Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 01-23-2012, 02:23 AM   #51
69GMC910
MOTORHEAD!
69GMC910's Avatar
Re: Engine?
This car is an iron headed (781 I think) 496. It's making 657hp and 675tq. It's a daily driver.
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Performer RPM Air Gap
Hooker 2455's
TCI Turbo 400 Super Street Fighter
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Hoosier 30x10.5 Radial Slick
Full weight long box pickup
Current best- 11.33@117mph
69GMC910 is offline   Reply With Quote
Old 01-23-2012, 12:36 PM   #52
redsled87
redsled87's Avatar
Re: Engine?
Originally Posted by Super73 View Post
Randy,
Numbers from the 60's and 70's were rated differently than todays motors.
The L88 and old school LS7 were more or less all out factory race motors. Look at todays little C6 ZO6 motor that is 427ci making every bit of 505hp from the factory. Smooth idle, runs vacum brakes, weighs less.. With a set of headers and a cam swap, they have been known to make over 600rwhp on pump gas.
Tony Mamo from AFR recently made 730+hp on an engine dyno with a 454ci LS motor. This was a 91 octane drinking hyd roller motor.
I mean really, things could be argueed for days on this.
I still haven't seen a rough cost for an NA high 11/low 12 second big block in a 36-3800lb truck.
4-5 years ago I remember driving around my buddies big block 69 truck wearing aftermarket heads, decent sized cam with 11-1 compression, converter, gear and tire. I was only running 12.30's in my truck then. He gatted me by 2-3 cars do to my lack of traction, went by him before the 1/8 and strapped close to 5 cars on him. Similar results with a second pass. My guess is it was a high 12 second truck at best.
Now I know DJ's old motor would have drove around me.. But what would that motor take to replicate in todays market?
I'll have around $4700 in my 496. I'm hoping to run low 12's with it. Although, I'm going to have to baby it this season until, I upgrade the rear to a 9".
1987 R10 Pump Gas 496/TH375
Best 1/4 pass to date
60' 1.49
1/4 10.93
MPH 120
redsled87 is offline   Reply With Quote
Old 01-23-2012, 01:12 PM   #53
Super73
Super73's Avatar
Re: Engine?
Thank you for the honest example.
You can get an ls2 with trans and harness, put headers on it, put a cam in it, add injectors and get it tuned. For about the same amount.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 01-24-2012, 01:48 AM   #54
Bad70sbchevy
Bad70sbchevy's Avatar
Re: Engine?
That's the price for a used motor right?
1970 Chevrolet C-10 w/355sbc
2010 Silverado Daily Driver
1971 Mercedes 280sl project car
Bad70sbchevy is offline   Reply With Quote
Old 01-24-2012, 11:05 AM   #55
ripdog28
ripdog28's Avatar
Re: Engine?
Originally Posted by Bad70sbchevy View Post
The reason they run rat motors in Pro Stock is because the motors have to be NA, thus a need for bigger cubic inches to make power and I'm pretty sure they don't run turbo 4 cylinder motors in NHRA Pro Stock last time I checked but I can be wrong. You can make a lot more power with a turbo big block than a 4 cylinder, but trying to hook up all that power is another story...
You are correct, i miss spoke about the Prostock class. However, there are many 4cylinders in other NHRA classes making well over 1500hp.
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 01-25-2012, 01:41 AM   #56
redsled87
redsled87's Avatar
Re: Engine?
Yeah, the LS engines are cool but, you can get more torque out of a BBC than an LS from the articles I've read. My 496 also is going to have, forged Scat crank and I beam rods as well as, forged SRP pistons for a grand total of $1700 for the rotator kit.
60' 1.49
1/4 10.93
MPH 120
Old 01-26-2012, 10:57 PM   #57
BigDan3131
BigDan3131's Avatar
Re: Engine?
Usually when they don't list the price, it costs too much.
I dug around after reading that and if memory serves that motor was about $80k and they offer a 1000 cid version now that can be had as a street motor for a nice $100-120k.
BigDan3131 is offline   Reply With Quote
Old 01-29-2012, 10:49 AM   #58
Vortecpro
Re: Engine?
