Old 01-26-2012, 02:19 PM   #1
K98AL
K98AL's Avatar
235 dual carb questions
I have a strong 235 in my '62 - I'm thinking about getting a dual carb setup.
I am running Fenton headers, so I don't have any heat riser, are there any dual setups that address this?
Also, if I do go to the dual setup, what changes do I need to make to the two 1-barrel carbs?
Any experience with these? Thanks for your help!
K98AL is offline   Reply With Quote
Old 01-26-2012, 02:35 PM   #2
c10hevy
c10hevy's Avatar
Re: 235 dual carb questions
I did this on my '52 and I got a plate with fittings for coolant to run through the heat riser. It takes a little bit longer than the exhaust to heat up but works fine after warming up. I know that Tom Langdon sells the coolant plate and also has 2 holley 2 bbl from a ford fiesta or focus that are supposed to be the best setup to make power. Id definitely check langdons stovebolts out.
c10hevy is offline   Reply With Quote
Old 01-26-2012, 02:50 PM   #3
1963c-10
1963c-10's Avatar
Yeah...Tom Langdon is the man with L6 mods
1964 Short bed trailer
