Old 01-21-2012, 02:04 PM   #1051
taank
Re: Make it handle
Originally Posted by Grimee View Post
Raising the arms in the cross member will change the amount of anti squat and the pinion angle. the springs will set the ride hight
so you would have to shim the axle to put back to angle
taank is offline   Reply With Quote
Old 01-21-2012, 02:39 PM   #1052
Grimee
Grimee's Avatar
Re: Make it handle
If it needs to be shimmed you can, but do it after you get your ride height set
Grimee is offline   Reply With Quote
Old 01-22-2012, 12:21 AM   #1053
hairlesshobo
hairlesshobo's Avatar
Re: Make it handle
Originally Posted by robnolimit View Post
TO ALL USING URATHANE Drill the outer sleave and install your own grease zerk fittings in EACH bushing. Use poly-graphite grease. We dont want them to flex, but we do want them to rotate easily. CAUTIONThe inner steel sleave of the bushing shoud be as long as the urathane parts. When the bolt is tight, it should torque up onto the inner sleave, NOT crush the urathane bushing sides. MANY MANUFACTURERS dO NOT GET THIS. it is up to you to check. If there not right, don't use them.
I hate to bring up a (really) old post..
Rob, any chance you could go into this a little more? Were you referring to control arm bushings? If so, any chance you have a pic of what it looks like once this is done?
Next weekend I plan to move the lca forward 1" to gain much needed caster and I ordered an energy suspension poly bushing kit. I want to make sure I do it right the first time.
Steve
Shawty: '84 C10 Silverado SWB, 700r4, SBC 350 - 4 bolt main, bored 60 over w/ Weiand aluminum intake and moderate cam, 2" true dual exhaust, Thrush mufflers, 3.42:1 gears -- Build Thread
The Tranny (wrecked ): '86 Trans Am, SBC 350 (now in above truck), Borg-Warner T-5, 2" true dual, Thrush mufflers, 2.73:1 gears
hairlesshobo is offline   Reply With Quote
Old 01-22-2012, 12:46 AM   #1054
Skellington
Re: Make it handle
The discussion of the antisquat is very interesting to me.
Where would you calculate the IC on a 4 link or 3 link set up? would you take the average of the the front's top and bottom bars?
Skellington is offline   Reply With Quote
Old 01-23-2012, 10:37 PM   #1055
hgs_notes
GEARHEAD
hgs_notes's Avatar
Re: Make it handle
Just thinking out loud here, but wondering if its possible to convert the trailing arms to a solid mount link, then just add another pair triangulated from beside the differential going forward and outboard the current trailing arm mounts. Double triangulated 4 link, no track bar.
hgs_notes is offline   Reply With Quote
Old 01-24-2012, 12:23 AM   #1056
Midniteotto
Midniteotto's Avatar
Re: Make it handle
Well... I picked up a 69 frame last week, and have been really trying to figure out how I wanted to start this thing... Subscribed to learn stuff!!
Midniteotto is offline   Reply With Quote
Old 01-24-2012, 05:04 PM   #1057
robnolimit
robnolimit's Avatar
Re: Make it handle
here's a bushing drawing. The inner sleave should be slightly noger than the urathane. If you are buying the Energy kits, they get it right. This is a good test of aftermarket parts. At a show, you can look at the bushings in a manufacturers A-arms, or rear bars, if the sleave is short, the parts are sh!#.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 01-24-2012, 05:12 PM   #1058
Conundrum
Conundrum's Avatar
Re: Make it handle
Hey Rob, have you figured out how much is a good amount to lower the upper A-arm mounting points on the 60-87s?
74 GMC SWB Project "Sin-thia" Static Dropped 8"f/10"r
http://67-72chevytrucks.com/vboard/s...d.php?t=460030
97 GMC reg cab short bed, 4.3V6 / 5spd, daily driver
220,000 miles, all stock for now
Conundrum is offline   Reply With Quote
Old 01-24-2012, 08:29 PM   #1059
robnolimit
robnolimit's Avatar
Re: Make it handle
working on it.
Old 01-24-2012, 09:17 PM   #1060
gofastnut
gofastnut's Avatar
Re: Make it handle
TMI! TMI! Wait, what am I saying?!?! Need more input!!
Thanks EVERYONE for their input, 'specially Rob, who flat out ROCKS with his wealth of knowledge and willingness to share. This separates a good forum from a FANTASTIC one!
Jeff
96 C3500 Crew Cab Long bed (Waiting on Cool Name)
64 C-10 shortie stepside, "Ole Brownie"
C-10 Club
My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345
gofastnut is offline   Reply With Quote
Old 01-25-2012, 12:06 AM   #1061
gringoloco
A guy with a truck
gringoloco's Avatar
Re: Make it handle
working on it.
Sweet. Curious how this would combine with the caster mod...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 01-25-2012, 01:27 PM   #1062
Conundrum
Conundrum's Avatar
Re: Make it handle
working on it.
Thanks Rob
Old 01-27-2012, 10:23 AM   #1063
aggie91
I'm just glad to be here!
aggie91's Avatar
Re: Make it handle
Rob, I know that this picture is not one our your products, but can you explain why this is better/worse then say a panhard bar that is just from the driver side frame mount to the passenger side trailing arm, that is level at ride height?
http://www.hotchkis.net/_uploaded_fi...639image_5.jpg
To me, it looks like the upper bar and the driver side bracket just stiffens and lowers the driver side mount.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 01-27-2012, 10:27 AM   #1064
hairlesshobo
Re: Make it handle
I assume this only applies to the older trucks (72 or older), right? My bushings look nothing like the above picture is why I ask.
