Old 01-30-2012, 12:11 AM   #1
Dguzzardo22
Height of body mounts
What's the height of front middle and back and core support mounts ?
Dguzzardo22 is offline   Reply With Quote
Old 01-31-2012, 07:57 PM   #2
Dguzzardo22
Re: Height of body mounts
Can anyone measure them for me ? Thanks ?
Old 02-03-2012, 06:08 AM   #3
Dguzzardo22
Can someone take like 10 min to go measure the middle sections and front rear of the body mounts on there blazer ?
All body mounts THANKS !!
Old 02-04-2012, 07:37 AM   #4
tobiahr
tobiahr's Avatar
what exactly do you want measured? the distance from the ground to the body mount? the thickness of the body mount? i could take 8 hours measuring all the various aspects of the body mounts and still not have the information you want because you have not properly defined it.
tobiahr is offline   Reply With Quote
Old 02-04-2012, 02:26 PM   #5
Dguzzardo22
The height as if all mounts were standing on a table from the top to bottom .
The height from body to frame .
Old 02-04-2012, 09:16 PM   #6
tobiahr
tobiahr's Avatar
mine average 3/4 to 1 1/4 inches from body to frame, but they are old and need to be replaced. the radiator support mounts are only about 1/2inch but the rubber bushing is rotted to the point of non existance. that is also compressed thickness on all of them, if you are looking at material to replace them with you will need to take that into account.
Old 02-04-2012, 09:18 PM   #7
Dguzzardo22
What about the middle body mount
Old 02-06-2012, 01:05 AM   #8
Dguzzardo22
Old 02-06-2012, 01:23 AM   #9
tobiahr
tobiahr's Avatar
i just remembered the body mounts are different heights depending on year model. what year is yours? and did you cut the crossmember?
Old 02-06-2012, 01:36 AM   #10
Dguzzardo22
Yes I cut mine for a wishbone link and driveshaft .
Mine is a 76 .
Old 02-06-2012, 01:49 AM   #11
tobiahr
tobiahr's Avatar
the measurement on mine would be different then. i have an 82. 73-76 should be the same. you might have better luck contacting a distributor and asking. i do see from the lmc catalog diagram that year and position is probably about 2 to 3 inches http://www.lmctruck.com/icatalog/csb/full.aspx?Page=36
