Old 02-05-2012, 04:27 PM   #1
SOON2BLAZE
SOON2BLAZE's Avatar
So you"ve upgraded your headlight harness...
Me to. Did mine about 5 years ago from Classic industries. Glad I did it. Now I need to replace the relay for the high beams. Anyone else had an issue with finding the relay? I did get a "maybe a mitsubishi MB 627 895 will work". Looks similar in the book, they also mentioned a Borg Warner R5008 and a Carquest 56-2054. No local retailer have any of these in stock. Thanks, Chris
SOON2BLAZE is offline   Reply With Quote
Old 02-05-2012, 04:41 PM   #2
Andy4639
Old member
Andy4639's Avatar
Wink Re: So you"ve upgraded your headlight harness...
I used the same relays as the low beam. 12 volts is 12 volts. 30 amp relay. They are good for the 14 volts the alternator puts out.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 02-05-2012, 05:15 PM   #3
SOON2BLAZE
SOON2BLAZE's Avatar
Andy, hi I saw that they were the exact same, thats how I diagnosed the issue. Just looking for a replacement that is a direct fit. TR65 pm'd me this: My relay is a Song Chuan 804-1A-C1
Here is the spec sheet on it.
http://www.therelaycompany.com/datafiles/804.pdf
Here is an ebay listing for it ($3.60+$6.00)
http://www.ebay.com/itm/1pc-Car-Powe...-/140473712708
Of course you could splice in most any 30 amp automotive relay with the pigtail that goes with it.
Old 02-05-2012, 10:03 PM   #4
Andy4639
Old member
Andy4639's Avatar
OK,
I used them from Radio shack ones. I did my own wiring connectors and all.
Old 02-06-2012, 01:01 PM   #5
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Just pick up a 5 spade one at your local parts store.
-1st, they are already in the U.S.(not Taiwan-->E-Bay)
-There only about $5.00 or less.
-Just don't use the 87a terminal.
Picked this Bosch one up at Napa.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 02-06-2012, 01:05 PM   #6
rpmerf
rpmerf's Avatar
thats the relay I used on my car and truck. Its a standard configuration.
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
Old 02-06-2012, 04:12 PM   #7
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
I did mine 5 or 6 years ago and got used relays form a wrecked Dodge Caravan ( which I think the wrecker charged me a 1.00 each ) and everything still works as it should. THis is great upgrade for 15.00 worth of parts and 2 or 3 hours work.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 02-06-2012, 07:42 PM   #8
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
hehe, I did this upgrade on the 71 and it didn't last 2 weeks. Had to unplug it all and go back to stock to even get the lights to come on. It was in Bremerton though and we all know how wet it is, think my relays might have gotten some moisture in them and fried. One day I'll go back through it and troubleshoot.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 03-20-2012, 06:03 PM   #9
Bardahl
Help ! Upon further review??? I have a drivers side low beam on my 68 GMC, thats it, I replaced the other Low beam and checked the lights and all 4 worked, 3 days later and I~m back to 1 drivers side low beam? could it be relays?, these are aftermarket (metal cube relays w/only 2 terminals w/threadeds and nuts to connect the ring terminals too)??
Bardahl is offline   Reply With Quote
Old 03-20-2012, 07:12 PM   #10
Dingfodgy
Lemme show you something!!
Dingfodgy's Avatar
Two terminal relays? Metal Cube? Are these horn relays? Definately sounds like the wrong components are being used. There are several write-ups on this subject. Just go to your local napa grab two 30amp 4-pole relays (Bosch, GE, Sylvania, Delco- it don't matter, 12v is 12v). Make sure to also put in a 20a inline fuse on the power wire from the battery- it's cheap insurance.
'67 CST-10 LWB ("Crusty") SOLD
'67 GMC SWB ("Murdock")
2000 K1500 Suburban ("Betty")
'95 BMW 325i ("Joy")
Dingfodgy is offline   Reply With Quote
Old 03-20-2012, 07:24 PM   #11
Bardahl
thx. will do the new relays.
