Old 02-01-2012, 09:25 PM   #1
cwindham
cwindham's Avatar
Gauge Lights
What do I need to get to enhance the lights in my gauges? They don't light up much at night, difficult to see almost. Is it a printed circuit?
1984 Chevrolet Silverado
cwindham is offline   Reply With Quote
Old 02-01-2012, 10:28 PM   #2
DetroitIron
DetroitIron's Avatar
Re: Gauge Lights
I had the same question/need last Spring...I got some great help that involved removing the gauge cluster and spray painting the inside of the plastic gauge bezel gloss white...wow..what a difference with the light bulbs bouncing the light off the white inside vs the stock blueish plastic...it sounds a bit odd, but man did it work. Good luck
_______________________________________________
1985 Chevy Scottsdale K20 350 with 700R4 running 3.42 gearing aka "The Honey Badger"
1993 Silverado C3500 Ext. Cab Dually 6.5 turbo diesel
DetroitIron is offline   Reply With Quote
Old 02-01-2012, 10:29 PM   #3
DetroitIron
Re: Gauge Lights
Also, check and replace any burned out bulbs...I had one out
Old 02-01-2012, 10:38 PM   #4
cwindham
cwindham's Avatar
Re: Gauge Lights
Thanks man... I will check into it.
Old 02-01-2012, 10:59 PM   #5
THE "10" SILVERADO
THE "10" SILVERADO's Avatar
Re: Gauge Lights
While your at it, replace the bulb connectors. Mine were a little corroded and I think it did effect the lighting a little bit. Instead of white I used the redneck rattle can chrome and it came out fine also.
Michael
Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9
THE "10" SILVERADO is offline   Reply With Quote
Old 02-01-2012, 11:42 PM   #6
billybobjimmyjoejack
Re: Gauge Lights
The head light switch is also a dimmer switch for the dash lights. Check for any corrosion or break on the coil of the switch.
billybobjimmyjoejack is offline   Reply With Quote
Old 02-02-2012, 12:59 PM   #7
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Gauge Lights
did this in the fall great improvement(78 jimmy below)
added seperate red LEDS for my colour
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
