Old 09-08-2003, 10:35 AM   #1
MStokes
MStokes's Avatar
Lower Control Arm U-Bolts
Are the 4 U-bolts that hold the front lower control arm shafts to the frame supposed to be the same size? I noticed I have two that are slightly larger than the other two. If two are supposed to be a little larger, where do the larger ones go?
1972 C-10 LWB, 400/350, 2WD
1972 C-20 Custom Camper, 350/350, 4WD (Converted)
MStokes is offline   Reply With Quote
Old 09-08-2003, 10:50 AM   #2
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Mine were all the same size.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 09-08-2003, 11:16 AM   #3
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Sounds like someone only replaced U-bolts that were bad at one point. Some of the origanals were the smaller ones, however they would have all been that way. The larger ones were produced to replace the smaller ones, and all that are available now. You probably have two different size holes in your crossmember also, so if you want to reuse the U-bolts then the larger ones will not fit in the smaller holes. If they do then it realy doesn't matter where they go. I wouldn't re-use them myself, the nuts are self locking and may not work as well the second time around. WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 09-08-2003, 11:20 AM   #4
MStokes
MStokes's Avatar
Thanks for the details Wes. Should I be able to get suitable replacements with self locking nuts at a bolt supply house or would I need to special order them from a part vendor?
Old 09-08-2003, 11:48 AM   #5
71HUGGER396
Confirmed Truckaholic
71HUGGER396's Avatar
I just bought these parts at napa, the new bolts were 9/16". I thought I would have to drill the holes out but they just fit.
71HUGGER396 is offline   Reply With Quote
Old 09-08-2003, 11:51 AM   #6
MStokes
MStokes's Avatar
Should these U-bolts be grade 8?
Old 09-08-2003, 12:04 PM   #7
Hugger
Hugger's Avatar
I just re-did my front end this past weekend...
In the picture you posted one has flat washers, and the other has lock washers.
I replaced my self locking nuts with grade 8 nuts, and lock washers.
Anybody se a problem with using lock washers, instead on self-locking nuts?
72 LWB - Hugger Orange
350/350 3.73
Next; 335hp GM Crate
Hugger is offline   Reply With Quote
Old 09-08-2003, 02:54 PM   #8
Fred T
Cantankerous Geezer
Fred T's Avatar
They take a lot of vibration and can work loose. Use red Loctite.
I purchased 1/2" grade 8 flanged locknuts with black oxide coating at the hardware store, they were over a buck each!
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
