Old 09-06-2003, 10:37 PM   #1
mkmiller1
mkmiller1's Avatar
Need diagram for running dual batteries
title says it all. Anyone have the diagram?
thanks,
Matthew
GOD is good...All the time!
'71 swb custom10 barn find-68K original miles
72 K5 CST rust bucket, but runs and drives 84K miles
mkmiller1 is offline   Reply With Quote
Old 09-06-2003, 10:48 PM   #2
racedvl
racedvl's Avatar
Dual batterys. . .
racedvl is offline   Reply With Quote
Old 09-06-2003, 11:35 PM   #3
mkmiller1
mkmiller1's Avatar
Thanks racedvl!
Matthew
Old 09-07-2003, 03:02 AM   #4
67cst
i love summertime
67cst's Avatar
what are benifits for 2 batteries? my 71 has the setup but i took the second one out cause it was dead...should i get another one? would it help to start it up in the winter or anything like that?
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 09-07-2003, 08:27 AM   #5
GM72K10
Next!
GM72K10's Avatar
Big advantage if you're snowplowing! Got the dual set up in my 72 K2500 plow truck, works great!
GM
86 K30 CUCV M1028A1
86 K30 CUCV M1028a2 dually
86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump
More square bodies and CUCVs than I care to admit to
2020 Silverado K3500HD Work truck
GM72K10 is offline   Reply With Quote
Old 09-08-2003, 12:19 AM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Advantages all depend on how it is hooked up.
The way shown on this scematic will let you listen to your radio all night long, or run all the stuff in the camper all night long off of battery number 2, while as soon as you hit the ignition switch, it will switch back to battery #1. Both will charge as the engine runs.
If you hook it up with a large cable going from the positive post to the starter (on both batteries) you will get some kick ass amps to crank over in the coldest days and with the highest compression with no problems.
If you hook it up to where the positive from # one goes to the starter, then the negitave goes to positive of # 2 and then the negitave goes to ground, then you'll have a 24 - 28 volt system that will fry everything in your truck (with the exception of LED lights, and maybe your starter) and is not recomended.
Old 09-08-2003, 09:30 AM   #7
mkmiller1
mkmiller1's Avatar
I'm going to be using it to help run a winch. Which setup would you recommend for getting more juice to the winch?
thanks,
Matthew
Old 09-08-2003, 05:06 PM   #8
cojnit
Nothing clever
cojnit's Avatar
air
this would probably be good also for running electric air compressors and stuff when you are showing off your air system to the neighborhood.
Got "the Midas Touch!"
cojnit is offline   Reply With Quote
Old 09-08-2003, 11:09 PM   #9
Longhorn Man
(too lazy to type it all out)
That's how I would do it for max amps on a winch.
Old 09-08-2003, 11:36 PM   #10
Hooter
My other Love
Hooter's Avatar
the way i do it is have the one battery hooked up normally, have a lead going from the positve side of that battery to one side of a heavy duty solenoid, the other side of the solenoid is hooked up to the other battery and the solenoid is only generated when the key is on the on position, then I hook all the accesories, like my stereo and camper up to the second battery. then power is only drawn from that battery when the key is off, but as soon as the key is turned on, the battery gets linked back up to the charging system again
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 02-29-2004, 01:29 AM   #11
Brian Ringer
Junior Member
Brian Ringer's Avatar
Thanks for the info. I have a 72 K5 and I basically want a dual system for when I go camping I can power up accesories and still have a good battery to start up the Blazer.
Brian Ringer is offline   Reply With Quote
