02-02-2012, 11:23 AM | #1 |
PITbut
Wipers blow fuse only on low setting?
:UPDATE:
So i might have figured out the issue. What size fuse should be in the wiper motor location? Anyone know? Finally getting the truck 100%. Adding the final things like wipers and what not. The wipers have sat for 4 years. I lubed everything up and turn on the wipers. They do about 2 swipes and then pop the fuse. LIttle more lube and they do about 3 swipes and pop the fuse. Heres the thing, it ONLY pops the fuse when they are on the lowest setting. If i click it to the 2nd or third setting they stay on fine. 71 chevy pu. Thoughts?
New project. 1971 Twin Turbo blazer http://67-72chevytrucks.com/vboard/s...d.php?t=676047 My new YOUTUBE channel.. Videos of my truck and a current walk around. Lyrikz74 Youtube channel DONE! SOLD! My 1971 stepside build thread My Build Thread UPDATED 6/11. DONE and sold. Last edited by lyrikz; 02-02-2012 at 04:26 PM. |
02-02-2012, 12:33 PM | #2 | |
Re: Wipers blow fuse only on low setting?
68 SWB Fleet 383 |
02-02-2012, 12:39 PM | #3 |
Location: Formerly MD and San Diego, now loving life in Arizona
Might possibly be a defective switch. If the low position is worn, it could provide a path to a ground causing the failure.
Al '69 Gmc 2500 Custom Camper '69 Chevy C10 396 |
02-02-2012, 12:46 PM | #4 |
PITbut
Wire shorted in the motor internally???
New project. 1971 Twin Turbo blazer http://67-72chevytrucks.com/vboard/s...d.php?t=676047 My new YOUTUBE channel.. Videos of my truck and a current walk around. Lyrikz74 Youtube channel DONE! SOLD! My 1971 stepside build thread My Build Thread UPDATED 6/11. DONE and sold. |
02-02-2012, 01:03 PM | #5 |
02-02-2012, 02:11 PM | #6 |
Well, I'm not certain how the switch controls speed, but if it uses a resistor to limit current for the low speed, and that resistor was shorted, then it would blow the fuse on LOW but cause no problem on HIGH. Just a guess.
Use an ohmmeter to measure the resistance from input to the output(s) when the switch is off, low, and high. Should be infinite, some number, and zero. If it's zero in both low and high, that's your short I would imagine. |
02-02-2012, 02:17 PM | #7 | |
PITbut
02-02-2012, 02:38 PM | #8 |
One of the First
Thought: make sure the wiper arms are moving freely. Way back when, I remember that my wiper arm studs were corroded up and were hard to turn. I went through a few motors before i figured it out. R&R'd them and never had another problem.
02-02-2012, 03:35 PM | #9 | |
PITbut
Hmmm. On the washer switch there is three wires. ground, power to squirter and power to wiper motor. So there has to be a resistor in there somwhere
02-02-2012, 03:49 PM | #10 |
I'm pretty sure the switch controls the ground side of the wiper motor. the power goes from the fuse panel straight to the motor assembly... I'd say there is an issue in the wiper assembly itself.
02-02-2012, 04:05 PM | #11 |
Yes, they use resistors, but they're probably integral to the motor, not in the switch, if for no other reason than getting rid of the heat... note that the hi/lo heater fan switch has to use a big external resistor in the airflow path.
In any event, I believe the wiper switch provides two different paths to ground. The power wire at the motor is hot with ignition, and low grounds part of the internal resistor network and high grounds both parts. That said, I was wrong in my original post - and agree it's pretty much got to be a fault in the motor, not the switch. You could still use the ohmmeter to confirm it, but you'd have to do it at the wiper motog connectors. |
02-02-2012, 04:11 PM | #12 |
PITbut
I may have figured out my problem. I replaced all my fuses, or removed them. Well, i think i put the wrong fuse in. What size fuse should be in the wiper motor location?
02-02-2012, 04:16 PM | #13 | |
One of the First
Popped a few fuses, fried the motors after awhile... Good luck.
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
02-02-2012, 05:03 PM | #14 |
Its more of a current draw issue than it is a short issue. If it was a direct short, you wouldnt get two swipes of the wipers before it blows. If the linkages and joints are rusted or gumed up this will create more of a current (amperage) draw than normal. Its not quite as bad in the higher speeds because its getting " a running start". Kinda like pushing a truck with the tires half flat, it takes more energy, but once it gets going it aint bad. Putting a larger fuse in will only buy you time. Take the arms off and make sure everything is lubricated good. Use some penertrating oil (WD40, Blast, etc) on the all the linkages and then run the wipers with out the arms on them for a couple of minutes. Then stick the arms back on. After sitting for four years, theres nothing to lose.
02-02-2012, 05:05 PM | #15 | |
PITbut
02-02-2012, 05:12 PM | #16 |
According to my owner's manual the wiper fused is supposed to be 20 AGC. My lawyer won't let me say you can run a 25, but I'd imagine that's ok too.
I bet it'd pop a 3 amp fuse pretty quick! I'm surprised it would surive on high either. |
02-02-2012, 05:14 PM | #17 |
member #16
here you go.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
02-02-2012, 05:15 PM | #18 |
PITbut
Sweet, 20 it is. Im suprised to.. But this fuse is wire thin.. Then i saw some pics of other wiper fuses and was like WOOOAH thats way wrong... I believe i put that small ass fuse in EVERY fuse location so when i put power to everything the first time, nothing would blow. Well, nothing did blow except for the wiper motor.
02-02-2012, 05:16 PM | #19 |
PITbut
OMG im such an idiot.. IT SAYS IT RIGHT ON THE FUSE PANEL. lol. Wow.
Talk about overlooking something... Sorry for wasting all your guys time.
02-02-2012, 05:18 PM | #20 |
Yeah, Im very surprised that it ran at all on a 3 amp.
02-02-2012, 05:21 PM | #21 |
One of the First
I believe a 20 Amp
02-02-2012, 05:28 PM | #22 |
PITbut
Yep, ran all day on high. Low it would pop it.
02-02-2012, 05:44 PM | #23 |
02-02-2012, 06:20 PM | #24 |
PITbut
I was searching all over the internet for this info. Looking at those fuse panels and just did not see the 20 amp right there on it...
Sigh... oh well.
