#1751 |
Re: PO has me PO'd
Trying to assemble theses parts next
![]() Seems that both jaws are not the same, will have to determine which goes where. Does not say anything about it in the service manual ![]()
#1752 |
GEARHEAD
Re: PO has me PO'd
Not sure it matters. All it does is provide the indent for where the pin goes for each position of the tilt. Thats why it's staggered like that. Should move and stop in each position regardless of which way you install them. I was trying to see if I had pics from when I assembled mine, but couldn't find them. But I really don't think it matters.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff |
#1753 |
Re: PO has me PO'd
Thanks for your reply, ill check it out. Maybe, ill pull the springs out, and see how it works
#1754 |
Re: PO has me PO'd
here ya go bud...they've never been out.....
#1755 |
Re: PO has me PO'd
Thank you for your time...saves me. Service manual says to use a soap based grease, think it matters
#1756 |
Re: PO has me PO'd
You're welcome..... glad to help. I pulled this off of Wikipedia .... "In the context of lubrication, grease typically applies to a material consisting of a soap emulsified with mineral or vegetable oil." So personally I don't think it matters.... I always use the same grease I use on my ball joints haha
Posted via Mobile Device |
#1757 |
Re: PO has me PO'd
Found it was easiest to clamp the bowl to a work surface, gave you two hands to start the retaining pin
![]() ![]() Not much to put the turnsignal switch in... Waiting on the bearings to come in from Wes, Classic Heart Beats. Thanks kean for getting me back on track with those photos
#1758 |
Re: PO has me PO'd
Finally got the brush guard ive been looking for
#1759 |
Re: PO has me PO'd
Nice guard there!
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
#1760 |
Re: PO has me PO'd
Found out that if you push in the two side tangs from the front, you can use the channel locks to press out the connecter. Luckily the tangs are not spring steel, so once you push them in, they stay in, so it makes it easier to extract them. Dont forget to bend them out when you are ready to install them
![]() You can just make out the two side tangs ![]()
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 02-13-2012 at 10:00 PM. |
#1761 |
Re: PO has me PO'd
Trying to figure out how to fix my heater control, seems that a number 4 screw would fit, so i can drill and tap. Used my dremel cutoff wheel to get rid of the burr on the rivet, now it will act as a alignment dowel. Just have to drill the center
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 02-13-2012 at 11:31 PM. |
#1762 | |
Back in the sticks
Re: PO has me PO'd
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
#1763 | |
Re: PO has me PO'd
![]() ![]() Actually, the master cruise switch looks like a dealer installted option, so i will be opting for the turn stalk switch....thought i could use both, but M&H says i cant Vacuum, that is another story. Was goning to use a air pressure gauge, for my compressor, but decided a vacuum gauge would be more usefull in keeping my foot outta the throttle....WOT Found it on the classifieds, so im guessing its stock
#1764 |
Back in the sticks
Re: PO has me PO'd
hehe, I think I may have mixed my metaphors or something. I meant was your cruise system a vacuum operated one...Do you have a vacuum guage too? I put one in my Blazer too, but still haven't figured out what it is telling me.
That stalk kind of looks like the one I have on my 71 pickup. Its a 73 and up aftermarket system that Sears used to sell. It ran off of vacuum and a magnet on the driveshaft for speed input. Mine has a slide on off switch too, though.
#1765 |
Re: PO has me PO'd
[QUOTE=jaros44sr;5186429]Found it was easiest to clamp the bowl to a work surface, gave you two hands to start the retaining pin
![]() ![]() Not much to put the turnsignal switch in... Waiting on the bearings to come in from Wes, Classic Heart Beats. Thanks kean for getting me back on track with those photos You are welcome sir....I try to give back what little I can to a forum who has helped me SOOOOOOO much.... ![]() Last edited by keanevann; 02-14-2012 at 11:16 PM. Reason: Cant spell |
#1766 | |
Re: PO has me PO'd
#1767 | |
Re: PO has me PO'd
[quote=keanevann;5189038]
#1768 |
Re: PO has me PO'd
Think ill paint it black
#1769 |
GEARHEAD
Re: PO has me PO'd
Not black, I'd have it powder coated a chrome or bright silver.
#1770 | |
Re: PO has me PO'd
Finish has to be brush/roll on, durable. Powdercoating is out right now, dont have access to a large oven, yet! ![]()
#1771 |
VA72C10
![]() Join Date: Mar 2008
Re: PO has me PO'd
How close is it to the rings/buckets? I'd think it would look better if it matches spot on or is black or bright silver like the trim.
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#1772 |
Hand Crafted C-10
![]() Join Date: Aug 2006
Re: PO has me PO'd
I vote for black.
#1773 | |
Re: PO has me PO'd
#1774 |
Too Dumb To Know Better
Re: PO has me PO'd
Nice guard. Do you want it to stand out or blend in? Black for the first and white for the second. I vote black.
#1775 | |
Re: PO has me PO'd
Maybe i should run a poll and let that answer my situation, dunno
