Old 02-01-2012, 09:55 PM   #1
Boog
laying low
Boog's Avatar
Z code engines
I just bought a 2006 GMC crew Z71. It has the 5.3 Z code engine. According to the owners manual it is a flex fuel engine. It does not have the FlexFuel emblem on the tailgate but that doesn't mean anything.
While E85 is not readily available in our part of the country yet I am curious how these trucks run on it.
Anyone use E85 much and have real world comparison results to regular unleaded gas. Cost and mpg, performance?
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 02-04-2012, 11:26 AM   #2
1978steven
1978steven's Avatar
Re: Z code engines
My wife's '04 Tahoe is flex fuel with the 5.3. Although we do not regularly run E-85 I can tell you a few things we noticed the few times we have ran it. Here in NY flex fuel is not drastically cheaper then regular unleaded (current prices here in NY $3.08/E-85 and $3.69/Reg Unleaded), I did notice a more peppier driving Tahoe while running E-85, significantly less fuel mileage where she normally averages 14-15 mpg daily driving she got around 12 mpg on E-85, we also noticed while running E-85 the exhaust has a distinctive almost like race fuel smell. For daily use I would not run it as the cost per gallon is not worth it, but if loaded down or towing I would run it because it really felt like it had a good deal more powwwaaa.........
2002 Silverado 2500HD LB7 CCSB LT
EFI Live by Rob at ATP, Edge CTS Insight DSP 5 control, S&B CAI, PPE boost valve, Pro Fab AIH, AirDog II 165, PPE WIF sensor delete plug, 5" stainless exhaust, Cognito braces & HD tie rods, H2's 315/70 R17 BFG's
2004 Tahoe LT
2006 Silverado Z71 LS
1971 Chevy C10
1978steven is offline   Reply With Quote
Old 02-04-2012, 02:39 PM   #3
BossHogg69
motor exploder
BossHogg69's Avatar
Re: Z code engines
Hey Boog, you can drive down here to Sherwood and get a tank of E85 and find out - there's a Phillips station down here off the Wildwood exit on 67/167 that has it.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 02-05-2012, 02:30 PM   #4
biggsteve97
Re: Z code engines
I have an 03 Z71 Tahoe with the flex fuel 5.3L and I ran the E85 in it for about 2 weeks last year. Here is what I noticed: No real noticeable difference in power or driveability, it seem to be the same but with a slightly smoother idle. However while it was cheaper per tank(1.99/gal E85 vs 2.95/gal unleaded) the fuel mileage had dropped off so much it was not economically feasible to continue use. We went from 14.5mpg down to 8.5-9.1 mpg, therefore we were filling up more often and just negated the benefits for using E85.
biggsteve97 is offline   Reply With Quote
