Any options on upgrading wiper motors?
My wiper motor finally died today, in a blizzard 10 miles from home-of course. I have a couple others-pending bench-testing to see if they work-but are there any other options for a better set-up than stock? It always seems like the stock motors are too slow. Maybe because they are 40+ years old, but still. Just wondering.
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Any options on upgrading wiper motors?
These guys have been making wiper motors for just about everything, for a long time.
Made right here in Missouri. https://www.newportwipers.com/produc...7-72&make_id=2
Now that's exactly what I'm talking about. Thanks, lolife99 for that link. I'll have to use one of my stock units while I save up some wiper motor money, though.
poor glass maintenece and neglected linkages cause slow wiper atm travel lots of times
What cdowns said clean and lube all the linkage and clean the glass real good does wonders for wiper operation
Fuzzy |
![]() Join Date: Feb 2007
What do you guys recommend for a cleaning procedure and lubrication on the linkage?
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
![]() Join Date: Jan 2006
There are a couple of aftermarket systems I've seen here on the site. One of the nicer systems was in a Kevin Lewis' (RokCrln) Low Buck Truck build. Here's the thread: http://67-72chevytrucks.com/vboard/s...d.php?t=223158 But, you'll need to scan through it to see the specific information for the wipers (it's 50 pages on my computer).
don "The DRBMan" 2014 Audi A4 (The Wife's Daily Driver) 2017 HD Ultra (The Cruiser) 2003 HD Fatboy (The Ride) 2001 Chevy Suburban (Another back up!!) For the first time in forever, not a single 67-72 Chevy truck, Blazer, or Suburban on the property! Basically retired and getting the new Motorhome ready for some traveling. Doing a bit of work on the house getting it ready to sell! LOL!! |
cleaned my window and waxed the glass, lubed the linkage and wow, it was 3 times smoother and 2 times faster... works wonderful know...
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP SOLD 1972 chevy c10 |
#9 | |
(from Newport Engineering) http://67-72chevytrucks.com/vboard/s...223158&page=50 Quote: Then I moved on to the new wiper set up. Talk about an easy up grade to do in an hour or two. It now has a intermittent setting that goes from about once every 15 sec to once a second and a half and anywhere in between. The it also has low and high speed that is more up to date with todays speeds. The system came ready to bolt in and just plug together BUT I had to change things up a bit for my tastes. After following the very simple instructions I had the motor installed and test fit the 2" cube wiper switch. I noticed the shaft extension that was on the switch was a bit loose once I installed the switch so I pulled it off and used lock tight on the threads for good measure. Then I also noticed the pig tail extension they give to plug it all in was not needed with my truck so I figured I would just not use it so I could avoid any extra wire under my dash but when I pulled the pig tail out I found that both the motor and the switch had the same male spade terminals so it would not plug into it self. So I just cut off the spades from the switch end as close to the spades as possible because I could not afford to loose much length off the harness. Then I just put on new female spades and added some heat shrink tubing to it and it was ready to install. The after running a ground and acc. Hot lead it was complete. If you drive your truck in anything but perfect weather I highly recommend this up grade from NewPort engineering!
Exactly what is the advantage of using an aftermarket wiper motor over the original? I never knew anything was wrong with mine. They do what wipers do. I rarely use hi at all. I have never had a wiper motor fail on me. Now,washers? That's another story...about the opposite.They never work in any of my trucks. The only improvement I'd want is intermittent wipers.
does this motor have a washer pump attached or do you have to use a aux unit?
Maintain (clean/lube) your stock system. Then go to Wal*Mart or similar and buy a bottle of RainX. I put it on EVERY car I own. It works so good you can drive in rain or snow without wipers as it beads the stuff up and sends it sailing.
It also is nice for scraping ice off your windows like I will be doing this afternoon. The coating or whatever it does to your glass makes a surface that the ice doesn't stick real well to. I don't work for RainX.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
