Old 01-27-2012, 10:41 AM   #1
Eyegore
What Hump?
Eyegore's Avatar
Anyone ever remove trans & transfer case by themselves?
I have to pull a turbo 350 & transfer case. I've done it before but not by myself. Can it be done? I'll be using a floor jack trying to balance the trans and transfer case, the truck will be sitting on the ground, no jack stands, seems to be enough room. But in reality can I do this myself? Have any of you done it alone under the same condtions. By the way the last time I pulled a transmission & tc was some 20 years ago.
And I know the transfer case weighs some 250lbs or seems that heavy.
Tom
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
Old 01-27-2012, 10:51 AM   #2
Dunenutt
Newbee
Dunenutt's Avatar
Re: Anyone ever remove trans & transfer case by themselves?
I do it all the time, but in two pieces. Do yourself a favor, and get a trans jack.
http://www.harborfreight.com/450-lb-...ack-39178.html
Cheap insurance, one slip may be your last.
Dunenutt is offline   Reply With Quote
Old 01-27-2012, 10:58 AM   #3
hairlesshobo
hairlesshobo's Avatar
I agree, if you can afford it, a trans jack will be an excellent investment for yourself. If you absolutely don't have the money for a trans jack, something I have done in the past is to use two floor jacks and a small piece of plywood.
Another tip, whenever pulling a tranny with a floor jack, make sure you have a 2x4 or something similar handy. You need to place something between the jack and the pan of the transmission or you're liable to crush the pan on the transmission.
-Steve
Shawty: '84 C10 Silverado SWB, 700r4, SBC 350 - 4 bolt main, bored 60 over w/ Weiand aluminum intake and moderate cam, 2" true dual exhaust, Thrush mufflers, 3.42:1 gears -- Build Thread
The Tranny (wrecked ): '86 Trans Am, SBC 350 (now in above truck), Borg-Warner T-5, 2" true dual, Thrush mufflers, 2.73:1 gears
hairlesshobo is offline   Reply With Quote
Old 01-27-2012, 11:09 AM   #4
Keith Seymore
Keith Seymore's Avatar
I always use my floor jack and just balance the whole affair on the jack pad. You can also use ratcheting "tie down straps" and make a sling from frame rail to frame rail crosscar, both as a safety feature and/or as and aid in getting it up off the floor and onto the jack initially.
I'm sorry guys, but I CANNOT reccomend the harbor freight trans jack. I have one of those and the scissor portion doesn't want to stay vertical - it will lean off to one side or the other and dump everything onto the floor. I've had a couple close calls and won't use it again.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 01-27-2012, 11:19 AM   #5
Dunenutt
Newbee
Dunenutt's Avatar
K
The tie downs work great for the tranfer case. It's an odd shape, and really a pain to jack up, and down.
Never had an issue with my jack( used 10 times or so). Maybe they cheaped out in the last 10 years. Mine is still tight, and I use an impact to raise and lower it
Old 01-27-2012, 01:09 PM   #6
JMS-1
JMS-1's Avatar
This might sound crazy but I have seen my dad use a cherry picker with a chain through the trans tunnel when he didn’t have a floor jack. It actually looked fairly easy.
1980 converted C30 454, 4 on the floor...
JMS-1 is offline   Reply With Quote
Old 01-27-2012, 01:39 PM   #7
67swb72klb
67swb72klb's Avatar
^ that does work out real good !
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 01-27-2012, 02:16 PM   #8
hatzie
Moderator
hatzie's Avatar
I welded a chunk of steel pipe that fit the floor jack saddle hole to the center of a 12"x12"x1/4" plate. I drilled 1/4" holes in the corners for tie straps. I used a second jack to stabilize the transfer case. I installed a 700R4 & NP208 in my 76 by myself with that setup.
Old 01-27-2012, 02:59 PM   #9
Eyegore
What Hump?
Eyegore's Avatar
JMS-1, HATZIE and all the rest those are some great ideas.
Thank you.
Tom
Lil red 86 c-10
99 Sub
Old 01-28-2012, 05:08 PM   #10
russgt
russgt's Avatar
+3 on removing the trans tunnel and using a cherry picker
70 stepside
76 blazer
86 Silverado
20 Max Trailering 6.2 Crew
71 Nova SS
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634
russgt is offline   Reply With Quote
