Old 01-25-2012, 10:00 PM   #1
tbrown5079
Mounting the computer in a LS swap
Time to start on the electrical part of my LS swap into the cameo. For those of you that have done this, what did you use to mount the computer and where? I'm thinking on the left inner fender under the brake booster but should I leave it out in the open? Anyone get the mount from another vehicle or aftermarket?
tbrown5079 is offline   Reply With Quote
Old 01-25-2012, 10:09 PM   #2
Tuck
Re: Mounting the computer in a LS swap
just asked the same question. I am doing a twin tubo 4.8 in a 56.
Tuck is offline   Reply With Quote
Old 01-25-2012, 11:53 PM   #3
Kim57
Kim57's Avatar
I'm putting an LS2 in my 57 and I'm going to do my best to get it inside the cab behind the seat. If that doesn't work then possible under the dash.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 01-26-2012, 12:56 AM   #4
cajundragger
mine is under the drivers feet under the cab.
grab a 2001+ s-10 computer mount. It has a clip setup that locks onto the computer and provides 3 mounting holes.
i'll see if i can get a picture of mine...
cajundragger is offline   Reply With Quote
Old 01-26-2012, 01:12 AM   #5
cajundragger
bam
Old 01-26-2012, 05:53 PM   #6
tbrown5079
Another problem solved by the great people on this site. Can't we all get together and drink too much beer sometime? Thanks
Old 01-26-2012, 06:42 PM   #7
OKGMC4
OKGMC4's Avatar
I ran the wiring through the floor on the passenger side and it will be under the seat in my 56. I'm going to mount the ALDL and light under there as well.
56 GMC BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=368649
69 long bed Chevy turned 67 gmc jimmy roadster:
https://67-72chevytrucks.com/vboard/...d.php?t=851167
OKGMC4 is offline   Reply With Quote
Old 01-27-2012, 04:42 PM   #8
code4
You can put them just about anywhere, they are very weather resistant. they are in the engine compartment on chevy p/u's.
On my turbo panel I ran the wire through the trans tunnel & up the firewall. I removed a couple of the factory cover screws and attached angle iron, then attached to firewall.
code4 is offline   Reply With Quote
