Old 01-30-2012, 01:15 PM   #1
va72longhorn
va72longhorn's Avatar
need help from the refinishing guru's
I have a nice original saddle console that someone ignorant at the time (I wont say who : ) thought would look better white a couple years ago. Does anyone know a good, easy way to take rattlecan (krylon) off the molded plastic without screwing the original saddle finish up? If not, any other suggestions? What are you guys using for refinishing the consoles and '72 door panels?
va72longhorn is offline   Reply With Quote
Old 01-30-2012, 02:32 PM   #2
hayhauler71
hayhauler71's Avatar
Re: need help from the refinishing guru's
SEM vinyl dye comes in many colors in a rattle can
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 01-30-2012, 02:48 PM   #3
cdowns
cdowns's Avatar
i'd try using laquer thinner on a rag// start in an inconspicuous place first
Old 02-01-2012, 11:12 AM   #4
va72longhorn
Yeah, I was thinking the same thing on the laquer thinner. Might try it this weekend. I'll probably still end up going over it with some of the vinyl dye, though, if nothing else to ensure a match with the door panels. Is there any secret to prepping for that stuff since this is more of an ABS plastic than a more pourous vinyl material? Obviously you dont want to use any typ of sand paper. Maybe wiping down with alcohol? Is the SEM dye something available at the auto body supply houses?
Old 02-01-2012, 11:21 AM   #5
black_sheep454
If you have access to some enamel reducer or mineral spirits I would try it first over the lacquer thinner because it not as strong. May take some more time but have better results. If you respray with sem dye then scuff with some scotch brite pads and clean it with some wax and grease remover first.
1968 chevy lwb, getting ready to join forces with the 70 gmc
1970 gmc swb, getting ready to be a 68 chevy swb
1971 gmc lwb 2500 2wd Sierra Grande
1988 chevy 1-ton crew cab 2wd waiting for a 12v cummins
black_sheep454 is offline   Reply With Quote
Old 02-01-2012, 04:53 PM   #6
BluTrukker
BOHICA
BluTrukker's Avatar
put some brake fluid on the hard plastic parts. it will loosen it up and then you can brush it off with a stiff brush.
Trying to save someone from their own stupidity is like teaching a pig to dance. It is a waste of your time, and it annoys the pig!
BluTrukker is offline   Reply With Quote
Old 02-01-2012, 04:55 PM   #7
VWBeamer
I've had good results on the hard plastic painting it with regular enamel spray paint, if you can't get the old paint off.
VWBeamer is offline   Reply With Quote
Old 02-01-2012, 09:12 PM   #8
PHAT TONY
PHAT TONY's Avatar
Go to a parts store and find rubber bumper paint stripper, comes in a spray can.
1972 factory 2 Wheel Drive Blazer-Sold
1972 K10 4X4-Sold
1971 Chevrolet Cheyenne/10-Sold
1970 Chevrolet C/10-Sold
1968 GMC 4X4-Project
1968 Chevrolet C/10 Pro Street
1970 GMC 3/4 Ton-Parts
1997 2WD 2DR Yukon-Sweet
http://67-72chevytrucks.com/vboard/s...d.php?t=335664
PHAT TONY is offline   Reply With Quote
Old 02-02-2012, 08:58 AM   #9
va72longhorn
Now that something that I would have never thought of ! I'd really would like to have the original saddle finish when Im finished. I'll check around and see if I can find any of that.
