Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 02-01-2012, 11:35 AM   #1
dragginmetal
here, just not logged in
dragginmetal's Avatar
Oxygen/Acetylene Torch
I've been needing a torch for a while now. I'll be using it for basic farm use. I'm looking at three different ones. Anybody have any opinions? I'm leaning towards the Lincoln. Only because it's the cheapest and i own a Lincoln welder. So what do y'all think?
Lincoln Ele. $184.00
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
Victor firepower $219.99
http://www.northerntool.com/shop/too...7990_200357990
Hobart $199.99
http://www.tractorsupply.com/hobart-...ch-kit-3810496
dragginmetal is offline   Reply With Quote
Old 02-01-2012, 12:13 PM   #2
dragginmetal
Re: Oxygen/Acetylene Torch
** Let me add that, "basic farm use" would be cutting maybe 3/4" steel bar or 1/2" to 5/8" steel, as well as working on my truck. I'm just looking for a general purpose torch like you would have in a shop.
Old 02-01-2012, 12:23 PM   #3
ETsC10
Hand Crafted C-10
ETsC10's Avatar
The Lincoln Elect (Harris) appears to have 12' (the ad says 12"
hoses vs 20' on the other two.
IMHO--choose a brand that is Victor compatable. I believe the Hobart is...
don't know on the Lincoln.
ETsC10 is offline   Reply With Quote
Old 02-01-2012, 02:50 PM   #4
fishingjred73
fishingjred73's Avatar
You may also want to look at running it on propane if you don't already have an acetylene bottle and are going to use it for just cutting.
James
'68 Stepside (ground up in progress)
My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html
'81 SWB "Pap paw" (Driver)
The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html
Member of
www.louisianaclassictruckclub.com
https://www.facebook.com/groups/296290610747732/
fishingjred73 is offline   Reply With Quote
Old 02-01-2012, 10:25 PM   #5
dragginmetal
I didn't notice the Lincoln's hoses were only 12'. I might just spend the extra 20 bucks and get a Victor instead of the Hobart(Victor compatable).
I don't know anything about using propane. I'm gonna do some reading about that and see if it would be a better option for me.
Old 02-01-2012, 10:29 PM   #6
donut
donut's Avatar
Personally I'd check out your local welding shop, sometimes they have "re-man" that run fine. Also gives you the option to price check the consumables tips, cleaners, more hose (personally I won't even bother to hook up 12' of hose, I prefer more distance between my hot work and the tanks. Then again, I run flashbacks at home too.)
Some shops will also have off brand kits that work fine and use OTC parts.
On the job I've used Airco, Victor, Harris and some off brands. Torch tip style is different with the Victor and Airco styles common
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 02-01-2012, 11:12 PM   #7
fishingjred73
Only thing you have to change to run propane is the tip in the torch. Everything else will work. I like that if I run out of propane I can just run down the road to the Dollar Store exchange the bottle and get back at it. Don't have to worry about the welding supply being open on weekends and the propane is cheaper.
James
Member of
Old 02-03-2012, 09:20 AM   #8
dragginmetal
I haven't had a chance yet, but i'm gona try to get to the welding shop today. I'll see what they have.
So, it runs off propane and oxy? Is it a special propane tip, or just a different size tip?
Old 02-03-2012, 04:40 PM   #9
fishingjred73
Yep propane tank off the BBQ pit and oxy. I have a Victor torch and it's a special propane tip I had to buy.
James
Member of
Old 02-10-2012, 09:24 PM   #10
crushermechanic
crushermechanic's Avatar
propane uses 2-3 tip sizes larger than actylene because it doesnt burn as hot. get the longest hoses you can. make sure you use a flashback arrestor on both hoses and find a good torch cart.
crushermechanic is offline   Reply With Quote
Old 02-10-2012, 10:18 PM   #11
dwcsr
Hollister Road Co.
dwcsr's Avatar
The Lincoln set is for small tanks like the portable carrier type. The Hobart has the big gauges and back-flow prevention valves which is nice when you over heat he torch head and it burns back into the hoses.
