Old 01-28-2012, 02:03 PM   #26
joerocks
Re: Another C20 8-lug wheel question.
Here is mine, 16x9.5 and 285/75 tires, not alot of room left but with stock sagging(broke in) springs it doesn't rub anywhere
1992 Jeep Cherokee 4.0 AUTO
1972 C10 350/350
1971 C1500 350/350
1970 C20 396/400
joerocks is offline   Reply With Quote
Old 01-28-2012, 03:16 PM   #27
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Black rims with black truck looks real good. Like that tire size.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 01-29-2012, 11:33 PM   #28
derotoreut
derotoreut's Avatar
Originally Posted by FirstOwner69 View Post
I'm going to try chrome H2 wheels with 265/65 17s on my 69. These tires are about the same diameter as the 9.50/16.5s that were optional in 69 and about 1" wider. I mounted them on my rolling chassis to see how they line up vs. the 8.75/16.5s I had on the truck. The inner sidewall lines up with the center of the top ball joint. I'm hoping there's plenty of clearance. The 8.75s are about 3/4" outside the center of the ball joint. All I can show you is the attached picture with Chevy caps.
Found a set of H2 wheels and tires locally on CL. Tires are 265/70-17. Might go take a look. What do you think about look and price?
http://rochester.craigslist.org/pts/2805359875.html
~ Dan
Old 01-29-2012, 11:40 PM   #29
FirstOwner69
FirstOwner69's Avatar
I've seen the H2 wheels from $100-$400 for a set w/o tires. I lucked out and got my OEM chrome wheels for $100 w/o tires. Needless to say, I jumped at them. They looked brand new (here in AZ no one wants to run stock wheels on late model trucks and SUVs). The caps were another $100. So, if you can get decent wheels and tires for $200, go for it!
FirstOwner69 is offline   Reply With Quote
Old 01-29-2012, 11:45 PM   #30
derotoreut
derotoreut's Avatar
These would run about $250 each and include the center caps. Not sure what the H2 cap looks like. What would I have to do about lug nuts? Would I need to order special lugs for wheels like these?
~ Dan
Old 01-30-2012, 12:05 AM   #31
FirstOwner69
H2 caps are ugly (my opinion) and won't clear your rear axle. They may clear the front but I don't think so. The lug nuts, if using the Chevy caps, are available from a couple vendors on eBay. They are conversion lug nuts with the inner and outer threads. If you don't use Chevy caps (or any others that attach to the lug nuts) any lug nut with the right taper will do. As I recall you have a 69 or 70. They had 1/2" studs. 71 and up had 9/16" studs. If you converted to disc brakes, you probably have 9/16.
Old 01-30-2012, 12:39 AM   #32
FirstOwner69
More info....
Here are 3 lug nut sellers on eBay:
http://www.ebay.com/itm/300655875649...84.m1423.l2649
http://www.ebay.com/itm/330609381394...84.m1423.l2649
http://www.ebay.com/itm/380398436903...84.m1423.l2649 I bought mine here, but his prices have jumped.
The only Chevy or GMC caps that I know will fit properly into the recesses in the H2 wheels are the 2001-2006 and 2007 Classic 3/4 ton truck aluminum wheel caps. All others are too big.
Old 01-30-2012, 12:51 AM   #33
derotoreut
derotoreut's Avatar
More info....
This is great information. Thanks for your help. There's no way that I would have ever known this about the Chevy cap size. I would def want to get Chevy caps like yours. Did you say you bought them new?
BTW I have not yet installed front discs, but I'm planning to do it soon. Looking at a couple of suppliers for 8-lug kits (CPP or POL).
~ Dan
Old 01-30-2012, 01:22 AM   #34
FirstOwner69
I bought my caps on eBay and they were new OEM. I put blue painters tape over the gold bowtie on the one in the picture to see how it would look with the period correct color. I am now looking for for something for a permanent fix. There are a bunch of reproduction cap sets like this on eBay now, but no new OEM caps. They have an opening bid price of $80 or $100 buy it now for 4.
Old 10-22-2016, 02:15 PM   #35
ironman3452
ironman3452's Avatar
ok so I am looking for 17 inch wheels to put on my 64 panel, any suggestions?
ironman3452 is offline   Reply With Quote
Old 10-22-2016, 02:22 PM   #36
ironman3452
here is a picture of what is on the panel, from what I know these are trailer wheels and should not be used, only for trailer, that was what I have been told, problem, I have new 17 inch tires, that were given to me, so that is why I want to put 17's on it
Old 03-26-2019, 01:42 PM   #37
Furno68C20
Here ya go! These are BFG ALL Terrain 285/75/16.
I want to go back to original steel wheel with smaller tires. Want to buy em?
Furno68C20 is offline   Reply With Quote
Old 03-28-2019, 01:23 AM   #38
northerngmc
northerngmc's Avatar
235/85/R16's on newer Chev wheels. Before and after a 2/4 drop.
Blaine
59 GMC 9314 a.k.a. Whoopee
68 C20 50th Anniversary a.k.a. The Rat
http://www.flickr.com/photos/northerngmc/
http://www.members.tripod.com/P-wee/index_032.htm
1.61803 is one H of a lot better than 3.14159, no really it is!
northerngmc is offline   Reply With Quote
Old 03-28-2019, 08:31 AM   #39
derotoreut
derotoreut's Avatar
After seeing the resurrection of my original thread, I realized that I never followed up with pictures of my '69 C20. I ended up installing 285/70-17 tires on Hummer H2 wheels with Chevy caps. The truck has since been sold.
C20 with H2 wheels
Comparison of original tire size to last tire size.
Name:  H2 Wheels & Tires6.jpg
H2 wheel with Chevy cap
Name:  H2 Wheel & Cap.jpg
~ Dan
Old 03-28-2019, 02:36 PM   #40
FirstOwner69
Here's an update on mine. I accomplished my goal of making the Chevy center caps resemble the centers of the original hubcaps (shown for comparison). I finished the restoration in 2015. A lot has changed in 7 years!
Old 04-25-2019, 08:51 AM   #41
clegg
Do the H2 wheels bolt right on, no adapter or spacers necessary?
clegg is offline   Reply With Quote
Old 04-25-2019, 12:16 PM   #42
USAF
35's X 12.5" on 16" wheels on my 72 K20.
1972 K20
2004 Chevy Aveo
2011 BMW X5 Diesel
2018 Chevy Silverado Diesel
U.S. Air Force Retired - 1983-2017
USAF is offline   Reply With Quote
Old 04-25-2019, 01:52 PM   #43
FirstOwner69
They bolt right on. Center caps may be a problem depending on your rear axle.The Chevy caps I used fit on my Eaton axle. I believe they will require spacers if you have a Dana. Member davepl should be able to provide a definitive answer. The only Chevy center caps I found that fit into the wheel recess are those from the early 2000s 8 lug aluminum wheels.
Old 04-25-2019, 02:06 PM   #44
clegg
Thanks for the insight on these. I am looking at a possible- my motorcycle trade for a C20. I'm not sure which rear end the truck has. I may go and see it soon.