Old 01-27-2012, 10:58 AM   #1065
jmlcolorado
Re: Make it handle
Looks to me like this drops the drivers side mount so the bar is level at ride height. Then the other stiffens the mount.
Looks like a pretty good setup.
jmlcolorado is offline   Reply With Quote
Old 01-27-2012, 12:42 PM   #1066
jmlcolorado
Re: Make it handle
It also looks likt the mount on the drivers side.... bulk head i'd guess you call it, it mounted with a bracket on the frame, then a bolt. Without the top bar supporting it to the poassangers side, the vertical mount would sway and take the axle with it.
I would think it would have been better with a 1 piece solid mount on the drivers soide, then keep the brace in place to help avoid frame twist with heav side load.
But im no engineer
Old 01-27-2012, 01:21 PM   #1067
robnolimit
robnolimit's Avatar
Re: Make it handle
No problem, this is the Panhard kit included in the Hotchkis TVS kit. The idea here is to lower the Roll Center. Lowering the RC can help to increase the loading of the outside tire in a corner. This will also tend to increase the body roll. So, the addition of a rear sway bar is more important. On the Hotchkis kit, the upper bar is a brace for the lowered mount on the drivers side, to stop it from flexing or twisting the rails. The lower bar is the panhard rod, or locator, and the mount on the trailing arm is on the drivers arm, down low.
Old 01-30-2012, 01:07 PM   #1068
jimmydean
jimmydean's Avatar
Re: Make it handle
He is a question for you, Rob.
My '66 long bed will be running Nate's C4 front and back half. i know in the truck, the the CG is much higher than it is on the donor C4, so the handling suffers there. i also know the weight distribution is bad due to it being a truck, especially a long bed.
But to get the most, my idea is to mount the fuel cell between the rails as far back with the batteries on either side of the frame rails. With my tank and compressors just forward of the fuel cell just behind the rear axle centered in an Accuair eXo hidden under the bed as low as possible.
Or should I mount it closer to the cab in front of the axle for weight? Thinking front to back weight distribution, I am using the LT1 and 4l60e out of the donor C4 as well. Know that I am not looking to autocross this truck, just want it as fun to drive as possible on the street.
<edit> The donor is so damn fun to drive, but the seats are better in the truck.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 01-30-2012, 04:41 PM   #1069
robnolimit
robnolimit's Avatar
Re: Make it handle
I know you may hear about the rear 'swing' effect of weight if you move it too far behind the axle. - dont worry about it. Make sure it's safe. With the tank, keep it a bit forward of the rear crossmember, just incase you get into an accident. Move everything you can, every little bit helps. Even think about shifting the motor/trans to the pass side 3/4", for side/side balance. should be a fun driver
Old 01-31-2012, 12:06 PM   #1070
jimmydean
jimmydean's Avatar
Re: Make it handle
Awesome, thanks Rob. Sounds like I should do the fuel tank behind the axle, then the air tank and compressors furthest aft. In the event of an accident, the air tank is less likely to explode vs the fuel cell.
Now I am fully giddy with anticipation.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 02-01-2012, 12:24 AM   #1071
Matt R
Matt R's Avatar
Re: Make it handle
I've gotten some more done on my project. I'm guessing its almost time to move on to a 3 and/or 4 bar discussion in this thread.
My build thread http://www.67-72chevytrucks.com/vboa...d.php?t=494247
Matt R is offline   Reply With Quote
Old 02-01-2012, 01:59 AM   #1072
ItsRandy
ItsRandy's Avatar
Re: Make it handle
Hey Rob...any news on the 67-72 Chevy c10 rear sway bar like the one on JT? Are they ready for sale yet?
ItsRandy is offline   Reply With Quote
Old 02-01-2012, 03:03 PM   #1073
robnolimit
robnolimit's Avatar
Re: Make it handle
This is a side view of a basic 4-bar, or three link. We'll start here. Upper bar, lower bar, these are each mounted on the axle, and on the chassis. This is a SIDE VIEW only, to start the conversation. These pars push and pull to apply force to the chassis. The amount of force, and direction of the force would be a 'Vector', but we will keep it simple. For now, it is the center of each mounting point that we are interested in.
Old 02-01-2012, 03:04 PM   #1074
robnolimit
robnolimit's Avatar
Re: Make it handle
from the side view, if you draw a line through the mounting points, and farther forward, the upper line and lower line will cross. This intersection is the 'Instant Center'. A line from the Contact center through the Instant center will cross the CG line, and tell you where the Anti-squat is. Look at this for a while, and you will see that there are all sorts of ways to change the IC, and Anti-squat.
Old 02-01-2012, 03:06 PM   #1075
robnolimit
robnolimit's Avatar
Re: Make it handle
I'm gonna hear it for this one. From the side view, if the bars are parallel, there is NO Instant center. No I.C. means 0% Anti-squat. These are the 4-bars you see on roadsters and others. They look cool, but no hook & book.
Next, Side view of Triangulated 4 bar will also point to the I.C. These are more difficult to adjust. remember the Moroso "hop-stop" kit for A body chevy's? It raised the rear top mount of the Triangulated 4-bar on a chevelle. This moved the I.C. bach, and the A.S. up the scale.
