Old 01-30-2012, 11:38 AM   #1
tc4x4
tc4x4's Avatar
Sm465
On the topic of transmissions, I have the 4 speed with the granny gear. I beleive its the sm465.
The SM465 is heavy-duty truck transmission is used in light duty and heavy duty trucks. The SM465 was made by General Motors from 1968 to 1991. The SM465 can be found in Chevrolet and GMC full-size trucks, Blazers, Suburbans among other models
The "SM" in the transmission's designation stands for Synchro-Mesh.
Gear Ratios are:
First Gear - 6.55:1
Second Gear - 3.58:1
Third Gear - 1.70:1
Fourth Gear - 1.00:1
Reverse - 6.09:1
I think I have 4.10 gears also, when I'm cruising My rpms are revved pretty high. I'm considering while I have the axle opened up changing to something like 3.73 gears.
Would this make a big difference for cruising?
tc4x4 is offline   Reply With Quote
Old 01-30-2012, 07:16 PM   #2
76stepsidechevy
Re: Sm465
depends on your tire size, 4.10 to 3.73 really isn't much of a drop though. I have 33s with 3.73s and run 2500 rpm at 65.
76stepsidechevy is offline   Reply With Quote
Old 01-30-2012, 07:37 PM   #3
tc4x4
tc4x4's Avatar
Re: Sm465
I guess I just got a get a tach to see where I'm at first...
Old 01-30-2012, 09:46 PM   #4
coreys87
Re: Sm465
im running 3:83s with a sm465 and 35inch tires and its about 2300rpm to do 65 mph
coreys87 is offline   Reply With Quote
Old 01-30-2012, 09:49 PM   #5
76stepsidechevy
Re: Sm465
Hows it feel on take off? do you have to clutch it a lot? can you actually take off from first gear? I just went with some bigger lift springs and my 33s look tiny now so Im looking at a 35 or 36.
Old 01-30-2012, 09:53 PM   #6
coreys87
Re: Sm465
its really not bad. i only use first gear, no low. do have to clutch it a little more since im used to 4;56's
Old 01-30-2012, 09:57 PM   #7
76stepsidechevy
Re: Sm465
Cool, maybe ill just go with 35s then. It would be nice to get the rpms down to help out my highway mileage a little bit but It probably wont change anyways. New 6" bds springs make the old rancho 4" kit look like it was stock suspension. I only had time to do the rears this weekend and my truck has a wicked rake right now.
Old 02-01-2012, 09:26 AM   #8
coreys87
Re: Sm465
Really? I have been wanting to go to a 6 inch lift from my 4 inch
Old 02-01-2012, 06:24 PM   #9
76stepsidechevy
Re: Sm465
Yea, I haven't done the front springs yet but the old rear suspension was just blocks on stock springs. Im sure those 36 year old springs were tired. We'll see what happens when I get the front springs in this weekend. Lol right now it looks like a drag car.
