#3901 |
Re: Project Vitamin C-10
Here is the controler I used on my jeep to control the fan at all times. I really like it as it gives you adjustable temp control for the fan, compressor turn on for the fan, and run after ignition shuf off to cool the raditor and engine, and has only one wire to the engine and thats to the compressor. Very simple and very compact and very easy to install.. Only 79.95 plus shiping... Brian is an engineer and designed and builds these.. They will handle any fan you may wish to use even the heavy amp draw mark VIII fan many of us jeep owners install to cool the engines.
#3902 |
Forgot to include the link here it is..
http://dccontrol.com/relay_controllers.htm Check it out I think you will like it, its classy just like your build. |
#3903 | |||
1 thing at a time is progress.
I was able to spend about 6 hours on the hood today. I wiped it then guide coated it and used air tools to knock off the crust. Then I guide coated and blocked with 80. The top is done with 80. I still have to do the sides. Then i will guide coat and block with 120. If all is good I will buzz over with 180 and apply the slick sand.
Alan
Philippians 2:14-16 |
#3904 |
Looking real good. I know its going to turn out perfect for you.
#3905 |
hoods looking good, but i knew a man with your skills have no problem with that.
my 65 fleetside build http://67-72chevytrucks.com/vboard/s...d.php?t=442370 big back glass conversion http://67-72chevytrucks.com/vboard/s...dow+conversion |
#3906 |
Alan, Sorry I thought that since you are south you would be running with an AC for sure... Since you aren't then go with the simplest diagram and be doen with it... Who needs more headackes... LOl
#3907 |
SSN 706
You should make alittle movie of when you turn the key for the first time. Even if it does'nt start the first time. Be sure and get a close up of your face. Maybe a big fat chew in and a pinner hanging out.
#3908 | ||||
![]() Quote:
I filled the radiator with almost 4 gallons of 50/50 with my vac pump. I sucked the system down to make sure it would hold a vac. ![]() ![]() ![]() Well, it is alive. Start up was pretty good. First the lines on the tranny were loose. Then the tranny cooler lines on the radiator leaked. After several times tightening down I thought something was wrong. My gut was right. After removeing the lines we discovered there weren't any flares in the radiator. I called Summitt and they said it's 1/4" NPT. Shannon and I spent 3-4 hours looking for a fitting. No luck so I just ran a bypass hose for now. ![]() Line fittings are very confussing to me. It's a 5/16" OD line with inverted flare to 1/4" NPT. Correct like this one. ![]() Here is a video of it running. I still have some tuning to do.
Alan
Philippians 2:14-16 Last edited by Alan's Classic; 02-05-2012 at 01:23 AM. |
#3909 |
man that sounds good!
Cam 1972 Chevy C/10 "Custom Cruiser Project" Build Thread 1961 Olds Super 88 (Daily) 1966 Chevy Corvair 500, "Marigold" SOLD 2005 Subaru Outback Wagon DEAD 2008 Pontiac G8, New Winter/Daily |
#3910 |
man alan, when i clicked on the video and heard it running i just got a big grin on my face, lol!! great video, finding the leaks are just part of the progress! i think you'll be done before summer get here and the rate your going!! i think i got another year on mine before its road ready!! keep the videos coming, there better the pictures, lol!!
my project: http://67-72chevytrucks.com/vboard/s...d.php?t=456163 |
#3911 |
#3912 |
Rollin' Old Skool
already congratulated on Facebook, but i think it's worth another...so,
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
#3913 |
Sounds great Alan. It's all down hill from here.
1965 c-10 swb 1997 c-1500 extended cab 2004 tahoe 1993 mustang gt BUILD THREAD:http://67-72chevytrucks.com/vboard/s...d.php?t=336653 |
#3914 |
![]() ![]() Join Date: Oct 2011
Sounds great, congrats.
Craig 1966 Chevrolet C10 - Supercharged LS3 1968 Chevrolet Camaro 1957 Chevrolet 2dr Hardtop "It makes sence if you don't think about it" ![]() Mesquite 1966 C10 - LS3 W/ Air Ride http://67-72chevytrucks.com/vboard/s...=1#post4989763 |
#3915 |
Very well done... classy as always.
#3916 |
sounds great as everyone else has said... now quit grinning and get back to work
#3917 |
SSN 706
Congrats..... You need to find another project....Fast.
#3918 |
Glad you got it going, sounds good.
#3919 | |||
Dave, I can't afford to do another. If I do another it will be on someone elses dime. ![]() I'm such a tard sometimes. When I fired it and it ran for a while I noticed the cooling fan didn't come on. I jumped it and later found that there wasn't any power coming from the fuse block to the relay on the radiator support. I wish I would have paid attention before, because the fuse panel has a fan relay built into it. In the schematic the right 2 terminals are for the for the fan relay. The green is the ground. At this point I'm going to ground the relay in the cab and just use the relay out front. Since it can move under it's own power, I pulled it outside and gave it the first official bath. Of coarse I took some pics as well.
Alan
#3920 |
HOW long until spring??
![]() Join Date: Mar 2009
Alan I love the U-tube clip.. You have a driver!!!!!!!!!!!!!!!!!!!!!!!!!!! Congratulations we are all like a bunch of proud dads! way to go!
69 chevelle convertible 71-C-10 short-wide and low ![]() 64 C-10 custom shortbox "Bubba"s Recycling project" |
#3921 |
Man! Alan you have something to be very proud of. That truck has turned out just awesome!!! I want to come and see it in person one these days. Makes me want a 64-66 BAD! Congratulations!
The fleet 94 Chevy 4x4 reg cab 2018 Traverse (wifes car) 1977 SWB stepside 1949 Chevy truck |
#3922 |
The 55 is way cool
Posted via Mobile Device |
#3923 |
Alan that is one sweet looking truck, you have done some awesome work.
#3924 |
I always seem late to the show but I agree with everyone else sounds awesome!!!!
#3925 |
Resistance is Futile
Your truck looks great Alan; whats the ETA on the fenders?
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
Tags |
1959, 1960, 1964, 1965, 1966, c10, hugger, impala, orange |
