Old 02-07-2012, 10:49 AM   #26
lyrikz
PITbut
lyrikz's Avatar
Re: Carb issues, just chime in.
Originally Posted by geezer#99 View Post
When you say your timing is 32 degrees at 3000rpm does that mean with vacuum degrees added on.
A quick curve is timing comes up real fast right after idle and slow curve means timing comes up slowly up to when your timing is all in.
Ported or manifold. Every motor is different. You gotta experiment.
Geez, i couldnt really answer that. I was to busy paying attention to the rpm then checked timing. I couldnt tell how fast it went up...
New project. 1971 Twin Turbo blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=676047
My new YOUTUBE channel.. Videos of my truck and a current walk around.
Lyrikz74 Youtube channel DONE! SOLD!
My 1971 stepside build thread
My Build Thread UPDATED 6/11. DONE
and sold.
lyrikz is offline   Reply With Quote
Old 02-07-2012, 02:03 PM   #27
Cannonball1
Have you tried adjusting the accelerator pump linkage to give you a little more juice when you hit it? If it's like my old Carter AFB (they look the same), move the linkage one hole inward toward the pump. This will give it a little more gas through the boosters when you stomp it. If that fixes it your good. If it makes it worse, go one hole out from the original hole.
Cannonball1 is offline   Reply With Quote
Old 02-07-2012, 02:08 PM   #28
lyrikz
PITbut
lyrikz's Avatar
I noticed that was a very easy thing to try. Once i verify timing, remove that air intake, i will try switching that and see if it gets worse or better and chime in.
and sold.
Old 02-07-2012, 04:52 PM   #29
DANTIP
DANTIP's Avatar
Did the Q-Jet ever have a throttle-shaft bushing kit put in it?
DANTIP is offline   Reply With Quote
Old 02-07-2012, 04:55 PM   #30
lyrikz
PITbut
lyrikz's Avatar
The quadrajet had corroision in EVERY hidden crack. SOaked it, blew it out, and i was continually getting pieces of junk coming out. So i bought a new one.
I also kept the quadrajet and bought a book on how to rebuild it. Mine has all new stuff and is setup right, i just need to get the passages cleaned somehow. THe soaking didnt seem to do it.
and sold.
Old 02-07-2012, 05:45 PM   #31
story2tell
Take a look at a couple of articles on this Corvette site (http://lbfun.com/Corvette/Tech/vettetech.html) scroll down the page to "timing and vacuum advance." The article "Vacuum Advance Principles and Application" by Duke Williams and one by John Hinckley, "Advanced Curves" will explain vacuum advance, timing, and ported vs manifold vacuum. Big Blocks with big cams typically have lower vacuum than stock and usually need to have a different vacuum advance can installed. These two articles helped solve my problems.
story2tell is offline   Reply With Quote
