Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 11-08-2011, 04:06 PM   #176
kpeztruck
kpeztruck's Avatar
Re: post latest 1/4 and 1/8 mile times and 60ft.
Took mine to Steele this past Sunday. FIrst time for the truck at the track in 5 years. Could not get to run out the back with the too tight converter, and went 1.24 60' 5.61 at 123 mph in the 1/8. Coasted through 1/4 in neutral to a 9.52 et. lol Hope to figure out how to post some videos in the next couple days. Paul Baxter
kpeztruck is offline   Reply With Quote
Old 11-08-2011, 09:52 PM   #177
djracer
djracer's Avatar
Sweet Paul. I am glad you got it back to the track. I can't wait to see it run. I am sure you will get all the kinks out!
Which tire were you running?
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 11-08-2011, 10:25 PM   #178
68 C-10 KID
Mean Green
68 C-10 KID's Avatar
DANG! that's getting after it in the 60'.... wait yep just plain getting after it.
I have big block ENVY.
well done Paul.
427 SBC 683HP & 590ftlbsTRQ @ fly wheel.
60'-1.38 1/4-10.43 MPH-124.6
New ET current 4/2019
AKA MEAN GREEN.
68 C-10 KID is offline   Reply With Quote
Old 11-09-2011, 12:34 PM   #179
kpeztruck
kpeztruck's Avatar
Thanks guys, We have a lot left in the 60', i am hoping for 1.17-1.18 area, but on 28x10.5's. I had 29.5x10.5 tire on it Sunday. I will have to wait until spring to play again. I did not run the et that I wanted, but it was overall, very pleasing to get those #'s first time out, and bring it home unhurt! Paul Baxter
Old 11-09-2011, 04:30 PM   #180
bigboybodry
bigboybodry's Avatar
Thats getting it done, maybe one day I'll get all my bugs worked out. Great looking truck!
first track pass with the new motor on motor http://youtu.be/YgrJaEF_TaQ
bigboybodry is offline   Reply With Quote
Old 11-09-2011, 11:13 PM   #181
kpeztruck
kpeztruck's Avatar
i will attempt to load videos again, when I have more time. Failed miserably.
Old 11-19-2011, 02:11 AM   #182
moggey01
Paul just curious what your truck weighs?, and what the front rear percentage is now with the new front suspension. Your running 2 kits, have you seen anyone using Jeff Procks (Applied Nitrous Technology) new solenoids? They are really mean on 1 kit LOL. Guys around here love them with a nitrous controller on true 10,5s.
Mark
moggey01 is offline   Reply With Quote
Old 11-19-2011, 08:11 PM   #183
kpeztruck
kpeztruck's Avatar
Mark
Front should be about 53%, the estimate is based on the weight from before lowering the rear 2 1/2" and adding two full nitrous bottles. Prior to front suspension, and lowering the rear, it was 59% on the front. Truck weighs 3165# with 170# driver. I was only using one system when I ran the #'s above. Had .026 jets in one fogger, and still too fat on fuel. I have not spoken to anyone that has used Prock's solenoids, but will have to do some research, and asking around about them. I did not have a controller on mine, all on at the release of the trans brake. . Feel free to contact me with any questions. Paul
Old 11-20-2011, 09:55 AM   #184
moggey01
Paul, I cant get over how light your truck is. I basically have the same truck with a fleetside bed, and I figured it would weigh around 3600-3700 lbs. Im checking into acid dipping the cab,doors,and all front sheet metal, and leaving it in the tank a while LOl. I figured about 55% frontal weight. I was going to use a power steering pump ,A/C, alternator, and a vacuum pump. Did you move the engine back? It doesnt look like much if you did.
The guys with the Prock solenoids are using 50 pills on 1 kit. His new solenoid has a bigger inlet on it. It will make about 750 h.p. with that kit. With a controller they run 4.90s to 5.0s on the true 10.5 at 3480 lbs. Were going to try a drag radial with a car at minumum weight like that. Be interesting to see what it does.Thanks Mark
Old 11-21-2011, 07:47 PM   #185
kpeztruck
kpeztruck's Avatar
Mark, mine was 59% front weight with a cast block, aluminum head BBC, and stock front suspension converted to rack and pinion steering. Dropped to 54% after replacement of front suspension with chromoly tubular replacement arms, cross member, etc. Then should be less with rear lowered 2 1/2 ", and adding 2 full nitrous bottles in front of the tailgate. It still has all steel except for the hood, all glass except rear window, carpet, 2 seats, factory steering column. At this time, I do not have a bed floor in it, but am considering a 3 piece aluminum floor, and have wood hydrographics applied. I like the sericeability of the rear suspension, when there is no bed floor. I plan to make it removable with dzus fasteners. Hope this helps with any ideas to lose weight. The front suspension was the single largest weight loss, as it weighed 3410 before with driver. Paul
Old 11-21-2011, 10:18 PM   #186
Super73
Super73's Avatar
Paul,
You are making me want to spend the money on the front suspension.. I suspect I will be around 3,350lbs with me in the truck after the powerglide swap, backhalf/4-link, loss of my 125lb tailgate, and the addition of the cage. I know my 51/49 weight balance I had at 3,650lbs will be long gone.
