Old 09-06-2003, 08:14 PM   #1
1970blazin
Blazerless:-(
1970blazin's Avatar
Cut fiber optic shift indicator wire!
When the shift indicator got taken off of the steering column the wire got cut. Do I need to buy a new on of these? Does anyone know where I can get one, and/ or can I just patch these two wires together. (Sorry I don't know much about fiber optic wires) Thanks in advance for any help.
Diane
1970blazin
1970 CST Blazer-Orig. Dark Blue-SOLD
Progress Pics of Blazer for sale
1970blazin is offline   Reply With Quote
Old 09-06-2003, 08:37 PM   #2
nu2-72
Fiber optics are not really wires. They are glass/resin core like fiberglass/resin communication "wires". And it takes special tools to terminate and connect them. Time for a new one. I just pulled one today for the first time but think I am going to try and use it on a different column. Someone will have one here.
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
2004 Duramax Silverado 4x4
2006 Duramax Crew cab 4x4
2010 Harley Ultra Limited
2011 Harley Street Glide
nu2-72 is offline   Reply With Quote
Old 09-06-2003, 10:04 PM   #3
Bryan68custom
I put a van column in my truck the fiber optic cable was broken ,so I bought a red LED light from radio shack and made it fit in the hole the lens diameter is (6mm) or 1/4 across you will have to trim it a little. it worked out really good. part # is 276-084
Bryan68custom is offline   Reply With Quote
Old 09-06-2003, 10:19 PM   #4
lukecp
Formerly yellow72custom
lukecp's Avatar
Call me stupid but....
You mean the shift indicator for a auto tranny in these trucks is illumiunated? Mine never worked and i haven't seen one that had, but i alwas wondered what that strange wire that wasn't copper was going from the steering collum to the dash was....learn something every day, lol.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 09-06-2003, 10:48 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
If you look at the older van columns (non-tilt) you'll find them oce in a while...early 70's vans.
I find them once ina while and get 20 - 30 bucks each time.
Old 09-06-2003, 10:53 PM   #6
ddsmith
Glowing since 1978
ddsmith's Avatar
These fiber optic wires are far from the quality required to transmit information that the new fiber optic cable have to. The only purpose of the original fiber optic cables was just to move the light from the dash light to the shift indicator. Corvettes used these type of wires to transmit the external light status to the dash in several late 60's to early 70's cars. You could try finding a replacement on a Corvette Parts web site I would think. I would think that with all the fiber optics in use now you could easily find a replacement cable. Digital audio optical cable could also be used for this I would think. Any experts out there have any input?
66 Chevy C30 Stakebody Dump, PS,PB, 327cu in
71 Corvette Coupe 454 4 speed
69 Chevy C20 Custom Camper
ddsmith is offline   Reply With Quote
Old 09-06-2003, 11:05 PM   #7
miket
miket's Avatar
They aren't that hard to come by and really all it is...is a fibre cable that runs up to a bulb socket in the back of your instrument panel....I believe you will need the whole thing...I believe the fibre optic piece is connected to the socket...
I did a quick search on eaby but didn't come up with anything...someone on this board will have/find one.
FocuzTech Performance
Evergreen Protective Coatings
Gatorhyde...the best kept secret in spray in bed lining & protection
miket is offline   Reply With Quote
Old 09-06-2003, 11:10 PM   #8
nu2-72
Want a pic?
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
Old 09-06-2003, 11:12 PM   #9
ddsmith
Glowing since 1978
ddsmith's Avatar
I just looked on the web and found this http://www.zip-products.com/Corvette...B681E664C89597 It is designed to repair corvette fiber optics wires. Looking at this and knowing that the purpose of this line is to transmit light you may want to try and splice the line back together. I would get some shrink tubing that when it is fully contracted is slightly smaller than the fiber optic line. Slide the shrink tubing prior to shrinking over the fiber optic wire and slide the other piece of fiber optic wire in to butt against the other piece. Heat up the shrink tubing and it should grab tight and hold the pieces together. Make sure the fiber optic wires are butted tightly together to prevent the shrink tubing from blocking the light transfer from one wire piece to the other wire piece. Good luck.
Old 09-06-2003, 11:22 PM   #10
miket
miket's Avatar
70 blazin:
There are also two good sources for used parts within a reasonable drive from you....may want to get ahold of Wes or Frank...
