#26 | |
![]() Join Date: Jan 2012
Re: 1965 C-10 LS build
#27 |
![]() ![]() Join Date: Oct 2011
Here's a pic of the DT, they are nice.
Craig 1966 Chevrolet C10 - Supercharged LS3 1968 Chevrolet Camaro 1957 Chevrolet 2dr Hardtop "It makes sence if you don't think about it" ![]() Mesquite 1966 C10 - LS3 W/ Air Ride http://67-72chevytrucks.com/vboard/s...=1#post4989763 |
#28 |
#29 |
They just cleared, the are not long tube they are mid.
#30 |
A little update on the build. My gas tank came in and got it put in. I gave the wiring a little break and decided to move the battery to the drivers side. I cut in a box in the inner fender near the core support. I'm going to run the cold air intake and filter to the passenger side where the factory battery was located. I finished up the metal work on the cab and bed sides going to ship the bed sides and the hood off to the body shop on Thursday.
#31 |
#32 |
I was looking at different motor mount adapters and found that the ones that I used that were mark as for install the engine in the stock location (Transdapt Brand) moved the engine forward almost 2 inches. I found a set of Hooker Headers motor mount adapters that did put the engine in the stock location. About 2 inches back from the other brand.
![]() ![]() This should help a little with headers fitting. It also gives me a little more room between the radiator and the water pump pulley. Below is a couple of picture of where I move the battery to. My welding skills aren't as good as alot of people but the grinder will clean them up. I also posted a couple of pictures of the gas tank. ![]() ![]() ![]() ![]() USPS dropped off some more parts the past couple of days. I delievered my bed side and the hood to a body guy today. Should have them back in a couple of weeks nice and straight and ready for some blocking and more priming. Has anyone out there ever used Hot Rod Flatz paint? Wondering how it sprayed out? Hopoe everybody has a good night. ![]() |
#33 |
Yes, and with your current engine location I think you will be good to go.
#34 |
#35 |
just checked your thread, awesome build. i love the ls motors and the are capable of some serious horsepower,since you have already cut down your inner fender that would be a great place for a turbo
my 65 fleetside build http://67-72chevytrucks.com/vboard/s...d.php?t=442370 big back glass conversion http://67-72chevytrucks.com/vboard/s...dow+conversion |
#36 | |
#37 |
Man that wiring is amazing!
You would have to be really good at puzzles I think... Your build sure is coming along nice though, cant wait to see how it all turns out!
Michael McMurphy My 66 Stepside My 64 Tow Truck My 66 Tempest Table Of Contents Added to Page1 |
#38 |
She's going to be a beauty!!
#39 | |
#40 |
Thanks for the checking out my build. I just looked at your post. Your truck looks outstanding. Very clean and detailed rebuild. The tire combination is great. Can you tell me what size wheels and tire them are? Also what air ride system did you use? How do you like that system? I was looking at a Ride Tech system but there quite expensive. Thanks again, Robert
#41 |
Haven't posted much about the build, but I did got a few things done. I finished up the passanger side rocker and got it primed. I hung the door, inner and outer fender. I had to take off a couple of the braces off the inner fender to get it to line up. I starting to find out that this after market stuff doesn't line up very good. I have a little work to do on the door gaps as well. I finished the drive by wire pedal and got it mounted. I purchase a power window kit from AutoLoc and attempted to install it with no luck. The kit I bought was a universal kit for a flat window and I think I will return it or put it on E-Bay and buy a kit made for the truck.
I have been wanting to air bag the truck and I decided to do it know rather then when it painted. I ordered bags, brackets and fittings from AVS and a "C-Notch" kit from CPP. The bed and the hood should be back soon and will send the rest of the truck to the body shop after that. ![]() [IMG] ![]() ![]() ![]() ![]() ![]() Thanks for looking at my build and have a great night. ![]() |
#42 |
Looks like a fun build, I think LS power is the way to go if you can afford to make the leap.
http://67-72chevytrucks.com/vboard/s...d.php?t=765151 |
#43 |
Looking really good! Keep it up!
Posted via Mobile Device |
#44 |
that repop fander looks good!
#45 |
Your truck build is looks great. It's neat that your using the 6 cylinder engine. I like the color of the motor. The air valves tht you have look nice and compact and a clean look set up. I may have to look into something like that when I'm ready to get mine. Again very neat build you have going there.
#46 | |
#47 |
I wanted an LS so bad, but couldn't justify the cost. For $500 more than the LS I got a whole LT1 C4.
The LS is SO worth it and your truck will love you for it. ![]()
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
#48 |
Subscribed. Great build, I'm always amazed by guys, like yourself, that can take on so much of a build at one time and get things done. I'd be there for years trying to restore a chassis, body and install an LS drivetrain. Great job!
#49 | |
This is my Build A 5.3L 1965 C-10 Fleetside http://67-72chevytrucks.com/vboard/s...d.php?t=502100 |
#50 |
truck is coming along nicely, door and fender gaps look good, your going to have a sweet ride very soon at this rate.
