01-21-2012, 12:49 PM | #1 |
80 dual Vbelt alt pulley on my Buick V8
If I put on two belts like it had stock, it squeals all the time, if I just have on one belt, it will only squeal on take off for a sec or two. Both annoying All looks linned up proper, tight as can be, tired of the noise peroid; and having to turn off say like the heater fan before I take off at night with lights on so it does make noise. Anyone ever run into this???
Chevy GMC Trucks Find Of The Day https://www.facebook.com/ChevyGmcTrucksFindOfTheDay or http://ChevyGMCTrucks.com |
01-21-2012, 07:36 PM | #2 |
Dino burner
Re: 80 dual Vbelt alt pulley on my Buick V8
I've run into that when the belts I was using were mismatched.
By "mismatched" I don't mean they were different sizes; what I mean is that they were from different batches, and therefore slightly different. If you look on the outside surface of your belts, you'll find the part number / size code (such as 13A540), plus there will be another number that is like a date code or batch code. When you buy 2 new belts, try to get them from the same batch. That will help ensure that they are made of almost exactly the same rubber composition and length. When they make V-belts, they don't make them just 1/2" wide -- they're actually a couple of feet across, and then they are "sliced" into 1/2" width sections. So, if the batch code is the same, then both belts would come from the same large, original belt. Hope that helps. |
01-22-2012, 12:14 PM | #3 |
Ill have to try that, Im tired of feeling those invisible eyes judging my car maintenance when I forget to shut off an accessories before a stop at night to lower power demand and it squeals like a lose or crappy belt is installed.
03-13-2012, 07:27 PM | #4 |
The mystery is solved, some reason is they sell two belts for it, one is just 1in longer.
easily mixed up I bet. Made sure with their belt measure tool I got two alike, fingers crossed it works out.
