01-31-2012, 03:50 AM | #1101 |
Re: '66 Sunbeam Minx Project - F20C/6sp/4-link/Discs...
dang FF! yet again look so clean! BTW do you buy POR15 by the case? i see the box sitting there on the floor!
63 4 door Chevy II - NOVACATION (Updated 08/23/09) 65 Morris minor Traveler 77 Chevy Longbed. 93 Corolla JDM 20V Swap Daily Driver (Updated 07/16/09) Powder coating Hawaii Domestic Violence Awareness Show 5/3/09 Hawaii Rod and Custom Show 4/18 |
01-31-2012, 04:46 AM | #1102 |
Hah, no. That's a fuel tank sealer kit
Posted via Mobile Device |
01-31-2012, 02:58 PM | #1103 |
Nice work FF! I was curious how you like the Rigid flaring tool? I have one I bought from Sears and it does not grip the tube tight enough for flaring. When I turn the handle to plunge the flaring tip, the tube gets pushed out.
And if ya find it, a pic from the inside of the car of the adjustable proportioning valve would be cool. |
01-31-2012, 04:07 PM | #1104 |
You're right, on the 3/16 tube I have to tighten it down ultra f'n tight using a cheater handle! Seems like it may be due to the fact that the 3/16 slot is the only one that's smooth/no ridges. I was considering removing a tiny bit of material from the inside surface of the jaws. But so far it's working with the cheater bar. Just hope I don't break it... I'll take another pic of the prop valve tonight.
01-31-2012, 05:08 PM | #1105 |
when you remove some material you dont have to tighten it so mush , i think its the better solution it keeps the device intact and doesnt ruin the tread over time
it prolly be hardened material though
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
02-01-2012, 05:15 AM | #1106 |
I took a little off the inside surface of one of the jaws on the disc sander. Might be a little better. I'll do the other side next (we're talkin thou's at a time).
And now this- Prop valve location: The diff brake line plan hit a snag... I put the rear back in place to locate the hard-line/flex line bracket and found some clearance issues. So I ran them in a more conventional route. Still made sure they stay below the top of the pumpkin since it will be coming close to the trunk floor under compression. Here's a shot of the rear-end in place: Flex line bracket locating: New hard-line set up on rear. A little trick for locating a bend: These have American on one end and Metric on the other Other side: |
02-01-2012, 09:29 AM | #1107 |
This same kit is a essential tool that was sent to our dealership. Its the best flaring tool I have ever used, its expensive but worth it in my opinion... You can find it cheaper but it has less stuff in the kit usually. just search ebay for hyraulic flaring tool and you can get the same kit for way less. I even seen a kit that just does the brake lines and it was only $60 http://www.classictube.com/shop-onli...tegory_id=1866
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks.. |
02-01-2012, 01:19 PM | #1108 |
the pollock
i hate you so much right now... in a envious little brother sorta way.
every damn time i bend brake lines it looks like a two year old drew the layout in crayons.. i can never ever ever ever find a good bender when im doing lines.. and im allllllwwwwaaaayyyysss tweaking.. im jealous.. i no like you right now because it's so pretttttyy
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 |
02-01-2012, 03:14 PM | #1109 |
I'll give this a try. Thanks for the tip!
02-01-2012, 03:22 PM | #1110 |
VA72C10
looking good!!!
Looking for a 67-72 swb or blazer project in or around VA. |
02-01-2012, 03:33 PM | #1111 |
Great tips and illustrations as usual.
02-01-2012, 05:00 PM | #1112 |
i heared people using belt pulleys of different sizes to bend brakeline in the right radius
02-01-2012, 09:50 PM | #1113 | |
NP Thanks Nice, I'll have to try that on the fuel line! |
02-02-2012, 11:33 AM | #1114 |
The Aeroquip stuff is nice, they make some of the best hydraulic hoses in the industry. They even sell some that are non-crimp fittings which makes it nice. I will check my catalog to see if they show fuel line like this, if so I can buy it cheaper..
Not in my catalog but the dealer says he can order it, let me know if you want to go with it and I will get pricing for you.
05 2500HD 6.0 excab 69 LWB-Gone but not forgotten! 68 Dodge Charger 383/727 69 Dodge Charger-440/4spd Last edited by OLDIRON69; 02-02-2012 at 11:41 AM. |
02-02-2012, 04:44 PM | #1115 |
As always FF, that's some major talent.
SEMPER FORTIS U.S. NAVY 97-05 USAF 94-97 |
02-02-2012, 07:25 PM | #1116 | |
Thanks, but I have to admit those lines are so easy to bend they make me look good Posted via Mobile Device |
02-03-2012, 01:13 PM | #1117 |
ok let's see....road test checklist....
engine............... check trans................. check wheels............... check suspension.......... check brakes................ check interior................ Milk crate! so when should i book my ticket? glad to see it's coming along.
02-03-2012, 02:07 PM | #1118 |
the pollock
I did the milk rate a few months ago in the maro frizzle.. stepped on the gas and the motor had a little more kick then i was epecting in the car.. it put me on my ass behind the milk crate was very humorous..
make sure the ebrake works..
02-03-2012, 04:02 PM | #1119 | |
Shootin for spring!!! ebrake............... check |
02-03-2012, 04:39 PM | #1120 |
makes me think of my yougth i was putting togethr a motorcycle and hadnt bolted down the buddyseat when i whent out to try to drive it .
the motor was going down the road a few feet before falling over i was left behind with the seat between my legs
02-06-2012, 10:03 PM | #1121 |
Had an "oh crap" moment looking at the pics. This one:
In particular the relationship of the prop valve to the trans x-member bolt holes ...yeh Solution: ...I'll pay for my mistake in the form of having to re-powdercoat it now On to the fuel lines. I had attempted to re-use the S2000 lines with no luck. On one of my bazillion trips to NAPA this week I checked out their Poly Armor line selection to see if they had 5/16" for the fuel supply and 1/4 for the return: Yep! Picked up 2ea 60" sticks and some fittings. Here's that: |
02-06-2012, 10:15 PM | #1122 |
VA72C10
nice work as usual!
02-06-2012, 11:55 PM | #1123 |
67cheby
looks FACTORY !
02-07-2012, 09:07 AM | #1124 |
05 2500HD 6.0 excab 69 LWB-Gone but not forgotten! 68 Dodge Charger 383/727 69 Dodge Charger-440/4spd |
02-07-2012, 02:15 PM | #1125 |
don "The DRBMan" 2014 Audi A4 (The Wife's Daily Driver) 2017 HD Ultra (The Cruiser) 2003 HD Fatboy (The Ride) 2001 Chevy Suburban (Another back up!!) For the first time in forever, not a single 67-72 Chevy truck, Blazer, or Suburban on the property! Basically retired and getting the new Motorhome ready for some traveling. Doing a bit of work on the house getting it ready to sell! LOL!! |
