Old 01-18-2012, 06:13 PM   #1
herbert
85 carb ?
Have possible carb promble crank drive about 1/4 mile and cut off to re start have hold peddel to floor. Have air cleaner off and a lot of gas around front carb. This truck has what I call electric carb wire running to top. The number on side of it is 1708 5236 not sure of 3 1525 HLY. Now I have another carb was told it came from Z28 the number on it is1708 3204
1603 FRB does anbody know what these code mean. this is a 305 h modor thanks.
herbert is offline   Reply With Quote
Old 01-18-2012, 07:24 PM   #2
beamn7
Re: 85 carb ?
When you say gas around the front of the carb, you mean on the outside of it? Possible that the float level is off or the float is saturated and not stopping the flow of fuel at the needle and seat causing it to flood and stall.... When was the last time it was overhauled? I'd pick up a kit from the local auto parts and do an overhaul on it. Fairly cheap....
beamn7 is offline   Reply With Quote
Old 01-18-2012, 09:02 PM   #3
84chevy4x4
84chevy4x4's Avatar
Re: 85 carb ?
sounds like the choke isnt opening all the way. my quadrajet carb does that when its cold. the choke falls shut.
1984 Chevy K20 work in progress
1977 Chevy C30 Dump
1979 GMC 35 4x4 Dump
1969 GMC 1500 Rat
84chevy4x4 is offline   Reply With Quote
Old 01-19-2012, 01:44 PM   #4
jimboh247
jimboh247's Avatar
Re: 85 carb ?
The '85 carb has an "extra" accelerator pump. That's what the plug on top is for.
The 17083204 is an '83 Chevy automatic trans carb. The extra numbers are date codes.
I feel your pain. I'm not a mechanic by any means, and carb work might as well be witchcraft. I'm going thru carb issues right now too! You need to find an old timer mechanic that has actually worked on a carb for any help in my area.
'85 SWB Silverado
jimboh247 is offline   Reply With Quote
Old 01-19-2012, 04:12 PM   #5
OleBlue79
OleBlue79's Avatar
Re: 85 carb ?
I'm no carb mechanic but I am getting close to old timer status. If it's a Quadra jet they are know to leak a little around the the top of the carb. Just the gasket "seeps" a little. Just enough to keep the top and front of the carb kind of moist. No real problem. Second, the way you say it's acting I would replace the fuel filter.I had one once that I could drive it for 4 to 5 miles are so and then it would slowly die out. After it sat for a couple of minutes it would fire back up and go some more. Replaced the fuel filter and it fixed the problem. If it's a clear filter don't look at it and think enerythings fine if you don't see any trash or sludge. Just go ahead and replace it and try that.
One other thing about Q-jets. The fitting where the fuel line screws into the carb will sometimes strip the threads or will eventually start leaking where someone before you has cross threaded the part. There is also a small fule filter inside that fitting. Take it out and throw it away and install a fuel filter in your fuel line.
79 C-20 Scottsdale 350/400 3:73 gears 9 leafs and a headache rack (I speak English, thank you)
OleBlue79 is offline   Reply With Quote
Old 01-19-2012, 04:14 PM   #6
OleBlue79
OleBlue79's Avatar
Re: 85 carb ?
If the threads turn out to be stripped, you can buy a self taping fitting from the Help! section at your auto parts store. I bought one from O'Reilly's.