Old 09-07-2003, 08:41 AM   #11
jay6891
Car Knocker
jay6891's Avatar
I pulled a dash out of a 83 chevy last weekend and it had the fiber optic light in it also. I didn't follow it out so I don't know where it was going. Was heading off toward the ac controller or? You might find a replacement there.
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit.
jay6891 is offline   Reply With Quote
Old 09-07-2003, 09:29 AM   #12
72MARIO
72MARIO's Avatar
I am Lost. Never seen that when I took my truck apart.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 09-07-2003, 12:44 PM   #13
nu2-72
Here's one
Here is the one that I have just finished cleaning up. Polished the plastic lens and shined up the black. And it works.
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
Old 09-07-2003, 05:41 PM   #14
TERRYP
GYRO GEARLOOSE
TERRYP's Avatar
Most 70's and 80's caddy's and old's had them to show light status on the front fenders, you see them everywhere. I used then to transmit taillights to inside of my panel, work real nice.
Nevada City, CA
Everett, Washington
57 3/4 rat, 235, 3spd
66 C-10 Panel, SWB. 350 from '68, 200R4 tranny, 3.07 rear ratio, restoring
68 C10 LWB 350 4spd, 4.56 rear dump runner
82 Camaro, 305, THM-200-R4
84 Monte Carlo 305 TH350, land tuna
85 Tercel SW, snow runner
DISGRACED OUTLAW MEMBER OF THE DRUM BRAKE CLUB
TERRYP is offline   Reply With Quote
Old 09-07-2003, 08:03 PM   #15
Project1970
14.1 @ 96MPH
Project1970's Avatar
So that's what it looks like!!!
I've been using the light from my tach to tell, it does a pretty good job.
Speaking of which, I need to properly tap that in...
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 06-18-2020, 04:21 PM   #16
Majikbeer
Re: Cut fiber optic shift indicator wire!
Shift Indicator Fiber Optic Cable
Sold as Each
Part #: 7850
1967-1970 Chevy Truck or GMC Truck
Majikbeer is offline   Reply With Quote
Old 06-19-2020, 04:43 AM   #17
GMCPaul
We stock them in quantity for 67-70 and 71-72 versions.
Part # 3276689 67-72 Shift Indicator Fiber Optic Cable
1967-72 Fiber Optic Cable for Chevy & GMC Automatic shift indicator pointers without tilt column. Excellent reproduction of the original, with terminals. Bulb socket with holder not included. Specify if 67-70, or 71-72 in cart. $20.00ea
https://gmcpauls.com/steering.htm
Paul Jr @ GMCPauls
GMCPaul is offline   Reply With Quote
Old 06-19-2020, 06:31 AM   #18
dennislbrooks
dennislbrooks's Avatar
As ddsmith has suggested, try cutting the ends as square as you can and supergluing . The strength of the glued joint is probably more importatnt than the straight cut. Straight cut makes a stronger joint. You have nothing to lose. All it is doing as said above is transmitting light. I used to splice communications fiber optics. At first we fused it together then they went with mechanical splices. Now use both.
A piece of shrink may help hold splice after but may not be necessary. 88 tape, vinyl electrical tape may aslo work for a cover.
Is it clear plastic or glass?
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T
dennislbrooks is offline   Reply With Quote
Old 06-19-2020, 11:06 PM   #19
vitamin_c95
This post was last posted in back in 03 btw. But Yeah, mine was cut too. I bought a new one, still no worky. I just count detent at night
1971 C20 Longhorn 350/350 "Conquistador"
vitamin_c95 is offline   Reply With Quote
Old 02-01-2021, 10:01 AM   #20
72afr
Beep! Beep!
72afr's Avatar
Reviving a ridiculously old thread here, but I believe mine was cut when I got the truck. We swapped in a tach dash and looks like we forgot the socket needed to make the FO work. Does anyone know where I can track one down?
1972 Chevrolet C/10 shortbed, stepside, 350, HEI, Fire Engine Red, Black Interior, Former Army cargo transport
2003 Chevrolet 2500HD CC 6.0 4wd
2004 Jeep Rubicon some aftermarket stuff...
2019 Jeep Unlimited Rubicon (the wife's baby hauler)
72afr is offline   Reply With Quote
