Electric vs Manual Fuel Pumps
So I'm planning on putting a fuel cell in my truck one of these days and was curious about the fuel pump options. Do I have to run an electric pump or can I use the normal pump on the engine block?
And which is better and why? |
Re: Electric vs Manual Fuel Pumps
You can use a "regular" pump on a fuel cell.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
mechanical fuel pumps are one of the most reliable units ever designed// no reason with a carb to run anything but
If your pickup is just a driver, maybe a once in a while quarter mile pass, the mechanical pump, is simple, and will work fine.
Eletrical pumps serve a good purpose when needed in higher performance applications. I like things simple, every chance I get. |
Yep i yanked the electric pump out of my truck and put a mechanical back on it as soon as i bought it, keep it simple, they just work
68 SWB Fleet 383 |
And if you're out on the road and have an issue with a mechanical, stock fuel pump, you're an auto parts store away from getting a stock replacement off the shelf.
If you have a whizz-bang googleplex super duper fuel dumper and it goes out you'll have to wait for Summit to bring you a new one which may destroy a trip. I replaced the stock fuel pump on my truck in Deer River, Minnesota. I limped into town and found the auto parts store on main street. I installed the pump in the back lot. Total down time about 30 minutes.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
go with a mechanical pump. electric fuel pumps always decide to go out at the worst times. in my opinion mechanical pumps last much longer too
Posted via Mobile Device |
#8 | |
I wish i could run a mechanical but i'm running a vortech 350 and have to use an electric pump and your right they do go out and its always at a bad time. always have a spare under the seat.
I don't think we get smarter as we get older. We just run out of Stupid things to do. |
Fabricate till you "puke"
I have a stock AC Delco on my 383(specs in my sig).....I have never seen the old stroker to starve for fuel. The stock pump puts out 5 1/2-6 psi. Last trip out, the youngest kid was playin....@ 125 mph in 5th gear, I told him ....you have 2 choices, either back it down, or shift OD, & drop the hammer. On the way back, that lill bioch was in OD & I layed the hammer down
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
The only reason I run an electric pump on non-injected cars is when the block isn't cast for one, like the old ZZ502s. Mechanical pumps are infinitely quieter and hassle-free.
I've got an Aeromotive A1300 pump in one car that's good for about 1500hp, and wound up adding a pump controller and moving it in-tank just to dampen the noise. So I use them were I have to, but given a choice always pick mechanical. |
Awesome. Thanks for all the inputs. The truck is not going to be a daily driver or driven on the street at all. It's strictly going to be a drag truck. And right now all I'm running is a 500 cadi. All stock other than an aluminum high rise intake. Truck is pretty much gutted out and is a long bed, so I just wasn't to sure about the fuel pump situation, but thanks again.
toys'r'us
mine leaked a bit after 40 years. still ran just leaked a bit. bellow pumps will pump mud and never jam
71 jimmy bone stock 350 sm465 33x12.5 rallies 79 caprice landau full load crate350 th350 lowered 20"wires 00 f150 reg cab sb 4x4 5.4L |
