Old 02-08-2012, 11:22 PM   #1
BillWallace
BillWallace's Avatar
327 has no bolt hole!
My truck is a 66 c20 with a 327 and 4 speed. I was going to throw a new harmonic dampener on and lo there are no threads with which to use my installer tool. Is there some special tool to reinstall the balancer other than the obvious BFH? I really dont want to beat the hell out of my engine for fear of creating unnecessary work for myself.
BillWallace is offline   Reply With Quote
Old 02-08-2012, 11:25 PM   #2
Sillyoldman
#16876
Sillyoldman's Avatar
Re: 327 has no bolt hole!
Some cranks did not have threaded holes. Don't beat the thing. You can mess up the mains. I heated my balancer in the oven on low temp and tapped it on. There are a lot of opinions on this topic. I suppose the best way is to drop the crank and have it pressed on.
Posted via Stationary Device
'71 Custom Deluxe C-20 402.
'67 Buick Special 455.
'49 Plymouth Special Deluxe.
"I love that old car smell"
Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
Sillyoldman is offline   Reply With Quote
Old 02-08-2012, 11:44 PM   #3
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Arrow Re: 327 has no bolt hole!
Don't hit it with the hammer!
Harmonic Balancer Installation Tools:
http://www.jegs.com/webapp/wcs/store...itemPerPage=90
http://www.summitracing.com/search/?...on+Tool&RC=100
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 02-09-2012, 01:37 AM   #4
Captainfab
60-66 Nut
Heat up the balancer as Sillyoldman mentioned, This can be done either in an oven, or in a pot of boiling water. In the over, be very careful you don't get it too hot so as to comprimise the rubber. At the same time, if you can,cool the crank snout. An ice pack should work. Then when you do go to install the balancer, don't mess around, get it driven on before the temps equalize. I would use a soft mallet or at least a block of wood between the balancer and hammer.
Old 02-09-2012, 02:40 AM   #5
dracko
dracko's Avatar
^^what he said^^
Just did that on my 230 and it worked like a charm. I pulled the rad and sat on top of the valve cover to get a comfortable spot to hold a piece of wood on the HB and tap it on.
dracko is offline   Reply With Quote
Old 02-09-2012, 02:54 AM   #6
kc0kfg
Originally Posted by dracko View Post
^^what he said^^
^^what he said^^X2
The installers work wonders when you have a bolt on type but the early ones like yours just use friction.
The heat/ cold trick works well.
1966 Chevy Paneltruck
1992 gmc 1 ton 2wd
1997 burban
Never be afraid to try something remember amateurs built the ark, the Titanic was built by pro's
kc0kfg is offline   Reply With Quote
Old 02-09-2012, 09:27 AM   #7
awbrown
Most people wont agree with this , but the according to everything I have read the early 265 283 balancers were installed with a lead hammer at the factory ,it leaves no marks and works fine .. I have had one I made in my tool box going on 20 years ,I use it for the ones with no bolt holes in the crank ... I have an installer for the rest...
awbrown is offline   Reply With Quote
Old 02-09-2012, 09:32 AM   #8
T Smith
T Smith's Avatar
BFH and a thick block of wood, the heating/cooling trick helps too...
T Smith is offline   Reply With Quote
Old 02-09-2012, 10:56 AM   #9
awbrown
I might ad after loosing one off an engine ,I do drill and tap all of them unless it is for a restoration, it only takes a few minutes in the mill .....
Old 02-09-2012, 06:32 PM   #10
jchav62
1962 C-10
jchav62's Avatar
This is what I was going to suggest. I usually used a BFH and a block of wood in the past. This past summer, I lost one coming back from Taos. Drilled and tapped it after that. Highly recommended...
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 02-10-2012, 12:15 AM   #11
BillWallace
Thank you everyone for your help! Im gonna give the hot and cold trick a shot this weekend. I do wonder, though, how they were put on at the factory. If i had taken it to the chevy dealer in 1966 how would they have installed it?
