#126 |
Re: Crash's 72 K10
Thanks Mike.. I am trying to get caught up with you.. :-)
Mark ----------------------- Crash's 69 4x4 SWB Crash's Roof over Lake Home Crash's 1988 Land Cruiser Build |
#127 | |
Re: Crash's 72 K10
Thanks... I hope so....
#128 |
Re: Crash's 72 K10
Looking better and better, what size exhaust are you running, lots of room for it. I have 3" on my 71 4x4, pretty tight in some places but works, need it for the Big block. Nice temp, here it is -17c on a warm day, was -36c last week for almost 3 days, rather rough. it's getting closer to spring though.
#129 | |
Re: Crash's 72 K10
2 1/4" is what is on there now.. I will go with 2 1/2" when I take it to the muffler shop... The weather here has been very mild.. It was 68 Friday...
#130 |
Re: Crash's 72 K10
I will start my resto on my 72 K10 SWB stepside within the next month or so and wanted to thank you for posting so many pics. They surely take the guess work out of alot that I want to do to mine. Keep the pics a coming!!! Great work and awesome truck!!!
#131 |
Re: Crash's 72 K10
Thanks... Sometimes I worry that I post to many pictures... Hope what I have done so far helps..
#133 | |
Still Learning
Re: Crash's 72 K10
![]() Nice progress Mark! All the custom hard lines look better than factory. Diggin the dobber exhaust too. |
#134 |
Re: Crash's 72 K10
#135 | |
Re: Crash's 72 K10
True..... Thanks for the comment on the lines.. I am not 100% happy with them, but they will work... ![]()
#136 |
Re: Crash's 72 K10
On the frame you used POR15, can you spray it or do you have to brush it? Are you happy with the results? It seems as if that paint offers a good long lasting protection, just not wanting to brush it if possible. I have used a brand called "Master Series" before with much success just havent used POR15. Your comments will be greatly appreciated.
Link to my 69 Camaro 6.0/T56 swap: http://ls1tech.com/forums/conversion...69-camaro.html |
#137 | |
Re: Crash's 72 K10
#138 | |
Re: Crash's 72 K10
#139 | |
Re: Crash's 72 K10
Good luck on finishing up your current project and moving forward on the 72.
#140 |
Re: Crash's 72 K10
#141 |
VA72C10
![]() Join Date: Mar 2008
Re: Crash's 72 K10
Frame is looking great! Nice work!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#142 |
Re: Crash's 72 K10
Thanks... Soon I will have to start on the cab.... wish me luck..
#143 |
Still Learning
Re: Crash's 72 K10
Nice work on the wiring diagram. You know you're going to have to show me how to do my fans. Thanks again for the O2 sensor connector and install
#144 |
Re: Crash's 72 K10
I am very impressed. How many builds have you done? I am in the process of my second restoration, but I can tell you know what you are doing. Just the idea of installing a LS engine is daunting. Thanks for all the pictures and the knowledge you are passing on.
Here is mine http://www.flickr.com/photos/waltspr...7628925019747/
I know I can! I know i can! 72 K20 Restoration |
#145 | |
Re: Crash's 72 K10
This is my first build... I have done a lot of mechanic work in the past (long ago) and a couple of engine swaps.. So I am learning as I go... this forum and the people on it are great resources... I would not be this far along without them…
#146 |
![]() Join Date: Oct 2011
Re: Crash's 72 K10
Hey Mark, your cooler lines looked great!! I was wondering where you got your wiring diagram??? (I'm a little concerned)
Wade ![]() , JUST WALK AWAY, AND I'LL SPARE YOUR LIVES!!! , Build thread "TANGERINE" http://67-72chevytrucks.com/vboard/s...d.php?t=498570 Board Members Met: bigblock68, ol_skool_chevy ,68TT,atvpro |
#147 |
Re: Crash's 72 K10
It's alive...!!!!!!!!!!!!!!! Hooked up the PCM. powered up the fuse panel.. hit the starter.. started right up.... sounds good..
#148 |
Re: Crash's 72 K10
Thanks fakerwade.. Which wiring diagram.. the one in showing my fuse box and relays? It is something I created based on the factory wiring diagram.. What is you concern?
#149 | |
Re: Crash's 72 K10
#150 | |
Re: Crash's 72 K10
Thanks fakerwade.... I could very well have things wrong.. However, in this case I think I am right. After review the wiring diagrams and the fuse box itself the orange wires (Blue Pin 20 and Pin 57 - Circuit 440) uses a 20 amp fuse. I agree it seems large for memory retention as well.. But I thought it best to follow what the factory did. On the fuel pump, I was surprised with that as well.. The fans circuits work by the PCM taking the pins to ground. However, the fuel pump outputs 12V+.. Not sure why they did it that way... Once again thanks... and please let me know if you spot any other issues..
