Old 01-26-2012, 02:28 AM   #1
gracy
1960 mirror holes
Hi Iwas trying to find a measurement where the original mirror holes been. the previous owner had filled them in. I would like to put stock mirrors on the doors. thanks
gracy is offline   Reply With Quote
Old 01-26-2012, 10:06 AM   #2
1963c-10
1963c-10's Avatar
Re: 1960 mirror holes
If you take off the inner door panel, you should be able to reach inside and feel the support plate for the mirrors. I used a spring punch once I located the plate and then drilled from the outside. You will find a support brace on the passenger side also.
1964 Short bed trailer
Old 01-26-2012, 02:26 PM   #3
gracy
they put the bolt in the holes. that why I need a good loction on holes to drill and tap
Old 01-26-2012, 02:48 PM   #4
1963c-10
1963c-10's Avatar
See if this helps. This is from the passenger side. Driver side was in sun and pics were bad.
Old 01-26-2012, 02:55 PM   #5
markeb01
Senior Enthusiast
markeb01's Avatar
Welcome to the forum. Posts #7 & 14 on the following thread should help you out. Also note 1960-63 mirror brackets are generally parallel to the body line. 64-66 are usually at an uphill angle as shown in the following photos:
http://67-72chevytrucks.com/vboard/s...irror+template
Old 01-26-2012, 03:18 PM   #6
TopFuel1966
TopFuel1966's Avatar
The mirror mounting holes in my drivers side door were plugged also. I sanded the surface down to bare metal which exposed the circular break lines of the three plugs. I drilled the plugs out and chased the threads in the captive nuts. I then made a template from some thin cardboard and used the reverse image on the passenger side door to locate where to drill the holes.
TopFuel1966 is offline   Reply With Quote
Old 01-26-2012, 04:51 PM   #7
1963c-10
1963c-10's Avatar
Cool, glad you were able to complete it. I was going to suggest buying the gasket or tracing the bottom of the mirror for a template.
Old 01-26-2012, 05:21 PM   #8
11echo
On another project car I had, I had the same problem! What I did was take a large piece of paper and trace the pattern of the mounting flange on the mirror (outline only) ...then I cut that out. I then went to another car like mine, positioned the paper so the cut-out outline was around the mirror on the car. Then with a pencil I marked on the paper the edges of the door. Obviously the paper was large enough to do at least 50% of the door. I then put the paper back on my car, taping it in place, then put the mirror in the cut-out hole ...again with the pencil, I marked where the holes would be. Worked like a charm for me, I think I was right on in one hole and maybe 1/16" off in the others. ...Good Luck!
11echo is offline   Reply With Quote
