dukcaln
dukcaln's Avatar
Re: Sound Deadening
did mine today, went to home depot bought two rolls of self adhesive foam duct insulator and a roll of aluminum seam tape and here was the final look. cost me $50 bucks. Rolls we $18 each and tape was $8
It was easy to work with, cuts very easy with a blade and souns so much better...
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP
SOLD 1972 chevy c10
dukcaln is offline   Reply With Quote
Old 04-30-2012, 09:18 AM   #11
Mattman2010
Re: Sound Deadening
Hey guys thanks for the ideas. Truck is on hold for right now as I had a little fire (trucks fine just gotta replace a brake line) and so I pulled it off the road and going to start a cummins swap. These ideas should help me figure out what I want to do about the sound deadner. I got some dynamat left over that I might just use in the doors and get some of that stuff from lowes or home depot and use that on the floor.
Build Thread
Build Thread
Thread
Old 04-30-2012, 10:09 AM   #12
dukcaln
dukcaln's Avatar
Re: Sound Deadening
the stuff from lowes works good....also the cummins swap is great. my buddies got on in his truck and that thing is awsome
SOLD 1972 chevy c10
Old 05-04-2012, 10:35 PM   #13
crsweet91
crsweet91's Avatar
Re: Sound Deadening
I used edead because the cost was low. Not as thick as dynamat. I think the problem with the stuff from hardware stores is its tar based unlike dynamat which is butyl rubber. Not sure If its the best option even with the cost being so low.
crsweet91 is offline   Reply With Quote
Old 05-05-2012, 07:44 PM   #14
dukcaln
dukcaln's Avatar
Re: Sound Deadening
stuff I used from home depot was not tar based. it was foam self adhesive. worked like a champ
SOLD 1972 chevy c10
Old 05-05-2012, 08:05 PM   #15
crsweet91
crsweet91's Avatar
Re: Sound Deadening
So it was actual foam mat with self adhesive. Do you have a link, Id like to check it out for the price you payed.
Old 05-05-2012, 10:28 PM   #16
dukcaln
dukcaln's Avatar
Re: Sound Deadening
stand by
SOLD 1972 chevy c10
Old 05-05-2012, 10:33 PM   #17
dukcaln
dukcaln's Avatar
Re: Sound Deadening
http://www.homedepot.com/h_d1/N-5yc1...&storeId=10051
here you go. worked really very well and the difference in the cab is amazing.... was so easy to cut with a blade and was easy to shape and mold over the hump and all around the cab. 2 rolls was perfect for the floor and if you want to go up the side and rear of the cab then 3 will work but 4 to be safe
SOLD 1972 chevy c10
Old 07-25-2012, 11:02 PM   #18
odee
Re: Sound Deadening
for the guys that doubled up on the dynamat fatmat on the firewall area did it make a big difference? I have gotten my cummins swap done and started driving it some would like to make it a little quieter. thanks
odee is offline   Reply With Quote
Old 07-26-2012, 11:17 AM   #19
tubbedII
needs more $$$
tubbedII's Avatar
Re: Sound Deadening
I'd go with multiple layers of different material.
1st a typical dynomat type, then a dense foam, and then your typical stock firewall foam with the cardboard face. Doing that and sound deadening the rest of the cab should be sufficient.
1970 2wd Blazer
Old 07-28-2012, 06:05 AM   #20
oldspowered67C10
Re: Sound Deadening
There is no point in doubling up on something like dynamat, theres really no point in having 100% coverage for that matter. Dynamat really blocks very little sound, its for panel dampening not blocking sound. All its supposed to do weigh down the panel so vibrations from outside dont vibrate the panel and making it act like a big speaker. Really, with a quality product like dynamat extreme, 50% coverage is usually enough to get all you can out of it.
Old 08-07-2012, 12:45 PM   #21
gramps77
Re: Sound Deadening
True story, more is not always better. I went with Damplifier Pro in my standard cab 77. Its DEAD quiet now.
Also may want to look here.
http://www.soundsolutionsaudio.com/f...ener-showdown/
gramps77 is offline   Reply With Quote
Old 08-15-2012, 03:20 PM   #22
Lost81c10
Lost81c10's Avatar
Re: Sound Deadening
all,
i was wondering, for all of you that have done it, if this was the only material you used between the carpert and the cab floor? if so how is it working for heat shielding purposes, if not what else did you use for heat shield.
thanks.
AB
Lost81c10 is offline   Reply With Quote
Old 08-15-2012, 05:26 PM   #23
jimmydean
jimmydean's Avatar
Re: Sound Deadening
I did peal and seal, then pad, then carpet. Did it for sound (cab is dead quiet now) not heat.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
