Old 02-09-2012, 07:06 PM   #1
Arl37
How do I adjust TV Cable on this setup
1969 C 10 305 with 700r4. Just installed a 600 CFM Holley 4 barrel and Edelbrock Performer manifold. I installed the Holley bracket on the carb that is supposed to give the correct ratio between accelerator post/rod and TV post/cable. Asked AAmaco if they could adjust and they said they didnt have records for this setup so they couldnt do it. Forum seems to have some stuff on how to adjust but it all looks pretty carb and trans specific so I thought I would just ask the question.
Arl37 is offline   Reply With Quote
Old 02-09-2012, 10:47 PM   #2
hugger6933
Re: How do I adjust TV Cable on this setup
Push the "button" on the big part of the cable just where the bracket snap is. Once the button is depressed push the inner portion of the cable assy [where the cable come out and hooks to the carbis a inner lining looking part]back towards the bracket. That will tighten the cable. Now, by hand crank the trhootle open to the WOT position. The cable lining should clickseveral times and come out a good bit . That is supposed to be correctly adjusted. I don't know why the trans shop did'nt do this for you or at least tell you, maybe they either don't know themselves how to work on the "old" stuff or maybe they are just jerks. Now do you know what the trans came from? if it was a truck your ok, but if it is from something else you may have trouble with perfect shifting. I had a 350 tbi I put into a s-10 once that came from a G20 and the gov was different and made the shifts late because of the weight of the van compared to the truck Yon can move the inner part of the cable in just one click or out one if the above adjustment doesnt get dead on
hugger6933 is offline   Reply With Quote
Old 02-09-2012, 11:26 PM   #3
dukcaln
dukcaln's Avatar
pretty much it......
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP
SOLD 1972 chevy c10
dukcaln is offline   Reply With Quote
Old 02-10-2012, 12:12 AM   #4
Arl37
Old 02-10-2012, 12:19 AM   #5
Arl37
Mine is a little different . It has a snap that I pull out to unlock the sleeve. then im told to pull the sleeve out. Then wot .While WOT push sleeve back in and push the snap in to lock the sleeve in place. does this sound right?
Old 02-10-2012, 09:02 AM   #6
hugger6933
If you unlock it and pull it out, no tension will be on the TV cable. I think you and I are backwards instead of pulling out try pushing in
