Old 01-31-2012, 03:00 PM   #1
PAPA KENT
PAPA KENT's Avatar
Mirror barcket.where to find the right one?
hi there,last fall i purchased a steel rechromed mirror bracket for the left side off of e-bay and recently i purchased what was advertised as a chrome right side bracket from e-bay which turned out to be stainless steel which of course does'nt match but my problem is the left side bracket of course stands up high like the originals of course but the arm on the rightside bracket has a much lower angle on it so of course my 5x7 mirror has a portion of it lower than my window. does anyone know a seller that sells the bracket with the correct bend to the arm?other wise i'll have to buy another one that matches the drop like the right one.i would like them to be above the window glass like the originals. any ideas?
thanks!
PAPA KENT is offline   Reply With Quote
Old 01-31-2012, 03:53 PM   #2
1963c-10
1963c-10's Avatar
Re: Mirror barcket.where to find the right one?
LMC, Ecklers, Classic parts of America, Classic Industries, Truck Shop, Bow Tie Bits, Tim Tygerts Obsolete Chevy Truck Parts, Classic Truck Parts.......I would stay with the Stainless stell....never rust and easy to polish.
1964 Short bed trailer
Old 01-31-2012, 05:27 PM   #3
PAPA KENT
PAPA KENT's Avatar
Originally Posted by 1963c-10 View Post
lmc, ecklers, classic parts of america, classic industries, truck shop, bow tie bits, tim tygerts obsolete chevy truck parts, classic truck parts.......i would stay with the stainless stell....never rust and easy to polish.
hey thanks for the reply,but i guess what i am trying to ask is if anyone knows who makes the bracket where the arm goes more in a upwards direction like the originals.otherwise i will buy another one that the arm's angle is much lower.if all of the repop's are at the same lower angle then i'll have to settle with those.
Old 01-31-2012, 05:58 PM   #4
1963c-10
1963c-10's Avatar
Most of the repops are made by the same manufacturer. Have you compared it to an OEM part? Might be worth finding NOS part
Old 01-31-2012, 08:16 PM   #5
PAPA KENT
PAPA KENT's Avatar
yes i figured most of the repops were the same but i was hoping that someone might have made one that had the correct angle on the bar itself.the chrome one looks to be o.e. and i like it but perhaps i will have to sell the chrome one and pickup another repro to make them match.
thanks!
Old 02-01-2012, 12:09 AM   #6
markeb01
Senior Enthusiast
markeb01's Avatar
I have an original OEM mirror arm I picked up in a wrecking yard 20 years ago. It’s shown in the first photo. The arm in the second photo was purchased from Chevy Duty 14 years ago.
They both appear to be identical in shape. So I’m not sure searching for an OEM bracket will solve the problem. I don’t remember ever seeing an original style mirror arm or aftermarket replacement that is as tall as the chrome version you have.
There are so many aftermarket parts that are not even close to original specs, I would suspect it’s likely the tall chrome arm is aftermarket. Hopefully another member has one formed in the same shape that can identify the manufacturer.
Old 02-01-2012, 12:04 PM   #7
PAPA KENT
PAPA KENT's Avatar
thanks mark for the insight.you are probably right,i guess i better just order another stainless bracket to match the new one.
kent.
Old 02-04-2012, 01:14 AM   #8
dugvera@gmail.com
dugvera@gmail.com's Avatar
Size:  17.1 KBPosted via Mobile Device
If this is the one you want it was purchased from brothers.
Doug
66 4x4 GMC Suburban
76 4x4 Chevy Shortbed
dugvera@gmail.com is offline   Reply With Quote
Old 02-04-2012, 09:37 PM   #9
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
I haven't seen any OE 60-66 to compare, but I know on the OE/repro 47-54, and the 55-9 the RH brackets are shaped different than the LH
Old 02-05-2012, 02:19 PM   #10
PAPA KENT
PAPA KENT's Avatar
Originally Posted by dugvera@gmail.com View Post
Attachment 866668Posted via Mobile Device
yours seem to have the correct slant on them and i see where the base meets the door the curve seems to be right.the stainless one i got does'nt match the door at all.the center of the base is lower than the outsides so it would have to be bent straight to match the door.i listed my chrome one on e-bay,maybe i should keep it and wait for another one that will fit properly for the right side.
thanks for the picture!
kent.
Old 02-05-2012, 02:21 PM   #11
PAPA KENT
PAPA KENT's Avatar
hi jon,i assumed that they would be the same.my right one sits 2" lower than the left side.looks pretty stupid.
jon let me know what your doing tuesday morning,i thought maybe we could go to breakfast.
kent.
