Old 02-09-2012, 12:59 AM   #1
Dano69c10
Dano69c10's Avatar
Coilover angle
Can coilover shocks be installed vertical? Should there be some angle to them?
Thanx in advance
Dano
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline   Reply With Quote
Old 02-09-2012, 02:37 AM   #2
mongoose
mongoose's Avatar
Re: Coilover angle
straighter the better.
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 02-09-2012, 01:44 PM   #3
Dano69c10
Dano69c10's Avatar
Re: Coilover angle
kool!
'69 Fleet
Old 02-12-2012, 02:42 PM   #4
robnolimit
robnolimit's Avatar
Re: Coilover angle
He's right. Check into Pro Shocks, or Afco's website, they have graphs and calculators to show the effective spring rate and shock dampening rate changes per degree of angle. There could be an advantage of leaning the shock, but you have to do the math to get it right. A 4" stroke shock laid over 30* from the axle travel line will provide almost 6" of travel, but needs 27% more spring and dampening to provide the same ride as it would straight up.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 02-12-2012, 07:01 PM   #5
Dano69c10
Dano69c10's Avatar
Re: Coilover angle
Thanx Rob,
I do have some C-10 coilover shock thoughts and ideas I'd like to run by you sometime. But I'll have to get back to you sometime in the future.
Thanx
Dano
'69 Fleet
Old 02-12-2012, 08:13 PM   #6
robnolimit
robnolimit's Avatar
Re: Coilover angle
anytime