In regards to 69 910 GMC, I could see no problem with a 700 HP pump gas 496 running very easily into the 10s in the same conditions you run your LS in with power adders. Mid eighties 1/2 ton, 4000 pounds, 3.50 gears, pump gas normally aspirated hyd roller 700 HP 496 driver, 10 sec truck at Sacremento easily, heres an honest example of a 9000.00 power plant.
Vortecpro is offline   Reply With Quote
Old 01-29-2012, 09:45 PM   #59
Super73
Super73's Avatar
Re: Engine?
I would hope a 496ci motor would run as good as my little 347ci motor did on a 100 shot, it has 150ci on it. Now as my cubic inches get closer to that 496 mark (418ci) I would suspect I would need less bottle.
Again, I am not saying you can't make big power on the BBC platform. With any NA motor, if you have comprable heads for the ci (flow enough for the ci), the right cam and combo, a bigger cube motor should make more power, period. I just see too many bad big block combos to be an advocate of the big block craze. I'm not drinking the cool aide, but then again a lot of you big block guys aren't drinking the LS cool aide.. To each his/her own. That's what makes this sport fun!!
Old 01-29-2012, 10:50 PM   #60
Vortecpro
Re: Engine?
Just maybe you should consider drinking some of the coolaid, because that light weight, big tired truck of yours just might see some 9 sec NA passes, and still work the power brakes, 238@.050 hyd roller.
Old 01-30-2012, 12:07 AM   #61
Super73
Super73's Avatar
Re: Engine?
If I put a big block in it, it wouldn't be light weight anymore at some point I will change the combo, go with a solid roller in hopes to go 9's. And please correct me if I am wrong, and I do respect his truck, but I believe dj never went 9's NA with his big tired big block truck with less weight than me.
Old 01-30-2012, 12:12 AM   #62
Vortecpro
Re: Engine?
Dont know DJ, 9s NA.
Old 01-30-2012, 07:40 PM   #63
kwhite4
Junior Member
kwhite4's Avatar
Re: Engine?
I went 9.8o's with number one rod trying to come out...and my truck is all steel no power adders. The best motor for him is what he can afford and what he is comfortable working on. IMO
68 GMC
565 BBC
Abruzzi super pro glide
9.85@135.00
kwhite4 is offline   Reply With Quote
Old 01-30-2012, 09:55 PM   #64
GMR-PERFORMANCE
GMR-PERFORMANCE's Avatar
Re: Engine?
I look at what an engine can make per cube. that 496 is making 1.44 per cube,.. very nice ,..a 376 CI LS engine will make 1.46 very easy.
I have owned BB, SB and yes the LS as well. Dollar for dollar you can not beat them ,... facts are what they are.
If I did not have the parts I had from the 383 that went south. I would have went LS all the way.
There was a great write up a while back on a 6.0 that they bought a cheap stroker kit and went at it.
Heres the link,http://www.carcraft.com/techarticles...d/viewall.html
now take that same bone yard engine that you start with say 1500 bucks another 1500 in the stroker kit, swap the cam intake carb, ign and you are making well into the 575-600 range and all in money wise you can spend about 5000-6000 buying all new parts and have a engine that makes killer power is is extremely tough and will still handle the juice for the extra power
I built a el cheapo 413 stroker for the junk yard engine. With some looking around we where able to pick up a few used parts here and there. Once done with a E bay pro form carb and PP intake it laid down 612 hp that 1.48 per cube. Total budget 4100 bucks.
Gotta love a BBC for running on 7 TOO funny
GMR-PERFORMANCE is offline   Reply With Quote
Old 01-31-2012, 12:15 AM   #65
djracer
djracer's Avatar
Re: Engine?
My junk was not built to run Normally Aspirated. My motor was not a good combo. I wanted to upgrade cylinder heads and I knew I wasn't gonna keep the smaller Big Block so I bought way too much head for a 468 so it was a pig on the Motor. I used to run 9.20's at 143 mph N/A with the same short block and a better combo in a 2800lb car that was a little more aero dynamic than the truck. My truck may still not be back together anytime soon. (issues on the home front) But the new motor should run low 9's N/A with the right convertor. I'm know the tight nitrous convertor will slow it down but to be able to spray a 300 to 500 shot it will have to have it.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 01-31-2012, 01:23 AM   #66
Super73
Super73's Avatar
Re: Engine?
