Old 02-03-2012, 09:35 PM   #1
davepl
davepl's Avatar
Dual-wheel conversion of longhorn?
I stumbled across this thread of an "inboard duallie", for lack of a more official name, and was very intrigued. Other than wheel tubs, it looks like a fairly reversible change, too.
Since I'm not very familar with HD trucks, I'm wondering if this is possible on a standard C20 longhorn (which I guess has C30 rails). Is there actually room to have completely inboard duallies like this on a truck that didn't start life that way?
I always assumed that factory dualies had to run the extra wheels outboard due to fitment, but maybe not. Not saying I'm going to run off an do this, but it's certainly cool and different!
http://67-72chevytrucks.com/vboard/s...d.php?t=307114
davepl is offline   Reply With Quote
Old 02-03-2012, 10:49 PM   #2
SCOTI
SCOTI's Avatar
Re: Dual-wheel conversion of longhorn?
C&C trucks (cab & chassis trucks, aka flatbeds) came w/the narrower rear housings. When swapped under a standard fleetside bed, the wheel sit as they do in that pic. If a standard 'dually' rear housing is used, the wheels would stick out farther & require the dually fenders.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-03-2012, 11:25 PM   #3
davepl
davepl's Avatar
Thanks!
So is there anything about a conventional (non-C&C) frame that would prevent you from installing the narrower C&C rear end? I imagine you'd need the springs and everything else from the C&C truck, right?
Old 02-03-2012, 11:42 PM   #4
SCOTI
SCOTI's Avatar
Originally Posted by davepl View Post
Thanks!
Nothing about the frame width prevents swapping parts.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-04-2012, 07:32 AM   #5
Dual rear wheel cab & chassis (which is all C/30 DRWs) had the narrower axle and single rear wheel cab & chassis had the same rear as a Longhorn or any other pickup. The Longhorn frame,being the one ton frame,is the same frame as used on all C/30s dual & single rear wheel. The Longhorn is the same truck as a 133" dual rear wheel cab & chassis except it has the single wheels and a bed. All 72Freak had to do was put a Longhorn bed on a 133" cab & chassis. The only modification required was extending the wheelhouses inward because the dual wheel axle doesn't allow for the 48"(+/-) floor width that is standard on all pickups.
Old 02-04-2012, 08:32 AM   #6
72freak
Rottenwood Garage Member
72freak's Avatar
Just look for a narrow rear axle and mount it up. You will have to make the wheel wells..I added 4" to each one and cut the floor to match. You will no longer be able to haul any 4' wide material laying flat though. I also used wheel spacers on the front to push the wheels out as it didnt look good to me with the dually wheels way in. We tried some regular wheels also but that didnt look good either. I also added some wheel well flare at the rear and it looked fine. I have enough left over to do another rear of you need it.
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 02-04-2012, 10:01 AM   #7
no moa
no moa's Avatar
I so wanted to do this to my C30, but i'm positive there aren't many Longhorn beds in Redneck Maine. lol
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently.
http://67-72chevytrucks.com/vboard/s...d.php?t=451950
1971 c10 step 250 3 OTT
1969 c30 TOW-MATER. 307 4 speed, holmes 440 body.
http://67-72chevytrucks.com/vboard/s...d.php?t=451082
2006 CTS-V LS2 6spd.
no moa is offline   Reply With Quote
Old 02-05-2012, 08:15 PM   #8
69C-owner
this is very interesting, I missed out on the chance to have a 67 C20 flatbed with duals from pretty much nothing but with this knowlege I can slowly gather up the truck and parts to "clone" wat I lost
http://67-72chevytrucks.com/vboard/s...d.php?t=43855069 LWB Fleet
1994 Buick Roadmaster
1994 GMC Sonoma
69C-owner is offline   Reply With Quote