But if I could get to 3,150lbs, I might be getting closer to the 9.9x NA goal I have set for 3 years
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 11-23-2011, 11:06 PM   #187
kpeztruck
kpeztruck's Avatar
Originally Posted by Super73 View Post
Paul,
I can't wait to see yours done, and making passes again. I know you are going to be getting close to your goal. I talked with my chassis man yesterday, and he is concerned about the amount we will be paying for some of the brackets to be mass produced. He wants to take time to do this, and it still be profitable, and fair to the customer. We do not want to exceed our price point. I hope to lay down some strong passes in the spring, and push the issue quickly. I know you will reach your goal soon. Paul
Old 01-28-2012, 01:30 AM   #188
H82LUSE
http://67-72chevytrucks.com/vboard/a...1&d=1318815485
Here's my numbers so far:
3925 LBS
All Motor
60' 1.254
330' 3.740
660' 5.829 @ 117MPH
990' 7.593
1320' 9.19 @ 145MPH
On 1 Stage
60' 1.213
330' 3.508
660' 5.450 @ 126MPH
990' 7.095
1320' 8.580 @ 155MPH
H82LUSE is offline   Reply With Quote
Old 01-28-2012, 06:54 AM   #189
69trk
69trk's Avatar
killer truck
http://67-72chevytrucks.com/vboard/s...d.php?t=494388
431 big block times, changed to a 6.0 ls with turbo
1.58- 60'
7.18- 1/8th mile@95.18
11.37- 1/4 @115.81
69trk is offline   Reply With Quote
Old 01-28-2012, 10:17 AM   #190
bigboybodry
3925 LBS
All Motor
60' 1.254
330' 3.740
660' 5.829 @ 117MPH
990' 7.593
1320' 9.19 @ 145MPH
On 1 Stage
60' 1.213
330' 3.508
660' 5.450 @ 126MPH
990' 7.095
THAT'S AWSOME!!!!!!! That thing must have a grown man under the hood?
Old 01-28-2012, 11:06 AM   #191
68 C-10 KID
Mean Green
Not only does that truck have a grown man under the hood it packs the tires and sets them down like its the most natural thing you seen!
AKA MEAN GREEN.
Old 01-29-2012, 04:18 AM   #192
H82LUSE
Thanks guys
The motor is a PAR 632 it is by far the best combo i have ever ran in the truck.
I am switching to a sheet metal manifold and dual 4s for this year, with any luck im hoping for 8s on all motor....
Old 01-29-2012, 09:44 AM   #193
djracer
djracer's Avatar
3925 LBS
All Motor
60' 1.254
330' 3.740
660' 5.829 @ 117MPH
990' 7.593
1320' 9.19 @ 145MPH
On 1 Stage
60' 1.213
330' 3.508
660' 5.450 @ 126MPH
990' 7.095
Sweet Looking truck tell us about the suspension and so forth?
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 01-29-2012, 03:02 PM   #194
H82LUSE
Up front I run a fat man fab front end with qa1 double adjustable coilovers manual rack strange rotors and calipers.
Out back is a dana60 with a set of outlaw triple adjustable ladderbars i made from 1 3/8 chromoly with single adjustable strange coilovers and a anti roll bar
It all fits in the stock rear frame rails with 33"x16"x15" hoosiers on centerline convo pro wheels.
Old 02-13-2012, 02:35 PM   #195
dinnut
dinnut's Avatar
70 c10.
469 BB. 10:1 with 088 rectangle port heads and a comp cams xm 278. 24-2600 stall th350 and a ford nine inch with 3.50 gears and a spool.28x12.50 et street bias ply. Untuned with a vac secondary 750 holley DP with a proform center section. First time running it at the truck. Running a strip dominator. Through longtubes and 3" exhaust with mufflers. 3rd run trans started over heating and slipping so i went home
13.55 @ 101.1
60 ft 2.019
RT .048
NEXT STEP... taking the strip dominator off for a Performer RPM Air gap. Was running the strip dominator because it was the only rectangle port intake i had at the time. Gonna play with the timing some and change the secondary spring.
I was happy I beat a c6 vette, a new 5.0 mustang on skinnies and drag radials and a new body style camaro ss.
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 03-04-2012, 05:57 AM   #196
moggey01
How wide is the rear end housing {housing end to end} and what back spacing are on the wheels of your truck? I am looking to do something similar but may run a smaller tire. Thanks Mark
Old 03-04-2012, 09:48 AM   #197
Boostedbowtie
newb here .
Mine is 4450lbs with a 383sbc .........with a little boost from a S480 turbo .
Boostedbowtie is offline   Reply With Quote
Old 03-16-2012, 11:05 PM   #198
H82LUSE
Hey Mark :
I will measure this weekend for ya I have the wheels off and the axles out so it will be to easy
Old 03-23-2012, 12:27 AM   #199
VALDEZ
VALDEZ's Avatar
alright makin a few pulls on the dyno in class tomorrow, hoping to break 200 horse haha. by the way how many of you have already been out racing this season?
VALDEZ
1971 C10 LWB 350/350
http://67-72chevytrucks.com/vboard/s...d.php?t=400327
VALDEZ is offline   Reply With Quote
Old 03-23-2012, 03:06 AM   #200
moggey01
Hey Mark :
Thanks a bunch at least I will have a good baseline on for a wide wheel and tire combination.
Mark