Kevin, I hope you weren't thinking I was bagging on your truck, not at all. Your truck has always impressed me. I used you truck as an example as it is/was lighter than mine, more cubes etc. It's not as easy to go 9's let alone 10's NA in one of these trucks, yet some make it sound like they grow on trees.
Old 01-31-2012, 01:45 AM   #67
bigboybodry
bigboybodry's Avatar
Re: Engine?
"JUNK" Are you crazy man? That thing was flying brother don't let anyone tell you otherwise just post up that vid link you don't have to say anything. for a tight converter and nos cam it was riding on motor too. 75% or more people on here would die for that setup.
Sorry to hear about the home front and truck delays! lord knows I have been there. If I can help I am just sitting on the couch recovering from surgery I'll take a road trip if need be.
first track pass with the new motor on motor http://youtu.be/YgrJaEF_TaQ
bigboybodry is offline   Reply With Quote
Old 01-31-2012, 08:19 AM   #68
djracer
djracer's Avatar
Re: Engine?
Its all good. Just letting some know how far the combo was off from where it should have been. Hopefully we will at least get to play with Cade's truck if its God's Will. Any progress on Brackets?
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 01-31-2012, 08:45 AM   #69
Super73
Super73's Avatar
Re: Engine?
I haven't made any more yet. Hopefully will have time in the next month or so.
Old 01-31-2012, 09:26 AM   #70
Vortecpro
Re: Engine?
It would be VERY easy for me to run 10s with your type of truck on pump gas NA, of course Id do with a 9 inch tire LOL, and I dont think it would take more than my flattappett 467 to get it done, infact my friends 4900 pound 1 ton drive line, 35 inch front tires, slicks on the rear 6 inch lifted, 3.73 gears, 1800 RPM stall converter 70 short wide ran 11.40 into a 20 mph head wind @ Bakersfield with a 650 HP BB, theres a video out there somewhere, I will try and find it.
Old 01-31-2012, 11:05 AM   #71
Super73
Super73's Avatar
Re: Engine?
I would hope a 467ci big block would get my truck in to the 10's. It would be rather sad if it didn't. You should go in to the big block building business and show some of these other cats how to make some power. Again, I am not saying big blocks can't make power.
Old 01-31-2012, 11:13 AM   #72
GMR-PERFORMANCE
Re: Engine?
DJ that is a killer ride, Not junk from what I see..
I understand how hard it is to get to those time. Thumbs up in my book
Old 01-31-2012, 12:03 PM   #73
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Talking Re: Engine?
Teehee..............
You fellas have a little Outlaw 10.5 Blood in ya....
Just let it out and go all out!
PLR 670ci 4000+ HP - Pro Line Racing Engine
http://www.prolineracing.net/
This is what 1Bad wants to be..........Fast Freddy
But for now I currently running Poor/Street Class - (Poe/Street)
(Poe/Street class is for the high class fellars & thier trucks.
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 01-31-2012, 05:33 PM   #74
ripdog28
ripdog28's Avatar
Re: Engine?
Incase some of you dont know, Vortecpro, Mark Jones, is in the BBC business. He ports old iron that have flow numbers equal to or better then AFR CNC ones. He knows what he is doing.
69 c-10 BBC
Old 01-31-2012, 06:04 PM   #75
1Bad62Pro/Street
Exclamation Re: Engine?
Most of you fellars are in the CA area or out west, but if anyone is located in SC or NC area.
Gene Fulton of Fulton Competition is one of the best engine builders around.
Fulton Competition specializes in large cubic-inch aluminum Chevrolet engines and custom nitrous systems.
CHEVY ONLY RIGHT
http://www.fultoncompetition.com/Ful.../About_Us.html
http://www.shop.synergycafe.net/mm5/...re_Code=fulton
From Street Racers, Nitrous Quick-8 and 10-inch Tire to Sportsman and Pro-Modified, Fulton Competition constructs custom engines that lead every racer to the Winner’s Circle.
Everytime I'm in there I just love to druel over those massive Big Blocks......
820 cubic inches...Can I touch it fellas... 1Bad it's time to leave.
