Old 02-03-2012, 03:16 PM   #1
kwin
kwin's Avatar
Aftermarket A arms?
I would like to improve the handling and straight line "feel" of my 91 burb, I saw some control arms for the 67-72 trucks , who makes them for a square and has anyone had any experience with making a burb handle?
Keith
kwin is offline   Reply With Quote
Old 02-03-2012, 03:30 PM   #2
jitteryguy
GoatLube Experss
jitteryguy's Avatar
Re: Aftermarket A arms?
I dont think you can use the terms "improve handling" and "91 burb" in the same sentence ?
I would look at tires, then quality front and rear sway bars, then good quality shock's.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 02-03-2012, 09:26 PM   #3
kwin
kwin's Avatar
lol, Im not looking for an indy car, just better on center feel and to tighten things up some.
Old 02-03-2012, 09:53 PM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Replacing the A-arms is not going to make a significant difference in handling. If you want to improve the handling of your Burb, start with the springs, swaybars and shocks. A lower center of gravity is a good starting point. If you are stock height, consider cutting a coil from the front and adding a shackle in the rear. Replace the stock shocks with a premium quality gas charged unit.
Most Burbs came with a front swaybar. If yours doesn't have one, get one. If it does have one, get a larger one from a C20 truck. Some Burbs came with a rear bar, others didn't. Once again, add a bar and better shocks.
This should get you headed in the right direction. Tells us what size tires you are running. That should be addressed too.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-03-2012, 10:19 PM   #5
tucsonjwt
x2 on swaybar first - especially the bushings. I had an upper control arm by Raybestos installed and it did not have the keyhole slot for the brake line clip in it, so a hole had to be drilled out to accommodate it. I would spend the extra money for OEM GM parts - you can get them at a reasonable price from the online suppliers.
I installed front sway bar bushings and the made a big difference in handling.
tucsonjwt is offline   Reply With Quote
Old 02-04-2012, 12:41 AM   #6
kwin
kwin's Avatar
It is at stock ride hight for now, it will be dropped soon, just trying to make a plan so that I am not buying the same parts over and over.
I may have a c30 sway bar and bushings that i was planning on using, it currently has stock 15's but I am trying to decide on wheels either heading to 17 or 18's. I like to see some side wall!
Will bigger wheel / lower side wall help with straight line stability? It feels very vague, I was thinking an increase in caster might be the solution.
Thanks for chiming in.
Keith
Old 02-04-2012, 02:24 AM   #7
SCOTI
SCOTI's Avatar
Replacing the a-arms w/some that have better geometry could/would make a difference. A burb won't ever be a sports-car.... but it doesn't have to remain a pig. I wouldn't go through the trouble of replacing them if there are not any significant geometry improvements (just because they're aftermarket tubular arms doesn't mean they're that much better).
The Hotchkis front kit & arms would work on a 73-87 (including a 91 burb).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-04-2012, 12:59 PM   #8
kwin
kwin's Avatar
"A burb won't ever be a sports-car.... but it doesn't have to remain a pig."
That sort of sums it up for me!
The kit you speak of is not listed on their site, am I missing something?
Old 02-04-2012, 01:01 PM   #9
kwin
kwin's Avatar
I will start with sway bay , spindles , wheels and tires. Because that was in the plans anyway. I love the truck, I just hate how vague it feels at highway speed.
Old 02-04-2012, 06:12 PM   #10
SCOTI
SCOTI's Avatar
The 67-87 front suspensions are the same basic design w/minor changes. The a-arms from a 73-87 can be used on a 67-72 x-member & a-arms from a 67-72 can be used on a 73-87.
Hotchkis offers 67-72 spec'd parts. The front a-arms, springs, shocks, & sway bars would swap under your burb (if you have the coin)....
http://www.hotchkis.net/search.html?...mitForm=Search
The Hotchkis rear parts wouldn't work for you but the front will be where you see the greatest gains. Just match the drop w/shackles & hangers, similar shocks & a sway bar to keep things consistent w/the front.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-05-2012, 02:51 PM   #11
kwin
kwin's Avatar
I was wondering if that was the case, thanks very much for the input.
Keith
Old 02-05-2012, 03:57 PM   #12
stroker87
lowering it, installing bigger wheels with performance tires & bigger sway bars will make a night and day difference in the handling you will loose some ride quality but being its a suburban it should still ride nice
a friend of mine done that to his and it was best thing he ever done to it, now when cruising @ 75+ mph it has a more connected feel less sway more predicable body roll is reduced too
stroker87 is offline   Reply With Quote
Old 02-05-2012, 10:07 PM   #13
nekkidhillbilly
i dont think theres much to improve with a arms
springs shocks sway bars and bushions would be 1st steps
nekkidhillbilly is offline   Reply With Quote
Old 02-06-2012, 01:23 AM   #14
SCOTI
SCOTI's Avatar
The overall set-up can be improved by simply dropping the COG, adding wider, stickier rubber, sway bars & poly bushings, & improving the alignment specs. But, you can still improve upon all of that w/aftermarket arms designed w/better geometry.....
You'll limit yourself w/stock a-arms & geometry.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-06-2012, 02:51 AM   #15
INSIDIOUS '86
INSIDIOUS '86's Avatar
Drill the cross shafts and move the whole a arm forward 3/4 of an inch to grab caster then go -.5* camber and 1/16 toe out and 5 degrees caster
Add urethane bushings all around including body mounts and add a rear anti roll bar.
This is going to be the best you can get for stock plus without going all out and chattering your teeth out of your head
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
