Old 01-29-2012, 06:02 PM   #1
Jkeith
Speedometer cable???
Installed speedometer cable and it pegs while just cruising down the road. How do I go about fixin it. Shows me at 20mph barely moving
Jkeith is offline   Reply With Quote
Old 01-29-2012, 06:30 PM   #2
Tmwoodall
Re: Speedometer cable???
I am guessing you have the wrong speedo gear in your tranny. Someone more knowledgable will chime in though.
www.tomthetruck.blogspot.com <-- Aka build thread.
Tmwoodall is offline   Reply With Quote
Old 01-29-2012, 07:20 PM   #3
68gmsee
Active Member
68gmsee's Avatar
Need a little more info...
What was the orginal reason for replacing the cable?
Sometimes, the cable doesn't sit in properly under the dash and/or the tightening cap will go on crossed and not go in all the way. Check it carefully.
Also, you say it "pegs" while cruising. Does it go all the way to the right?
And you say "it shows you at 20 mph barely moving." How fast are you going when it shows 20 mph? See if you can borrow a gps from someone. They tell you how fast you're really going. Then post the speed vs. what the speedometer shows and we can determine what may be the problem.
68gmsee is offline   Reply With Quote
