Old 01-18-2012, 08:34 PM   #1
lucifer
lucifer's Avatar
Cool 4WD to 2WD
Anyone know if 2WD and 4Wd frames are interchangable?
thanx
65 burb On the road Mar 26th Finally
lucifer is offline   Reply With Quote
Old 01-18-2012, 08:47 PM   #2
duallyjams
duallyjams's Avatar
Re: 4WD to 2WD
The frames are different but you can convert a GMC 2wd to 4wd the GMC already have leaf spring rear or if you want to convert a 4wd to 2wd that would be easy just remove the front spring hangers and bolt in a 2wd cross member then just remove the factory lift blocks from the rear and loose the transfer case .
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 01-18-2012, 11:11 PM   #3
tripleD
tripleD's Avatar
Re: 4WD to 2WD
the frames are close to the same i changed 2wd frame to 4wd and left the trailing arms in the rear just for flat track mud racing.A days job piece of cake.
triple d
tripleD is offline   Reply With Quote
Old 01-19-2012, 02:46 AM   #4
Captainfab
60-66 Nut
Re: 4WD to 2WD
The K series frames are deeper from the front of the cab to the rear where the frame starts to curve up. They also don't have the kick out in the frame where the coil springs would be for a C series truck.
