Old 01-28-2012, 07:46 PM   #1
Critterman71
Critterman71's Avatar
71 disc drum brakes issue need help
I have a 71 Chevy Longhorn with power Disc and drums with with all original equipt. I am having trouble finding my problem. every time I stop the rear brakes lock up under normal pedal pressure. I can stop the truck if I ease down on the pedal but if I hit the pedal normally it always locks the rear. The booster has been tested as well as the master cylinder and the front calipers too and rear wheel cylinders and all lines. NEED HELP> Thanks Critterman71
Critterman71 is offline   Reply With Quote
Old 01-28-2012, 07:55 PM   #2
BuiltwithIvy
Re: 71 disc drum brakes issue need help
do you have a proportioning valve?
"To speak of the art of one loom, the art of one river, the art of one tractor, or the art of one automobile is not preposterous; it is to point to the size and importance of the gap between general knowledge and situated knowledge" - James C. Scott
1969 C10 - http://67-72chevytrucks.com/vboard/s...d.php?t=492064
1930 Tudor Sedan
BuiltwithIvy is offline   Reply With Quote
Old 01-28-2012, 08:39 PM   #3
CaptRMW
Custom Sport W/T
CaptRMW's Avatar
Location: Tarpon Springs,Fl & Annapolis,Md. ....................Quaint drinking villages with a fishing problem
If you haven't already pull the rear drums and check for a seal leaking differential grease or a cylinder leaking brake fluid on the shoes.. Roger
CaptRMW is offline   Reply With Quote
Old 01-28-2012, 08:46 PM   #4
Critterman71
Thanks for the direction but I have check that also cylinders are excellent and no seal leaks thats why this is so baffling to me. I am now wondering about the prop valve but I am unsure how to test it for my issue, and or if it can be adjusted. Thanks so much for your reply. Keep truckn.
