Old 01-22-2012, 01:15 PM   #1
mrhino
Is my hitch set up strong enough
Hey Guys Im putting a hitch on my project. First the hitch I have was not made for this truck. Second the truck use to have a hydraulic lift on the back. The only thing left of that is a extension made from tubing welded to the bottom of the frame. It used to be a rectangle tubing but we had to cut a section off with a torch when removing the lift.
After I cut the mounting tabs off of the hitch(didnt align anyway). The hitch fits nice and snug againt the inside of the outside wall of the tubing. My question is: If I drill holes bolt it with four 1/2 bolts on either side would it be strong enough to pull, lets say a car trailer safely? the tubing does appear to be welded very well and all the way around. If you don't think it would be safe why and what should be change to make it so. thanks for your input
mrhino is offline   Reply With Quote
Old 01-22-2012, 01:41 PM   #2
stroker87
Re: Is my hitch set up strong enough
good question?
can you show where you cut the hitch, I'm sure you can get it to work might have to do some welding though?
how much weight would you be pulling?
stroker87 is offline   Reply With Quote
Old 01-22-2012, 10:00 PM   #3
yousesteers
how thick of a wall is that extension tube if it is heavy enough I would bolt it up using grade 8 bolts and if it was mine I would probably weld it also.
Clint Youse
Paris, MO
1984 Chevrolet 3+3 K30 with Cummins
1966 IH Scout has been a work in progress for 16 yrs
yousesteers is offline   Reply With Quote
Old 01-23-2012, 06:54 AM   #4
mrhino
Originally Posted by stroker87 View Post
good question?
I dont have any pics of what i cut off, but what I cut off was just the mouting tabs. they were little L shaped tabs at the top so it would slide between the framrails.There were two on each side
the hitch is 1/4 and the frame extension piece is 3/16. I was going to use 3 1/2 grade 8's and a one 3/4 gr8 going through that big hole with a spacer to tie it into the other side. and last clean up that area that was cut with torch and weld that to the hitch.
Old 01-23-2012, 07:25 AM   #5
MalibuSSwagon
I would say that your plan sounds solid. I have 4 1/2" grade 8 bolts holding on my hitch, of course mine is meant to fit a 73-87 and used pre-existing holes in the frame. I have been towing cars for 3 years with mine, no wear noted.
MalibuSSwagon is offline   Reply With Quote
Old 01-23-2012, 11:20 PM   #6
yousesteers
I would say do if you do it like you are talking your frame will break before that hitch comes off most are held on with a lot less than what you are talking
Clint Youse
Paris, MO
